34x10.5x17 for Overland Expedition
Discussion in 'Wheels & Tires' started by EMTacoma, Oct 9, 2015.
  1. Oct 9, 2015 at 4:31 AM
    EMTacoma
    EMTacoma [OP] Member
    2014 Tacoma Sport - Manual
    I'm new here to the forum I have a 14 Tacoma Sport Crew cab Manual. I'm planning an overland trip from Central PA to Northern Labrador, Canada in late December. See my route below. I've been trolling around here and the overland expidition portal for the last couple weeks. and learned a lot.
    The extent of my off roading is logging roads, and old abandoned forestry roads here in PA. I'd like the capability to do moderate offroading, but am not expecting to do a ton more than what I have done previously. I'm looking to put a 3inch lift on to accomodate some larger tires, preferably KO2's. The main purpose is for utility, but looks are certainly a plus. The reason I'm looking at KO2s is because I need something that is able to handle snow on gravel roads fairly well, and they seem to do the job. The translabrador highway runs for 500+ miles on only gravel with significant washboard sections, and can get fairly hazardous in the winter. I'll bring chains, shovel, vehicle recovery plates, come-along.
    My main question now is:
    Will BFG KO2S that are 34x10.5x17 fit on my truck with a 3 inch ome lift without cutting and trimming? I currently have 265x65x17 on the stock wheels. I'm thinking that getting a tall skinny wheel will help eliminate some of the issues with rubbing while turning. I'm okay with a slight rub at full-lock since most of the time I won't be doing super-technical off-roading that requires full lock turns. Any help or advice would be great. Thanks!
    doublethebass likes this.
  2. Oct 12, 2015 at 6:48 AM
    Missouriprerunner
    Missouriprerunner Well-Known Member
    Adam
    STL MO
    2018 dbl cab sr5
    Use the search function to look for the biggest size stock tires you can use on your truck, but I will tell you that 33's usually rub a bit on most people's rigs.
  3. Oct 12, 2015 at 6:54 AM
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    That looks like an awesome route!
  4. Oct 12, 2015 at 7:02 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Those will rub with no cutting and trimming.
  5. Oct 13, 2015 at 6:05 AM
    EMTacoma
    Yeah, it should be pretty cool. It's about as far north as you can go in Eastern Canada.
  6. Oct 13, 2015 at 6:09 AM
    EMTacoma
    Thanks! I found a post on this. https://www.tacomaworld.com/threads/255-85-r16-owners-experience.155849/ The tire dimensions are essentially the same if you read through the 156+ pages of posts, haha. It basically looks like it depends, but most of the time it will work. the KO2s aren't true 34" tires either.
  7. Oct 13, 2015 at 6:11 AM
    EMTacoma
    With a full 3" lift, which is what I'm planning on getting.
  8. Oct 13, 2015 at 9:18 AM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    From experience I've seen swapping coils and getting the spacer is the way to go rather than just a huge puck up front, takes some bounce out off-road and prevents tires from slammed the plastic or body.
  9. Oct 13, 2015 at 1:46 PM
    EMTacoma
    Okay, so you're saying an OME kit with the spacers and coils is a good way to go? This is what I was looking at:
  10. Oct 13, 2015 at 6:59 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Yea that's a kick ass kit, you will be more than happy with it. BUT remember that I had said with a full 3in lift most guys still see rubbing with 33's.
    Heck my buddy this week has a 3in lift on his work truck, a 2014 sierra and put 34's on it and it rubs now. So you'll need to be looking more into like 5 or 6in lift for 34's on a tacoma. Look through the threads and Google some builds with 34's to make sure you don't end up rubbing the crap out of your truck or tires
  11. Oct 14, 2015 at 3:45 AM
    EMTacoma
    Tarzan13 likes this.
  12. Oct 14, 2015 at 4:28 AM
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    Don't get a 5 or 6 in lift just do the cab mount chop, and trim some of the plastic, its not too hateful. Read up on anything over 3" not ideal for these trucks.
  13. Oct 14, 2015 at 4:36 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    This.
  14. Oct 14, 2015 at 7:05 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    It also might seem like you won't rub at first while parked on level ground, but as soon as you cycle that suspension when turning and going over a curb or into a parking lot, you'll rip your front mud flap off immediately.
  15. Oct 14, 2015 at 7:45 AM
    EMTacoma
    Agreed. I'm not putting anything >3" on. I was just trying to find the happy medium where I wouldn't have to cut the truck. But it looks like that might not work even with skinny 33s.
  16. Oct 14, 2015 at 7:46 AM
    EMTacoma
    SJ, makes sense.
  17. Oct 14, 2015 at 10:18 AM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Tire rack shows specs which show true tire size for that tire, just look under your tires specs. But yea like the guys said, on the pavement and even the occasional curb bump you may not notice rubbing even with a 33 but go off road and try to make a sharp turn and you'll be rubbing like crazy. My friends got a 4in lift that does well with 33's off road. Look into that maybe
  18. Oct 15, 2015 at 3:40 AM
    EMTacoma
    I'll give that a shot, thanks. Its a shame that you can't do 34s and a three inch lift without cutting. But not much I can do about that.
  19. Oct 15, 2015 at 8:14 AM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    I still have 265 75 16's on my truck with a 3in lift, I hated the look of it the first month but now it's grown on me, still doesn't look right but I don't roll my eyes when I see it lol. I have a hurt back from an accident so I won't be off road any time soon. I'll just save my money up and maybe after Christmas my back won't be hurt.
  20. Oct 16, 2015 at 2:46 PM
    mouse007
    mouse007 Well-Known Member
    Mauricio
    Weston,Florida.
    2014 TRD Off-Road 4x4
    ICON Vehicle Dynamics Uni-Ball UCA, ICON Vehicle Dynamics Extended travel remote reservoir coilovers, with 700# Coils and CDC (Compression Damping Control) Clicker Valves. Dakar Leafs Old Man Emu Nitro Sport Shocks Toyotech U-Bolt flip kit, Goodyear F. & R. extended Stainless Steel Brake lines. aFe Pro Dry drop in air filter. ARB Bull Bar. Weld on AVID Off-Road Rock Sliders W/ Kick Out. Tires: 285/75 R16 BFGoodrich KO/TA's. Light Force Blitz 240's 12v. Warn M-8000 W/ Viking Off-Road Synthetic winch line.
    @EMTacoma I have the 34" KO2's its an excellent tire about 1" taller than a 285".
    I'm also running Old Man Emu 886 coils with Icon UCA.
    My Caster is set as follows Left 2.1* and Right 2.3* this isn't the best, but the tech was a bit of dick and didn't want to dial more Caster.
    With that said, at FULL Stuff and the wheel slightly clocked I rub on the lower fender flare.
    It's very little so I think with better Caster numbers I wouldn't rub..
    I'm currently selling my 34" KO2's on FJ Steel wheels if your interested.
