34" Tires - Nothing but the truth.... BF Goodrich KM2 - 285/75r17
Discussion in 'Wheels & Tires' started by Limitless, Feb 25, 2013.
  1. Feb 25, 2013 at 8:37 PM
    Limitless
    Limitless [OP] Well-Known Member
    Scott
    NW Illinois
    12 DCLB White TRD
    De-badged, Tinted Windows.
    I know I searched and searched for this set up so I figure I will share the wealth..
    So here is the set up, bone stock 2012 TRD Sport 4x4 DCLB. I will post a lot of images of these being installed, so if you have questions or want more images ask quickly as the glass is going on this week and the chance for more images will not last too long.
    Tires: BF Goodrich Mud Terrain KM2 - 285/75r17
    - Sect. Width: 11.3"
    - Tread Width: 8.7"
    - Overall Diameter: 33.9"
    Wheels: Mickey Thompson Classic Lock 17x9
    - Back Spacing: 4-3/8
    - Offest: -15
    - Part Number: 479412
    I know everyone is going to freak out, since there is no lift on the truck yet, but here is the theory behind this. If it wont fit at stock ride height it wont fit when you lift the truck!! Well, it may fit, but it will still hit once the suspension cycles to the stock ride height position of the control arms.
    THE FRONT:
    So, do they fit? Yes, but this is not a drivable set up. You can not turn the wheel more than a few degrees.
    Can taking off or trimming only the plastic flare help? Not really, you will be able to turn the wheel further, but you will still make contact on the rear of the fender opening and the front bumper.
    So, bottom line, at this tire size you would need to trim the edge of the front bumper (possibly some of the inner liner), You will need to trim the rear of the Actual Steel Fender, and the plastic fender if you wanted to run that on the truck too.
    As for the pinch weld and the body mount, i will update more once the other side of the truck is torn down and the full lock to lock steering can be checked out.
    On to the Pictures, Again this truck is at factory ride height with stock suspension in these images.
    THE REAR:
    They seem to fit pretty well, now by no means was I able to flex the rear out yet, but for daily driving these tires will clear no problem. With a few buddies jumping in the back of the truck they did not touch the fender flare.
    Front View:
    Driver Front - No Flare - Cab Clearance:
    Driver Front - Bumper Clearance:
    Driver Rear:
    Passenger Front - With Flare:
    Driver Rear:
    Passenger Rear:
    Passenger Front - With Flare - Cab Clearance:
    Passenger Front - With Flare - Bumper Clearance:
  2. Feb 25, 2013 at 8:45 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  3. Feb 25, 2013 at 8:48 PM
    jandrews
    '09 FourDubDee TRD OR
    You're going to rub front and rear without trimming. Even with trimming there may still be some frame/UCA contact, and it's quite possible you'll buckle the bedsides at full flex of the rear axle.
    Most of this is pretty much known. There are rubbing issues with 33s.
  4. Feb 25, 2013 at 8:49 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    :jellydance: now get to trimming :popcorn:
  5. Feb 25, 2013 at 8:51 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    This is the size I want to get when my current tires are done.
    did you have to special order them?
    Can you get some pics of your truck from further away also.
  6. Feb 25, 2013 at 8:55 PM
    Limitless
    Scott
    NW Illinois
    12 DCLB White TRD
    Yes, I am fully aware of the fact that these do not fit. However, when I was looking for details about this size wheel, I could not find much. I was hoping to provide some insight for others on how this will work out and what needs to be done to clearance for these tires. I will continue this write up and the fiberglass installation along the way to help out anyone heading down these two roads.
    You can see the solution here:
    There is a full set of glass going on the truck, to truly clearance for the tires. Anything else in the way will get the BFH treatment or get cut out of the way! :D
  7. Feb 25, 2013 at 8:58 PM
    Limitless
    Scott
    NW Illinois
    12 DCLB White TRD
    Yes, I will take some pics for you tomorrow, when the sun is out so you can see the whole truck on both sides.
    You can see the tires in my build thread. These were ordered from discount tire direct with a pricematch from some dude on ebay. They were $306 each to my door.
    The Build
  8. Feb 25, 2013 at 8:59 PM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    Posted before I got there, thanks
  9. Feb 26, 2013 at 3:01 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    :popcorn: I'm curious to see how much has to be cut, ground, and hammered to keep those from rubbing at full lock and full suspension compression
  10. Feb 26, 2013 at 3:10 PM
    jandrews
    Not much. He's going glass.
  11. Feb 26, 2013 at 3:17 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Sub'd. I think I like where this is going.
  12. Feb 26, 2013 at 3:21 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
  13. Feb 26, 2013 at 3:27 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
  14. Feb 26, 2013 at 5:16 PM
    TexasTacoma37
    I saw that. That's why I'm interested.
  15. Feb 26, 2013 at 5:19 PM
    jandrews
    Pretty much cab mount, pinch weld, spacers, and he should be good.
  16. Feb 26, 2013 at 5:24 PM
    Doomsday
    Doomsday Well-Known Member
    Cypress, TX
    2017 TRD Sport 4x4 DCSB MGM
    Lights, Tires, Wheels,...more to come!
    Which brand fenders and size you go with?
  17. Feb 27, 2013 at 5:37 AM
    Limitless
    Scott
    NW Illinois
    12 DCLB White TRD
    From what I can tell on the actual steel fender, you will need to cut back the metal of the fender itself near the cab. I will take more pictures before we take that side off tonight.
    I went with Glassworks Unlimited 4.5" fenders ordered from Camburg Racing.
    ...also to the others, sorry, no full truck shots yesterday we were blasted in a snowstorm, updates tonight....
  18. Feb 27, 2013 at 6:05 AM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    Subscribed
  19. Feb 27, 2013 at 7:59 AM
    jandrews
    Negative. You will need to cut the cab mount and pound the fenderwell and pinch weld back with a good sized hammer, but tubbing is not strictly necessary. It will result in a bit of a cleaner finished look if you cut and re-tin.
    The issue can be minimized by running the smallest wheel spacer/most backspacing you can that keeps you from rubbing the frame in front of the suspension. This minimizes the scrub radius.
  20. Feb 27, 2013 at 8:01 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Are the bfg all terrains 33.9? Or closer to 33
