35k miles spark plugs swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomatrd15, May 10, 2018.
  1. May 10, 2018 at 3:48 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I went 60K before changing my originals. No change in gas mileage.
  2. May 10, 2018 at 3:49 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Betcha if you clean your throttle body you’ll notice a difference! Should check it out. Easy and cheap.
  3. May 10, 2018 at 3:52 PM
    ARB1977
    North Texas
    Did that too, even mass airflow sensor. Blew out my AFE prodry airfilter as well. Still get 400 miles per tank.
  4. May 10, 2018 at 3:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You’re not gonna get any better than that. That’s a whole lotta miles
    MolonLabeTaco likes this.
  5. May 10, 2018 at 3:58 PM
    ARB1977
    North Texas
    I’m stock with crappy SR5 prerunnner suspension. I did go to 265/70R16’s with black FJ Cruiser wheels. A little wider and slightly taller tire.
  6. May 10, 2018 at 8:08 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I get ~250. :angrygirl:
  7. May 10, 2018 at 8:16 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I get about 280 with slightly heavier tires and wheels. 400 would be freakin sweet.
  8. May 11, 2018 at 8:49 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    adding more weight, more rotational weight or adding wind resistance
    will give you worse MPG
  9. May 11, 2018 at 8:59 AM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Most of Toyotas maintenance schedule seems a bit ambitious, 15k diff changes if you tow or 30k if you don't. My previous trucks I changed at 100k. I kept to the maintenance schedules but really didn't see the need.
    Spark plugs I changed at 30 and 60k. I don't think they needed it. But you usually notice better response from your truck and slightly better gas mileage for a little while. Is super easy and cheap for someone mechanically inclined to do it. Not so much for someone who isn't and is probably a cash cow for the dealerships...
    Blockhead, 1Shifter, BillsSR5 and 2 others like this.
  10. May 11, 2018 at 9:08 AM
    knottyrope
    Knotty
    Bahstun
    never did diff fluid, xfer case, tranny fluid, PS fluid, blinker fluid or winter air in any vehicle I have owned
    never had a failure from it either
    All this maintenance is more money for dealer to make later
    Tacomatrd15[OP] likes this.
  11. May 11, 2018 at 11:00 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  12. May 11, 2018 at 1:46 PM
    Dane
    Dane Well-Known Member
    Dane
    Houston, TX
    07 PreRunner SR5 TRD Off Road
    I did mine first time at around 42k miles. Denso plugs looked ok, NKG plugs were little bit more down. At that time I put in 6 Denso plugs purchased on dealership and last weekend when i pulled them out after about 35k miles they looked just fine with gaps all within spec.
    This time I ordered Denso plugs online. definitely i would recommended not to use NKG.
  13. May 11, 2018 at 2:49 PM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    Not use NGK and use the Denso plugs all around? Do they come pre gapped?
  14. May 11, 2018 at 10:46 PM
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    Did mine for the first time last weekend at 58k. I also changed the PCV valve and cleaned the catch can system I put on. I can tell a bit of a difference in idle. The old plugs looked fine with no real difference between the two that I saw. My old gaps were a little more than others though, most were around 0.060.
  15. May 12, 2018 at 3:06 AM
    #35
    Tacomatrd15
    Tacomatrd15 [OP] Member
    They're all pretty much pre gapped, but it's always best to double check before install...
  16. May 12, 2018 at 3:13 AM
    #36
    Tacomatrd15
    That's what I figured since the gaps on the Denso spark plugs weren't too far off compared to the NGK.... Clerk suggested I put that I put the NGK iridium plugs.... But for some reason, the maintenance manual does not recommend the use of iridium spark plugs on the 4.0L V6 engine, only on the 2.7L V4..... Definitely will be using Denso spark plugs at the next change
  17. May 12, 2018 at 3:14 AM
    #37
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I’ve changed plugs 3 times on my truck with Denso plugs that I bought from the dealer. They were never ‘pre-gapped’ correctly...I always check them.
  18. May 12, 2018 at 3:19 AM
    #38
    Blockhead
    Pittsburgh, Pa.
    I’m at 172,000 miles now and have learned that most of the maintenance intervals suggested are overkill but to each his own.
    I now do plugs and diffs at 50,000 miles and even then they still look good. Never have changed tranny fluid and never will...:crapstorm:
    knottyrope likes this.
  19. May 12, 2018 at 3:19 AM
    #39
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I change mine after about 35k and honestly they look like they could go longer. I have a bad back so a lot of the maintenance stuff that I could do I don't. There's a good garage nearby with a very competent mechanic that does good work for a reasonable price. I take my truck to him for stuff I can't do, I rarely use the dealer.
  20. May 12, 2018 at 7:49 AM
    #40
    badger
    badger Well-Known Member
    07 SR5
    Gapped at the minimum spec, these plugs will be eroded out of spec in 30,000 miles. That's why the interval is 30,000 miles. Threads like this are why I would never buy a vehicle with more than 50,000 miles unless every detail of the maintenance was meticulously recorded with receipts. The idea that "I'm fine because nothing broke" just gives me an ice cream headache.
    EatSleepTacos likes this.
