33x12.50 Toyo MT PSI?
Discussion in 'Wheels & Tires' started by BronsDaGreat, Dec 2, 2013.
  1. Dec 2, 2013 at 1:12 AM
    BronsDaGreat
    BronsDaGreat [OP] Well-Known Member
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    6" FabTech Lift 20x12 Fuel Hostage Wheels 33x12.5 Toyo M/T Camburg Uni's UCA Spintech Muffler AppRadio 3 BHLM Wet Okole Seat Covers WeatherTech Floor Liners WeatherTech Vent Visors 6000k HID Headlights and fogs All Lighting Changed To LED AntennaX 13" Antenna Ceramic Tint K&N Drop In Filter Fully Debadged Blacked Out Emblem
    Anyone running these on a 20x12 wheel? If so what psi do you recommend? I am currently running it around 50psi..
  2. Dec 2, 2013 at 1:36 AM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    A lot of people use the chalk test, draw a line across the tires tread surface, drive around and check to see if the chalk scrubbed off. If there is still chalk visible on the edges, lower tire pressure and try again. This ensures a even contact patch, and the tires will wear better. With tires that wide, you could run higher pressure than the chalk test to get better MPG, but the tires will wear faster in the center. Typically the front tires require more pressure due to supporting more weight, but it all depends on how our truck is loaded.
  3. Dec 2, 2013 at 1:47 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    this
    Here's a Ehow article if you need even further clarification
    http://www.ehow.com/how_6948382_chalk-tires.html
  4. Dec 2, 2013 at 1:50 AM
    BronsDaGreat
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    Thanks guys! This website is unreal! I'm new to trucks and appreciate the help! Jeff at Maui off road set it to around 50 psi.. Just wanted other opinions.. Mahalo!!
