35" tires rubbing on newly installed n-fab steps
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03TRDtacotrucker, Oct 27, 2010.
  1. Oct 27, 2010 at 10:29 AM
    03TRDtacotrucker
    03TRDtacotrucker [OP] No Road. No Problem.
    Alex
    North Richland Hills, TX
    03 SC double cab TRD SR5 4X4
    TRD supercharger, URD 7th injector, Map 3 ECU, 2.2 URD pulley, Doug Thorley headers, Bear River tru performance hi flow cat, 18" Magnaflow muffler, 6" fabtech lift, 33" Goodyear wrangler tires, the old all pro tube rear bumper, ARB front bumper with smitty built 8k winch, pro comp krawlers 87 series wheels, roof rack, 60" hi-lift jack, K&N intake, grey wire mod, front and rear diff breather mod, G2-performance 4.56 gears w/ royal purple oil, red top optima battery, PreRunner Tiregate with full size spare, Radflo front coilovers, Custom home made front skid plate, rear bilstein 5150 series shocks, Elite sliders w/o kick, Camburg UCA, mech grill with old school TOYOTA logo, ash tray removal Cobra CB radio w/ Firestik - List as of 1-17-18
    just bought and installed n-fab nerf bars on my double cab 03 tacoma and the drivers side tires rubs really bad anyone else have a similar problem and a quick fix? Going home with a block of wood and a sledge hammer to see what kind of fixing that will do.....picture below is with the wheel turned a little to the left.....
    [​IMG] do.[​IMG]
  2. Oct 27, 2010 at 10:31 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Do you have any pictures? I don't see how the tires can be rubbing on the steps?
  3. Oct 27, 2010 at 10:36 AM
    03TRDtacotrucker
    Alex
    at work now will have to take some when i get home and show yall what im talking bout.... passenger side is fine its just the drivers side that rubs, only on turns at just the right angle which happens to be the angle used to make the turns around in the parking garage at work
  4. Oct 27, 2010 at 12:12 PM
    pittim
    pittim mittip backwards
    Pink slider.
    uhhhh
    a sawzall
  5. Oct 27, 2010 at 9:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    :smack:a grinder might work too...:eek:
  6. Oct 27, 2010 at 9:42 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    what kind of lift are you running to fit 35" tires?
  7. Oct 28, 2010 at 6:05 AM
    03TRDtacotrucker
    Alex
    forgot to take pics of my truck waiting to get my bumper back from the powder coating shop before i post new pics......got the problem fixed last night using a rigged up spacer pic below, its not as sturdy as before but still works great it sure as hell better than it was....used extra long bolts and a couple nuts spent $5.00 at lowes in parts.....im using a 6" fabtech lift btw
