33x13.50 on 15x8 wheel
Discussion in '1st Gen. Tacomas (1995-2004)' started by kwackin, Oct 24, 2017.
  1. Oct 24, 2017 at 5:02 PM
    kwackin
    kwackin [OP] Active Member
    99 Tacoma extended cab sr5 4x4
    I'm looking at nitto mud grapplers and the only size they make for a 15" wheel is 33x13.50. Are there any safety issues/concerns as far as running 13.50 on an 8" wide wheel?
  2. Oct 24, 2017 at 5:18 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    That's a pretty skinny rim for a tire that wide, I'm sure it can be mounted but chances of popping a bead may increase, balancing may be an issue as well.
  3. Oct 24, 2017 at 6:47 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    less chance of popping bead. shouldn't affect balancing.
    it will most likely wear uneven though. hel have to run low tire pressure to help.
    i ran 11.5s on a 7" rim without issues just the same but who knows.
  4. Oct 24, 2017 at 8:04 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I ran this exact setup on my truck before I sold it, no issues what so ever. Post #505 in my build thread shows what they'll look like roughly depending on your backspacing.
