35 inch tires with 2 inch lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JimboTacoma, May 2, 2019.
  1. May 2, 2019 at 4:44 PM
    JimboTacoma
    JimboTacoma [OP] Member
    2017 Off Road
    I have a 2017 third gen on stock suspension right now. My question is do you guys think I'd be able to run 35's with out rubbing when I get bilstein 5100s 2 inch lift and a 1 inch toytec body lift?
  2. May 2, 2019 at 4:44 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Not a chance
  3. May 2, 2019 at 4:45 PM
    JimboTacoma
    2017 Off Road
    Probably right. Guess I'll go 33s
  4. May 2, 2019 at 4:48 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Lifts do not prevent rubbing. Any time the tire articulated upwards into the wheel well, there needs to be room for it. The areas where rubbing occur are fairly low down, so unless you run a massive drop-bracket lift, you will not be clear of the cab mount.
    Most require a CMC (cab mount chop) to run 33’s, so 35’s is a stretch.
    The only exception would be a truck with huge preload spacers, that is only ever driven on perfectly level ground, and never articulates the suspension.
  5. May 2, 2019 at 4:50 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Sounds Legit
    JCOOR likes this.
  6. May 2, 2019 at 4:54 PM
    JimboTacoma
    2017 Off Road
    I was going to do a CMC anyways with 33's, but in this case what would I have to do to run 35's?
  7. May 2, 2019 at 4:56 PM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    lots of cutting, trimming, heat-gunning, shaving, ect
  8. May 2, 2019 at 4:57 PM
    JimboTacoma
    2017 Off Road
    Got it. Might just go with the 33's and avoid that mess.
  9. May 2, 2019 at 4:58 PM
    Stocklocker
    17TRDORDCSBAT
    Honestly, I think your truck will thank you in the end. 35’s are hard on things designed to run 30’s from the factory.
    ripcalifornia likes this.
  10. May 2, 2019 at 4:59 PM
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    Honestly a pretty smart choice, your wallet will thank you
    Post a pic when you get it all setup!
    Junkhead and BassAckwards like this.
  11. May 2, 2019 at 4:59 PM
    Clearwater Bill
    Billy
    Largo Florida
    255 x 85 x16 or 80 x17 are 33s
    On OE wheels no lift or cutting is needed.
    And 35s would make you want to regear to regain driveability. Not a cheap proposition.
    EubeenHadd likes this.
  12. May 2, 2019 at 5:01 PM
    JimboTacoma
    2017 Off Road
    Got it! Thanks for the help/advice guys. I'll post a picture when she's all set up.
    and might have to chop a bitter fender but will be easy for the most part
  13. May 2, 2019 at 5:01 PM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    It’s possible. People have done it before.
    mcharfauros likes this.
  14. May 2, 2019 at 5:01 PM
    Stocklocker
    17TRDORDCSBAT
    But you have to want that look. Arguably a great performer, but the tall skinny doesn’t appeal to everyone.
    Dryfly24 and ripcalifornia like this.
  15. May 2, 2019 at 5:04 PM
    JimboTacoma
    2017 Off Road
    Was going to go with Nitto Trail Grappler M/T LT285/70R17 121Q E (10 Ply) BW
  16. May 2, 2019 at 5:09 PM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    I will say, my "skinnies" do not look significantly skinnier than the factory tires. I haven't done a true side-by-side on two mounted tires, but they're quite beefy compared to stock.
    Stocklocker[QUOTED] likes this.
  17. May 2, 2019 at 5:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    True, and it doesn't as function well in all situations.
    However, many folks just know they want 33s, because internet.
  18. May 2, 2019 at 5:18 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Not to mention gearing to counter the loss of power
    Edit: already been mentioned lol I can’t keep up with these new posts.
  19. May 2, 2019 at 5:19 PM
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    Fuckin make that shit happen bro:thumbsup:
    tcjacado, Mully and state48overland like this.
  20. May 2, 2019 at 5:21 PM
    QuicksandTaco
    Cody
    Oregon
    Why 10 ply?
