35 gal fuel tank group buy
Discussion in 'Group Buys' started by steve103, Jan 25, 2013.
Thread Status:
Not open for further replies.
  1. Jan 25, 2013 at 9:47 PM
    #41
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    An extra 15 gallons is only ~130 lbs more. If you've got the cash for this, you probably can spring for the upgraded suspension that makes that negligible.
    And since it replaces the stock system, it's much simpler solution - a secondary tank adds a lot of other moving parts that provide opportunity for failure.
    There is no requirement to keep the tank full at all times. When you're using all that capacity, you'll have plenty of other gear to balance it out. Plus, you don't need to have to full all the time when not otherwise loaded.
    Point is - it's possible to overstate the effects of having the fuel tank aligned to one side.
  2. Jan 25, 2013 at 9:55 PM
    #42
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    What material is the tank made of?
    Aluminum, stainless steel?
    **Edit** I just read the link.... it's aluminum.
  3. Jan 25, 2013 at 11:12 PM
    #43
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Honestly, that's a bad design if I do say so...
    First off, it'll interfear with most under armor.
    Second, you'd need to make a hell of an armor piece to protect it from puncture on an expo rig.
    Third, seems like it'd be in the way of any decent travel on the rear suspension as well?
    Fourth... mad taco lean, can be compensated for... but this could be fixed by using the pass side as well for a tank design...
    Fifth... dual tanks with switch is better for expo as you have less failure points... and costs about the same or less.
    Sixth... seems like air pockets with that much routing would be an issue.
    Seventh... I'd be VERY concerned with how close the y-pipe is getting to that thing and the heat it'll get exposed to there. Any vapor leaks.... .....
    Still, props for the concept, but no thanks.
  4. Jan 26, 2013 at 9:27 AM
    #44
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    Found this for you guys, you could put some nice bumpers on it and a roof top tent and would be good to go.
  5. Jan 26, 2013 at 9:36 AM
    #45
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    So with the added weight of the tank and higher fuel capacity you would be adding around 210lbs with full tank
  6. Jan 26, 2013 at 9:39 AM
    #46
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    I would be more concerned with the square edges. There is a reason the original tank isn't squared off like that. Likely to have more fatigue failures.
  7. Jan 26, 2013 at 9:40 AM
    #47
    07SpeedwaySport
    07SpeedwaySport Senior MoFo'ing Member
    Fairfax, VA
    06 DCSB TRD OR--now silver
    tint.
    But you need an extra fuel pump to pump the gas from the big tank to the little one...too much work.
  8. Jan 26, 2013 at 9:45 AM
    #48
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
  9. Jan 26, 2013 at 9:57 AM
    #49
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Its just a gas tank its not carrying nuclear waste....your way over thinking this....props to the OP I don't think a lot of people here understand the whole expo theme and hate on the product that was custom built...
  10. Jan 26, 2013 at 9:58 AM
    #50
    BEEFY_CHEESY_TACO
    BEEFY_CHEESY_TACO DUDE MAN BRO
    Hot Carl!!!
    Roy UT
    2010 TRD-Off Road TACO Extra value package
    Icon Ext Travel w/ Resi Front and rear, Dakar leaf springs, total chaos UCA's, color matched rear bumper, color matched satoshi grille with black chrome TRD emblem, konig countersteer offroads (black) w/ 285/75 Duratracs, sockmonkey Trailiens 3rd tail light cover, Tacomaworld.com sticker (made by me), debadged all around, Relentless Front Bumper, Sliders, Rear bumper, and bed bars with Yakima rack w/ full size spare, shovel, hi-lift
    Yeeeaaa..... a lot of expeditioners have their spare tire removed from the factory location which opens up a perfect place for a secondary fuel cell thats tucked up out of the way and wouldn't be hard to install. Much more practical than spending $2k on a tank then spending another large chunk on a custom skid to cover it. Thats a lot of F-in money.
  11. Jan 26, 2013 at 10:01 AM
    #51
    Gincoma
    Salt Lake City UT
    Ummmm....ok??
  12. Jan 26, 2013 at 10:02 AM
    #52
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Quite the contrary, my rig is being built toward expo. I just think this particular design, is not good. That's all.
    Also as for failure, dual tank gives you two points of failure for puncture, that's what I meant. In the middle of BFE... that's some nice reassurance to have a secondary tank unaffected should something happen.
  13. Jan 26, 2013 at 10:04 AM
    #53
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I'm wondering if there will be problems keeping the pickup submerged. The stock tank has a low spot so that gas will generally stay at the pickup if you are inclined.
    That tank looks very long and flat bottomed, like on an incline all the gas shifts to 1 end or the other?
  14. Jan 26, 2013 at 10:07 AM
    #54
    Gincoma
    Salt Lake City UT
    :notsure:
  15. Jan 26, 2013 at 10:15 AM
    #55
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    He wasn't responding to you initially
  16. Jan 26, 2013 at 10:20 AM
    #56
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    lol @ butthurt
    Neat tank but thats a lot of dollhairs!
  17. Jan 26, 2013 at 10:28 AM
    #57
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    So I have to ask since A) some of us are in Cali and B) the U.S., are these going to be D.O.T. approved? CARB legal?
  18. Jan 26, 2013 at 10:43 AM
    #58
    Gincoma
    Salt Lake City UT
    Exactly...
  19. Jan 26, 2013 at 10:52 AM
    #59
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    Purses swinging
  20. Jan 26, 2013 at 10:54 AM
    #60
    Gincoma
    Salt Lake City UT
    :rolleyes:
Thread Status:
