35's how you get em to fit
Discussion in 'Wheels & Tires' started by sully1981, Mar 27, 2013.
  1. Mar 27, 2013 at 1:21 PM
    sully1981
    sully1981 [OP] Well-Known Member
    Costa Mesa, CA
    05 SPORT 4x4
    Solo XLT 19" 4WD Kit and 4-Link w/32" cycled, Caged, 41 gallon fuel cell, 2.5 bypass and coil-overs up front, 3.0 bypass and 2.5 coil-over in rear, PCI radio w/intercom and 5 headsets, 50" KC Gravity LED, 20" GG-lighting LED bar, Method Hole Wheels, Currie 9", URD CAI, 37x12.5x17 BAJA T/A, PRP Seats, Glassworks 6.5" front, Fiberwerx Bedsides.
    Debating on moving up to 35's. what did u do to get them to fit. Any rubbing? I've chopped body mount back a little already. Like the look better with 35's but don't want to spend the money if they're gonna drive me nuts and create problems
  2. Mar 27, 2013 at 1:29 PM
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Smallkine lost... Atleast i get 4wd
    2010 Tacoma TRD SPORT Kauai Built
    Stockish bahahaha
    I got 35's nitto mud grapplers... lots of tread. I believe if they are 35x10.5 u shouldn't rub it depends on the lift you have. mine is 35x12.5 and they rub pretty bad on a pro comp mx6 6in lift, im cranking my coilovers to the max in a few weeks to try to minimize the rubbing but i know there really isn't much i can do unless i add an additional spacer or body lift (which im not going to do because i dont like body lifts at all.
    hope this helps a little
    Oh and i didn't cut anything. the previous owner cut a little in the front side of the front finders but not much. i just let em rub.....
    and it only rubs when im taking sharp turns in reverse or making sharp turns and breaking.
  3. Mar 27, 2013 at 1:30 PM
    mjp2
    mjp2 Living vicariously though myself Moderator
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    If you're not comfortable taking a sawzall to lots of stuff, it's not worth the headache.
    Every truck fits differently (lift, UCAs, alignment, random tweaks in the build, etc.) so it's unique to your setup. It's simply a matter of mounting them and keeping a saw and large hammer in the truck to take care of issues as they come up.
  4. Mar 27, 2013 at 1:31 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    You will want to do quite a bit of clearancing, the cab mount is a good start.... pinch weld will need to be beaten back, and you may need to beat the firewall back a bit. Looks like you have a front bumper, so you wont have to worry about much up there. Fiberglass fenders aren't a bad idea either.
  5. Mar 27, 2013 at 1:34 PM
    Large
    Large Red
    Avatar pic looks like he's using front glass
  6. Mar 27, 2013 at 1:37 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    smashed pinch weld, chopped cab mount. still rubs a little. probably need more caster tho
  7. Mar 27, 2013 at 1:40 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Nice find, just looked at his gallery, he may be in pretty good shape for 35's.
  8. Mar 27, 2013 at 1:46 PM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC beadlocks and 35's, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, USA SPEC iPod Adapter, Rockford Fosgate 10" sub with custom box and amp. Andres' devil horn emblem, 50" D4 curved LED bar, HID converted hella 4000s.
    dont forget! you must re-gear too! ;)
  9. Mar 27, 2013 at 1:47 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    It's a good idea, but it isn't an absolute requirement...
  10. Mar 27, 2013 at 1:52 PM
    WailuaTaco808
    Phil
    Stockish bahahaha
    agreed i haven't re-geared... the 4.0 is pretty good at pulling 35's but you will feel a big difference thats for sure
  11. Mar 27, 2013 at 1:56 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Theres a few of these threads out there now.
  12. Mar 30, 2013 at 4:26 AM
    DevL
    DevL Well-Known Member
    Then dont get 35's without a drop bracket lift.
