35 inch Tire Lift requirement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by w1cked, Jan 5, 2016.
  1. Jan 5, 2016 at 7:45 PM
    w1cked
    w1cked [OP] Member
    Jorge
    2008 Tacoma TRD
    Guys
    I have read a few of the post on lifts and tires and the more I read the more confused I get.
    I would like to get 35 installed under my 2nd Gen. I have reviewed the fabtech,tough country & rough country. There is a huge price difference between them all. I also see the uniball upper control arms that none of the lifts bring.
    Your input is greatly appreciated.
  2. Jan 5, 2016 at 8:22 PM
    Pigpen
    Dan
    Northwest Montana
    Technically, you can put in 35s without lifting at all. You just have to have enough backspace on your wheels and cut anything that rubs.
    My buddy has a 6" DB lift and still had to do the CMC and trim the wheel well.
    Lift as little or as much as you want, just expect to cut off pieces of your truck.
    I'll be sticking with 33s for awhile.
  3. Jan 5, 2016 at 8:35 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Yeah no need to stuff a worthless POS lift under the truck to fit 35s, just cut the metal that rubs once you mount the meats.
  4. Jan 5, 2016 at 9:47 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Cut all the things
