34x10.5x15 Super Swamper LTB Need Help???
Discussion in '1st Gen. Tacomas (1995-2004)' started by BM0093, Oct 1, 2014.
  1. Oct 1, 2014 at 1:25 PM
    BM0093
    BM0093 [OP] Member
    Brandon
    Lancaster, SC
    2000 Regular Cab 4x4
    31x10.5x15 Mud Claws everything else stock
    I have a 2000 Toyota Tacoma regular cab and am looking at lifting it I was wanting to know if I was to put a 3 or 3.5 inch lift could I clear them the tires O.D is 33.6" tall and 11" wide with my stock rims I have 15x7 will I need to run spacers?
  2. Oct 1, 2014 at 1:58 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Gonna need wheel spacers and more lift especially for swampers
  3. Oct 1, 2014 at 2:03 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    The max you're gonna want to go with the IFS is 3", more than that and your CV's will be at too high of an angle. At 3" you can probably fit those tires, you will almost certainly need spacers (probably 1.25") because of the positive offset of the stock wheels.
    I'm running 255/85/16, which are about 33.1" tall, with a 3" lift and 4" backspace wheels, and it doesn't rub at all.
  4. Oct 1, 2014 at 2:05 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    I had a 2001 years ago with BFG 33x10.50 15's and if I remember right I got a little rub with those. So yea what bellassaiw10 said. More lift and spacers.
  5. Oct 2, 2014 at 8:46 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    If I were you, I would (cleanly) cut back the pinch weld and the corner of your quarter panel (as necessary). After that, you may need to push back a your fender well a little more. But, you should be able to fit them. If you only lift the truck, the second you flex your suspension, you'll cut your tires and rip something off your truck.
  6. Oct 2, 2014 at 9:45 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Swampers are notoriously taller then they say. You'll have to end up tubing probably. At that point might as well get a bigger tire
