34 Gallon Fuel Tank - Long Range Automotive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimbo623, May 21, 2017.
  1. May 29, 2017 at 5:27 PM
    jimbo623
    jimbo623 [OP] Jimbo
    Pueblo
    11 TRD Off Road
    Grillcraft Grill, Hella Black Magics, ICON shocks w/ remote reservoir, Total Chaos UCAs, Tom Woods Drive Shaft, TSB springs, LED Dome light, Redline Hood struts, Slotted rotors, WheatherTech Mats, Ultra Gauge, and Illuminated 4x4 switch
    I have you on the list in Group Buy thread.
  2. May 29, 2017 at 5:29 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    The tank is 45 kg which equals 99.2 pounds.
    Gas weighs in at 6.3 pounds x 20 gallons = 126 pounds + 14 extra gallons (88.2) = 214.2 pounds
    A tank with gas would weigh 313.4 pounds.
    Don't know what the stock tank weighs.
    12TRDTacoma and tacoguy67 like this.
  3. May 29, 2017 at 6:35 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    thats just for the fuel (around 91.5lbs) extra. .
  4. May 29, 2017 at 7:16 PM
    dawgrules
    dawgrules Active Member
    Ummm, two jerry cans bring me within 3 gallons - sure they take space but I have better ways to spend my money personally.
    12TRDTacoma and sfcacique like this.
  5. May 29, 2017 at 7:29 PM
    G.T.
    G.T.
    CONUS
    Good for you.
  6. May 29, 2017 at 8:39 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    To each their own. No one ever said this is the cheapest option to carry more fuel, but it is definitely the cleanest.
    12TRDTacoma likes this.
  7. May 29, 2017 at 9:37 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    That's the shipping weight which might be a bit more than the actual tank weight. I seem to recall some ext range tank being in the high 30kg range - 37 or 38 - as described on ExPo. Don't know if it was the same one though. Anyway somewhere between 80 and 90lbs is probably a sane estimate.
    Can't find the specs, but based on similar capacity tanks from 1st gen it is probably around 35 lbs.
    So the ext range tank probably adding about 50 lbs dry weight compared to the stock tank.
  8. May 30, 2017 at 3:46 AM
    dawgrules
    I wont argue that, it definitely removes the "banjo" factor -
  9. May 30, 2017 at 3:52 AM
    LastoftheGen2
    LastoftheGen2 Well-Known Member
    Mighty Mo
    NY & Vermont
    2015 Taco TRD Off Road
    Fab 4 Bumper with 9,000LB Winch. Prefy high lift rear bumper, All-Pro rock sliders, steel skids, expedition leaf pack and U-Bolt flip kit, King shocks with 700 lb springs, BFG AT KO2's 265/75, Safari snorkel, rear diff breather mod.
    Tank looks pretty solid. Do you think you would need a skid plate on it,,or is it solid enough on its own to go smashing.
  10. May 30, 2017 at 4:32 PM
    jimbo623
    jimbo623 [OP] Jimbo
    Pueblo
    11 TRD Off Road
    I believe it would, especially since the original skid is junk.
  11. May 30, 2017 at 5:07 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I wouldnt go smashing on rocks with anything made of aluminum, especially a fuel tank. Aluminum has no give.
  12. May 30, 2017 at 5:10 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Funny thing is, I've wheeled all over the place and the only skid I don't have is a gas tank skid. :oops:
  13. May 30, 2017 at 5:18 PM
    sfcacique
    sfcacique Well-Known Member
    Florida
    4WD TRD Access Cab
    Thule Racks with Hullavator, Pioneer Stereo/Nav
    Ref Taco Lean, i just put on Dakar leaf springs, as well as OME Shocks.
    Noted the leaves are marked for over, norm and under, but within specs. I put the over (+) on the driver's side, and the under (-) on 7th he passenger side.
    I still have to line up the rear shock bushings to finish the install, but I'll let you know if it makes any difference. Of course, I never noticed any lean before in my 2006 OR
  14. May 30, 2017 at 5:30 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Note in the LRA FAQs there is this line:
    Do I require an aftermarket gaurd to protect my tank?
    LRA tanks are constructed from 2mm aluminised steel and fully baffled internally, therefor a seperate gaurd is not required.
    Maybe the misspellings are an Aussie thing, but regardless it looks like they are saying the tanks are strong enough they don't need a guard like the OEM plastic tank has, but that is not the same as a skid.
    tinker_troy likes this.
  15. May 30, 2017 at 5:35 PM
    #35
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to TW! Do you have an LRA tank in a 2nd gen DCSB truck?
  16. May 30, 2017 at 5:38 PM
    #36
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This theory is irrelevant because all they are visually inspecting for during a smog inspection is the cat converter and all vacuum routing lines to be correct along with all original OE equipment and/ or CARB certified intake and exhaust systems. They don't give a hell about the fuel system. EVAP is the only relevant system if they can visually access it without having to break themselves trying to inspect it, in our case they may be able to see it, but as long as you have no codes in the PCM you are good to go.
    Torspd and HomerTaco like this.
  17. May 30, 2017 at 5:40 PM
    #37
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Spray it black so it doesn't stand out in bright silver, then take it off road to cake it in some dirt so it looks like it belongs to reduce the likelyhood of questions.
  18. May 30, 2017 at 5:42 PM
    #38
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If I got one I would rock it bare and tell them to piss off. Smog techs (myself at one time included) have never once been instructed or trained to look at the fuel tanks.
    crashnburn80[QUOTED] likes this.
  19. May 30, 2017 at 5:42 PM
    #39
    LastoftheGen2
    Mighty Mo
    NY & Vermont
    My bad, I did not realize they were aluminum.
    Funny, factory skids are more like paper plates than skid plates.
    Installing the All Pro IFS, trany and transfer right now but not sure about the gas tank.
    Never dragged it but we'll see
  20. May 30, 2017 at 5:48 PM
    #40
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not aluminum. Aluminized steel.
