35s/34s minimal lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UnderfundedTaco, Mar 27, 2019.
  1. Mar 28, 2019 at 8:49 AM
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    agree w/ all above - 315/75/16 w/ 3" lift, 1" body, CMC, and pinch weld mod - and I still rub my wheel wells and when I'm fully locked left to right. At this point, I'm tack welding spacers to my steering stop. Instead of beating the crap out of the wheel well - I would rather tube what needs to be chopped. Beating works until you crack a seam and water starts coming in - with that YMMV.
  2. Mar 28, 2019 at 9:23 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I have 315/75/16s 2” lift. Well maybe closer to 2 1/4”. I do rub the fire wall/wheel well if off-roading hard.
    ImMrCrash likes this.
  3. Mar 28, 2019 at 10:34 AM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    Who is running a cab relocate, vs just a maximum cab chop? Wanting to do my research before buying a set of 35's and new wheels to experiment with.
    Which brand/model tires, and which wheels (or what width and offset/backspace specs) please?
  4. Mar 28, 2019 at 11:42 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    3.5 inches of backspace works better with 35’s. 4.5 inches of backspace will rub the frame.
    I just chopped my cab mount to the max. I don’t rub at all but I also have SPC UCA’s that let me push the wheel forward in the wheel well to keep it away from the cab mount.
  5. Mar 28, 2019 at 12:08 PM
    racebug68
    Travis
    Chandler, AZ
    how much backspace you need to not rub the frame also depends on the width of the rim also, i.e. how wide the section width of the tire actually is, along with what actual tires you have and the specs. a 315/75 can vary dramatically between brands. the BFG KO2s for example are way wider than the Cooper ST/MAXX in the same size.
    mynewtoy[QUOTED] likes this.
  6. Mar 28, 2019 at 12:21 PM
    racebug68
    Travis
    Chandler, AZ
    also, it should be noted, Height can vary dramatically between tires as well, besides the reduction that wear introduces.
    From a theoretical perspective, the less backspace the rim has (meaning it is offset further to the outside, the more you will need to chop out of the cab mount and fender and pinch weld. Because with less backspace the wheel will arc when turning, especially at the outer edge of the tread, instead of pivot. To me, perfection would come if the tire would just barely rub the frame at full lock with mild articulation, and rub hard on the tire side lugs only at full stuff/lock. The frame and the tire can handle it, and would be aired down significantly in any contact situation anyway. Frame can be smoothed and nothing is tearing or "catching" on the lugs of the tire. This would minimize the cab chop, fender and pinch weld interference. And of course, maxing out the caster and using SPC UCA to push the wheel as far forward as it will go. Spot welding a washer or shim onto the steering lock stop to reduce turning radius a tiny amount is OK in my opinion as well.
    That all being said, who has done 315's with a 4.5" backspace wheel? or a 4.75" backspace wheel with a .75" bora spacer would be 4.0" effective... what width rim, 8"? What tire exactly? and what suspension lift (I could care less about a body lift)? Has anyone ever mounted 315's on a 7" rim?
    Thanks in advance.
  7. Mar 28, 2019 at 1:27 PM
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
    Very much agreed and excellent point. I currently have Fierce Attitude M/T 305/70R16 and the tread width at its absolute max is ~11” while the new tires being the exact same brand and type but in a 315/75R16 measure about 10” tread width.
  8. Mar 30, 2019 at 2:28 AM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    Lift height doesn’t play a factor in how big of a tire you can fit assuming you actually wheel and aren’t a pavement pounder. Unless you have huge bump stop spacers, when stuffed your wheel will be stuffed the same lifted vs stock hight.
    For 35s trim the fenders, chop off as much of the cab mount as possible and take a bfh to the firewall.
    Alexely999 likes this.
  9. Mar 31, 2019 at 12:36 PM
    Petit1989
    Petit1989 Well-Known Member
    2015 Tacoma trd
    Bilstein 5100s
    I’d like to run them if the taco had a v8
  10. Mar 31, 2019 at 12:46 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    35s king shocks tc UCA
  11. Mar 31, 2019 at 1:36 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Crap sorry I don’t have the wheel specs.... craigslist.
    I know that they are 16x8 ultrawheels
  12. Mar 31, 2019 at 2:21 PM
    Pigpen
    Dan
    Northwest Montana
    That's why you regear
  13. Feb 12, 2023 at 11:00 AM
    Danglee916
    Danglee916 Active Member
    2014 regular cab 4x4
