35" Tires...
Discussion in 'Wheels & Tires' started by arrrghhh, Aug 6, 2010.
  1. Aug 6, 2010 at 4:43 PM
    arrrghhh
    arrrghhh [OP] Well-Known Member
    Denver, CO
    09 TRD Off-Road
    Custom Front Bumper, Smittybilt XRC-8, 3" OME lift, 33" Falken A/T tires
    So I have an '09 that's stock. I'd like to replace my stock factory BFG's, and I was really hoping to go up to a 35" tire for ground clearance mainly.
    Obviously I'll have to get a lift... Will a 3" lift be enough? I'd like to avoid a ton of cutting, but of course I also don't want the tires rubbing.
    So what do you guys think? Looks like the biggest I can go is 265/75/16 on the stock suspension/wheels... I don't really want to get new wheels if I don't have to, although it would be nice I guess to have two sets of tires. Most of my driving is unfortunately on pavement, so perhaps that would be a benefit to get a separate set of wheels&tires...
    If I can't run a 35" tire on a 3" lift, how much lift would I need? Looks like a 33" tire is 285/75, can I run those on the stock suspension with minimal cutting?
    Thanks guys!
  2. Aug 6, 2010 at 4:49 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Fabtech Lift on top of 3 inch body lift. 34s trail grapplers on 18inch eagle alloys. KRFab Rear bumper, BHLM with HIDs, TRD seat covers, Hood scoop, N fab tire carrier, black valence, TRD intake, 40s Flowmasters, Foglight mod, best for last and thats my 4.56 gears, and much more too come.
    a 3inch lift you can go with 285s If you have stock wheels tho that are 16s your going to rub on the UCAs so your gonna need spacers. If you wanna fit 35s, your going to have to alot of cutting, and like you said you dont wanna cut alot. I had to trim a little and I have a 6inch lift. Some fellas here have a 3inch lift tho with 35s. I had a 3inch lift with 285 with 16s with spidertrax spacers. Others will chime in. A friend of mine also has a 3inch lift and has 285 bfg km2s but was rubbing on the UCAs like crazy so I sold him my spidertrax spacers when I got the 6inch lift. So imo your gonna have to cut alottt to fit 35s.
  3. Aug 6, 2010 at 4:52 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    4" lift would be fine with some trimming. U will actually have to cut part of the frame and then re-enforce it. This project will require cutting and welding.
  4. Aug 6, 2010 at 4:52 PM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    Yea, I think 6" lift is too big (personal preference, your truck looks good, just don't want mine that big :D)
    Hrm I heard it's a really bad idea to run spacers. Discount claimed they can't work on vehicles with them on... shortens the stud?
    Maybe I'll go with the 3" lift and run 33" tires. Thanks for the quick response!
    Any others?
    06Bluez, just saw your response. So a 4" lift will fit 35" tires... but I have to cut part of the frame?!? That doesn't sound like anything I want to get into!!
  5. Aug 6, 2010 at 4:55 PM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    Ah yea, I forgot about that... so tires, lift, and gears... Jeez, I'm lookin at 3k it sounds like :eek:! Thanks for the reminder! Looks like I may go with 33's in the short term haha!
  6. Aug 6, 2010 at 4:56 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    It's not necessarily the height of the vehicle that is the problem. It is the minimal amount of room inside the fender (width-wise). U need perfect backspacing on ur wheels and u will need to cut part of the frame and trim parts of the front and rear of the fender. 4" lift would be perfect but difficult to get. Camburg makes spindles for a 2wd that will achieve 4" of lift. With 4x4 u are limited.
  7. Aug 6, 2010 at 6:05 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    3" w/ 35s
    3" w/ 33s
    gears for 35s are a want and not a need. also the cut is to the body mount, not the frame.
  8. Aug 6, 2010 at 6:08 PM
    beef TACO no rice
    beef TACO no rice Well-Known Member
    Orlando, FL
    07 taco single cab
    hodge, what lift is that?
  9. Aug 6, 2010 at 6:09 PM
    jhodge83
    SC
    17 XLT Sport
    3" Walker Evans COs up front and 3" AP leaf pack out back
  10. Aug 6, 2010 at 6:10 PM
    beef TACO no rice
    Orlando, FL
    07 taco single cab
    i bought my truck and it already had a spacer up front to level, but im not sure how big it is.. wondering if its only a 2" level... would like to get the clearance youve got.. looks like your sitting higher then mine..
    hm
  11. Aug 6, 2010 at 6:11 PM
    jhodge83
    SC
    17 XLT Sport
    measure the thickness of the spacer and it is pretty much double that number
  12. Aug 6, 2010 at 6:13 PM
    jhodge83
    SC
    17 XLT Sport
    i've been driving on mine since april w/ no issues, including wheeling twice...and i still get better MPGs than if i regeared. no need to attempt to do 0-60 in 5 seconds in a truck w/ 35s.
  13. Aug 6, 2010 at 6:19 PM
    beef TACO no rice
    Orlando, FL
    07 taco single cab
    x2
  14. Aug 6, 2010 at 6:29 PM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    Me likey. So I can do 35" tires with a 3" lift, I just have to do some trimming on the body mount? I just worry about causing damage to the truck by a) putting on tires that rub or b) trimming too much. New to modding trucks, thanks for the tips guys. Keep 'em comin :D
  15. Aug 6, 2010 at 6:31 PM
    jhodge83
    SC
    17 XLT Sport
    backspacing of the wheels will also dictate the amount of trimming. you will have to chop the body mount for sure though....i'm not sure how much you'll have to cut off the front of the inner fenders/front bumper area though as i dont have that issue.
  16. Aug 6, 2010 at 6:37 PM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    Did you have to do any trimming in the front? I assume I would need to get new wheels to get more backspacing...
    Is this because of first gear takeoffs at lights causing extra stress from the weight/size of the tires? I don't see how that would apply when the vehicle is in motion... Unless I'm just missing something. Which is entirely possible.
  17. Aug 6, 2010 at 6:38 PM
    jhodge83
    SC
    17 XLT Sport
    "offroad" front bumper=no trimming in the front
  18. Aug 6, 2010 at 6:39 PM
    arrrghhh
    Denver, CO
    09 TRD Off-Road
    Ah. I want to do one of those eventually as well. Damn, it's like I need to do all these mods to my truck at once!!
  19. Aug 6, 2010 at 6:42 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    I just chopped my cab mount and I have a few inches to spare with 33's now. I'm pretty sure I could get 35's in there with 3" of lift.
  20. Dec 15, 2010 at 3:37 PM
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    I want to do this also. Jhodge where did you get your cab mount chop?
