35 mudders? 18in tires. 3in lift or 5in lift
Discussion in 'Wheels & Tires' started by Reflex242, Apr 19, 2008.
  1. Apr 19, 2008 at 8:00 PM
    Reflex242
    Reflex242 [OP] Member
    Looking for lift kit and tires for and 08 tacoma. let me know what you got and price.
  2. Apr 23, 2008 at 9:37 AM
    Rosco75
    Rosco75 Well-Known Member
    Clavet Sk
    2001 Tacoma SR5 TRD
    3 inch skyjacker lift, k&n FIPK, 33inch procomp mud terrain tires
    If you want 35inch mudders on I would recomend that you go bigger with the lift or you gonna get rubbing for sure. 5 inch fo sho. Bigger lift is bigger job though. Much bigger. I did a 3 inch and it was relatively easy to install. I would be getting help if I went any bigger. 3 inch lift allowed me to install 33 inch mudders but they rub the front fenders.
  3. Dec 22, 2008 at 11:03 AM
    georgiajake91
    georgiajake91 Jake
    Georgia
    1997 Tacoma 4x4
    3" Body lift, 3" Suspension lift, 35" Terra Grapplers, Motometal 955 finished, Nerf Bars, 20% Window Tint, Camo Seat Covers, 2 12" Audiopipe Subwoofers, 4000 Watt Amp, Optima Battery, TSC Toolbox
    i would even maybe considering going 6 inches. i have a 6 inch lift with 35x12.50x16 and they rub the front frame!
  4. Dec 22, 2008 at 11:07 AM
    SilverSeven
    SilverSeven Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    you can fit 35s on 3" lift but you must trim a lot.
  5. Dec 22, 2008 at 2:09 PM
    FamouzStarz
    FamouzStarz The illest taco
    21 TRD PRO
    ICON Build and then some
    with 35's might as well go with a 6" lift
  6. Dec 23, 2008 at 9:54 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Any news on those body mounts?
  7. Dec 23, 2008 at 10:18 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    I think best bet is to go 6" if youre looking to put on 35" tires
    Its possible (at least on a 1st gen) to cram 35s under 4" of lift, but it takes a lot of sawzall
  8. Dec 23, 2008 at 10:57 AM
    SilverSeven
    Jordon
    South Jurzee
    talked to him. he wanted 600 for the mounts and to install my springs. springs are installed so i need to get a quote of just the mounts.
