33x12.50x18
Discussion in 'Wheels & Tires' started by robdawg14m, Feb 1, 2010.
  1. Feb 1, 2010 at 7:43 AM
    robdawg14m
    robdawg14m [OP] Rob
    Robert
    Denton, TX
    08 DC 4X4 SR5
    Apline IDA-X100 Head Unit Massive P 950.5 Amplifier 100x4 + 550x1 Diamond Audio 10" D1 Sub Focal K2 Component 165KR Debadged 33x12.5 Toyo MT 18" ATX Artillery Toytec ultimate lift kit LR UCA's Wet Okole seat covers
    Okay, so I purchased the Toytec Ultimate Lift Kit and in the mean time I have been shopping for tires and rims. A local shop keeps telling me that 33X12.50X18 tires will fit without any rubbing issues. I want to believe them, but everything I have read no one is running that wide of a tire. Does anyone have any ideas?
  2. Feb 1, 2010 at 7:59 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  3. Feb 1, 2010 at 7:59 AM
    grizzbear
    grizzbear Well-Known Member
    im running a 3512.50r18 with my 6 inch lift and it rubs at full lock and half with a lil compression. ive been thinking on down sizing to a 33x12.50 to help with this problem. cuz i dont have the tools to hack up my body mount.
  4. Feb 1, 2010 at 8:01 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    what's the tire size you want to run (in metric)?
    too lazy to convert it, but i'm running 305/55 20's with a -21mm offset wheel and i had to trim quite a bit, including the cab mounts.
    even some 285 setups rub the cab mount, but it'll all depend on the wheels you are planning on running and what kind of backspacing / offset they've got.
  5. Feb 1, 2010 at 8:15 AM
    robdawg14m
    robdawg14m [OP] Rob
    Robert
    Denton, TX
    08 DC 4X4 SR5
    Keason1, it's the guys at Rock and Roll Offroad that are telling me this. They have built two bad ass tacomas up there that they have at the shop, so I want to believe them. 318/60/18 is the metric size.
    I ordered a set of 285/17/17 Toyo MT and rims on Saturday, but when I got home I had voicemail that said they only had 3 of the rims I ordered in stock and that they couldnt get another one in for 4 to 5 weeks, so they changed the order to 18's in the same rim and a 33X12.50X18 tire for the same price since it was their fault. I have been emailing them asking about the fit, but they keep telling me there wont be a problem and not to worry. I dont want to put my lift on and then get to the shop just to have the tires not fit.
  6. Feb 1, 2010 at 12:32 PM
    robdawg14m
    robdawg14m [OP] Rob
    Robert
    Denton, TX
    08 DC 4X4 SR5
    Anyone?
  7. Feb 1, 2010 at 1:47 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    In my experience, the maximum tire height without rubbing in a 3" lift is 32". The 33" tire will fit but will have rubbing in wheel wells or cab mount. Rubbing will be experienced when at at full lock or turning with suspension compressing.
    The amount of rubbing will also depend on the wheel backspacing, the actual tire height, the tire width and caster adjustment. Most are running 285/75/16 which is 33x11.5x16. I think the 12.5" width will rub more, but it depends on the other factors. The only person I know who runs this tire is HBTacoma but he has RCD 4.5" lift.
  8. Feb 1, 2010 at 2:13 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    You will for sure, have rubbing. However, it will be very minimal rubbing, most of which will be on the front part of your fender. Use a sharp knife or dremill tool to trim the plastic. On very sharp turns, backing up, you will also run on your body mount, but very little.
    Edit: you would have less rubbing with the 285/70/17's which are 11.5 wide, where as the 33/12.5/18's are an inch wider.
  9. Feb 1, 2010 at 2:26 PM
    robdawg14m
    robdawg14m [OP] Rob
    Robert
    Denton, TX
    08 DC 4X4 SR5
    I figured there would be rubbing issues either way. It came down to me not being patient enough to wait 4 or 5 weeks for the 17s, so I just took what the shop was offering.
    I have no problem with having to trim, but I'm just gonna have to find a shop that can do the cab mounts. I have been looking at snowboarders rig because he is running a 33X12.5X17, and I his truck is sick! I was just so set on getting the 285/70/17s that this whole thing kinda had me second guessing the 33X12.5, but im gonna roll with it and see how it comes out.
  10. Feb 1, 2010 at 2:28 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    Good luck man. At least you know what you are up against and the fix.
    Glad to have another TW member in Denton County.
  11. Feb 1, 2010 at 2:44 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    i have a 3 inch lift. Im running 33-12.50-17 on stock rims. I have spidertrax spacers also. I only rub a little when the wheel is cranked all the way
  12. Feb 1, 2010 at 2:56 PM
    robdawg14m
    robdawg14m [OP] Rob
    Robert
    Denton, TX
    08 DC 4X4 SR5
    Yeah man, theres not many people on this site that are from the North Texas area.
  13. Feb 1, 2010 at 8:24 PM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    click on the camera below my username to see pics of my body mount chop :D
