35's on 3" lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jr114, Oct 14, 2010.
  1. Oct 14, 2010 at 10:37 AM
    jr114
    jr114 [OP] Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Guys who are running 35's on a 3" lift...did you guys re gear or are you using the stock gears. I'm thinking that since I'm gonna be buying new tires soon, i might as well do the body mount chop at the same time and throw a 35 on there.
  2. Oct 14, 2010 at 10:39 AM
    uberlols
    uberlols I can fit 35"s
    Jake
    Va beach
    6" of lift
    I fit 35's no problem with a 4" lift and no body chopping for me. I went wide for wheels so that helped some. I am using stock gears on my automatic v6. More than enough power. Aluminum wheels help. Steel wheels are just so damn heavy.
  3. Oct 14, 2010 at 10:49 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I believe I was first or one of the first on here running a 3" lift and 35's, and still have the stock 3.73's in my truck. I can make up for them with my 6 speed quite well. I will, however, be regearing to 4.10 or maybe 4.56's once I can afford to do front and rear lockers and gears all at the same time. There is quite a bit of trimming to be done to clear the 35's just so you know.
  4. Oct 14, 2010 at 10:51 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    35s here on stock gears...
  5. Oct 14, 2010 at 10:56 AM
    jr114
    Jon
    SoCal
    Truck
    ill look through your guys photos..but if you dont mind, would you post a few pictures of the trimming that needs to be done? thank you. I dont mind cutting it up. is it true that you have to trim 3/4 off the fender well?
  6. Oct 14, 2010 at 11:01 AM
    RelentlessFab
    Eric
    Sparks, NV
    yeah man check out my build for pics. I did an inital trim, then trimmed some more, then almost ripped both my front fender flares off and finally got some help by a skilled friend of mine to clearance 2" out of all 4 of my flares and weld them to look like stock flares. We then hacked 2" out of all 4 of the sheetmetal fenders to install the new flares. The only place they rub any more is at full compression in the top of the fenderwell. To eliminate that some bumpstops are needed since dealing with it any other way would require hacking out the fenderwell/engine bay and re-plating it which is a bit more work then I want to hassle with.
  7. Oct 14, 2010 at 11:15 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    just go with glass upfront! :D
  8. Oct 14, 2010 at 11:32 AM
    RelentlessFab
    Eric
    Sparks, NV
    He'll still rub the fenderwell under compression and 'glass typically doesnt line up nearly as good as factory sheet metal. I thought about doing 'glass but cost and looks kept me away. JMO
  9. Oct 14, 2010 at 11:34 AM
    Chachie
    Justin
    Nor Cal
    Good point. Im wanting to go to 33's. if anyone has some 33x12.5r17's they want to trade for some 315/70r17's before buying a set, id be down.
