33x12.50x15 rubbing uca!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by SkyHighTacoma, Oct 18, 2011.
  1. Oct 18, 2011 at 7:28 PM
    SkyHighTacoma
    SkyHighTacoma [OP] Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    So I put some 33x12.50x15 tires on my stock 15" wheels and they fit fine expect the rub on the uca. I was thinking of wheel spacers, but I REALLY DONT want wheel spacers and I dont have the money for new wheels. So I was thinking maybe I could grind off just enough of the very end of the uca to clear the tires (maybe 1/4" - 1/2") and re-weld a steel plate to patch it back up. Is this a bad idea for mild offroading? It will only be for now untill I can afford new wheels and light racing uca. Has anyone done this before? :confused:
  2. Oct 18, 2011 at 7:30 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    im no expert but this sounds like a horrible idea
  3. Oct 18, 2011 at 7:32 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Rub at all time? Or certain times..
  4. Oct 18, 2011 at 7:33 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    awh shit here comes that one sas guy..
  5. Oct 18, 2011 at 7:37 PM
    Supra TT
    Eric
    Indiana
    Whats a UCA?
  6. Oct 18, 2011 at 7:39 PM
    Stubbs95tacoma
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Its what the cave men used on their carts pulled my wolly mamoths or some shit like that all i know is the solid axel is soo much better :thumbsup:
  7. Oct 18, 2011 at 8:00 PM
    SkyHighTacoma
    Josh
    15 DCSB SR5 MGM
    Pretty much at all times. If I were to hit the smallest bump in the road, yea, rubbing alot. I dont see how its a bad idea, all your doing is alil grinding and alil welding. Its not like your cutting it in half. People cut and reweld the body mount on 2nd gens just to run 33's, how is this so much different? I wouldnt think it is messing with the strength since your barely grinding after the upper ball joint so it just extra metal?
  8. Oct 18, 2011 at 8:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Why do you suppose toyota put that lil bit of extra metal right there. Does it feel like they put it there just to keep you from running 33/12.5-15s on stock wheels?
    It is ridiculous to compare the body mount chop to cutting and grinding on your suspension pieces which has the potential to weaken said piece. :facepalm:
    Have you seen what happens to a tacoma that looses a wheel at speed? You are proposing modifying a peice that holds your wheel on.
  9. Oct 18, 2011 at 8:54 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Wheel spacers...... a lot safer than trimming the UCA, me thinks.
  10. Oct 18, 2011 at 8:58 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    I would just get wheel spacers until i could afford new wheels. i deffinatly would not cut anything off the UCA
  11. Oct 18, 2011 at 8:59 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Dude there is nothing wrong with a good set of wheel spacers. Spidertraxx and Allpros are great spacers. I am runnign 1.5s on my truck, i love them and i offroad and drive the piss outa my truck sometimes. Have held up great. The way i see it if LT guys can run them and hit big jumps and have no probs..im sure you will be fine.
    Cutting the UCAs is a BAD idea.
    Your options are basicly this:
    -Wheel spacers, cheap and easy to do, get a good brand and you will be fine, can always resell once you have funds for other options
    -New UCAs Pretty pricey and no gaunette it'll solve your issue. Nice all around upgrade tho..
    -New rims with proper back spacing. This can be about the same at the UCA or really expensive.
    Take your pick.
  12. Oct 18, 2011 at 9:35 PM
    SkyHighTacoma
    Josh
    15 DCSB SR5 MGM
    It was just an idea. I was researching and saw that it HAS been done. And (I THINK) that I read that someone actually does this to stock uca's from a 4runner? and shaves it so you can run wider tires and sells them. So I figured if it has been done before, wouldnt hurt to keep it as an idea for research. I just dont know how it will look with spacers. Its already wide as hell..
  13. Oct 18, 2011 at 9:39 PM
    SkyHighTacoma
    Josh
    15 DCSB SR5 MGM
    I was compareing the body mount chop to the uca because the way I would cut it (if I was going to do it), would be just like a body mount chop. Shave it and plate it back up. Not in a way saying, "if you can do it to a body mount, why not a uca? I understand they are both completely different ball parks, just trying to describe how I would cut it, if I was going to do it. Sorry for the misunderstanding Im exhausted so Im not very clear right now. ;)
  14. Oct 18, 2011 at 9:41 PM
    SkyHighTacoma
    Josh
    15 DCSB SR5 MGM
    You have Allpro spacers right? I thought I saw that in one of your post.
  15. Oct 18, 2011 at 10:16 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    :p
    Haha jk man I hope you figure out what you decide to do. I love wider tires. By the way something like this could happen if you decide to do something like trim the uca....
  16. Oct 18, 2011 at 10:23 PM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Get some 1/4" spacers from Wheelers if it is close, but doesn't require 1" spacers. They are super cheap too. It might be enough to clear the UCA.
  17. Oct 19, 2011 at 5:18 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    unless you have balancing issues. no place i've ever delt with will try to fix a tire balance issue if you have spacers.
    it's best to save up and get wheels with the correct backspacing.
  18. Oct 19, 2011 at 5:50 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    If you are using the stock wheels that is a mistake right off the bat and I'm surprised a reputable tire shop even mounted them, not hard for those tires to pop right off the rims. I might have went with 33x10.50.15's on those rims or at most 32x11.50x15, but now that you have them save up and get wheels the proper width and the proper backspacing.
  19. Oct 19, 2011 at 5:56 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    pretty sure i've read before you need at least 16" rims
  20. Oct 19, 2011 at 7:17 AM
    Space Wrangler
    JCT
    Ga
    04 DC 4x4
    are the stock wheels only 7" wide? ...if so, you are correct. ...need at least 8" to run a 12.5" tire
