35'' Tires Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by zacharypaul89, Jul 25, 2011.
  1. Jul 25, 2011 at 1:23 PM
    zacharypaul89
    zacharypaul89 [OP] Eat right, be fit, die anyway
    Zach
    Georgia
    2015 4WD DCSB
    I have a 2001 Tacoma PreRunner and I'm in the process of getting Bilstein 5100's on the front and AAL in the back to give my truck a 3'' lift. I'm wanting to get some 35's after I get it lifted, but I'm not too sure what the best tire size are and what wheel size to use. Also, do I need wheel spacers?
  2. Jul 25, 2011 at 1:24 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    With a 3" lift you will have to tub the fire wall to fit 35's
    You could do a spindle lift on top of your 3" and fit 35's
  3. Jul 25, 2011 at 1:25 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    35's on a 1st gen with 3" lift... better get a torch
  4. Jul 25, 2011 at 1:25 PM
    Tlook
    Tlook Well-Known Member
    my 33" 10.50s rub with a 3 in toytech lift. so youll need huge spacers and new studs lol
  5. Jul 25, 2011 at 1:31 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    spacers will make it rub worse:)
    how much work are you wanting to do to make these bad boys fit?
  6. Jul 25, 2011 at 1:33 PM
    JLee
    Jerry
    Benicia, CA
    Come on guys 5100's and a spindle lift will fit 35's no need to brake out the torch. Okay maybe the BFH
  7. Jul 25, 2011 at 1:36 PM
    Tlook
    not if there all the way out the fenders :) jk
  8. Jul 25, 2011 at 2:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    :facepalm:35s on a prerunner? why??
  9. Jul 25, 2011 at 3:07 PM
    zacharypaul89
    Zach
    Georgia
    2015 4WD DCSB
    That's why I asked. My buddy has some 35's for sale for a great deal, but it seems like that's a bit impractical for my small truck. What's a good tire size for me with a 3'' lift?
  10. Jul 25, 2011 at 3:08 PM
    97yota4wd
    Eric
    Mesa, AZ
    32s, 33s will rub but you can make them fit
  11. Jul 25, 2011 at 3:09 PM
    JLee
    Jerry
    Benicia, CA
    33/11.5's are a good size
  12. Jul 25, 2011 at 3:09 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    285/75/16
  13. Jul 25, 2011 at 3:10 PM
    zacharypaul89
    Zach
    Georgia
    2015 4WD DCSB
    Alright, thanks.
