35x10.50x17 Kenda Klever R/T Kr601 Thread *SKINNY 35s*
Discussion in 'Wheels & Tires' started by socalexpeditions, Mar 13, 2020.
  1. Oct 11, 2021 at 1:50 PM
    #301
    socalexpeditions
    socalexpeditions [OP] IG: @socalexpeditions
    I drive like a grandma so maybe thats why I get good tread life with tires lol
    Navigator1[QUOTED] likes this.
  2. Oct 21, 2021 at 8:29 PM
    #302
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    So I ordered the Kenda and got them mounted today and the installer said they took a lot of weight. I haven’t had a run on the freeway yet but they seemed fine up to 50 mph. Has anyone else had any trouble?
  3. Oct 21, 2021 at 8:52 PM
    #303
    Maxx
    Maxx Well-Known Member
    I noticed a lot weights were needed to balance mine but no vibrations up to 100MPH during high speed passing. They are actually really smooth.
    Navigator1 likes this.
  4. Oct 22, 2021 at 8:30 AM
    #304
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Mine are fine
  5. Oct 22, 2021 at 9:10 AM
    #305
    awwbugman
    awwbugman Well-Known Member
    Kings/Deavers/SPCs 35x10.5 Kendas, LRA FuelTank, WARN Zeon10s SDHQ mount, Switch Pro, LightForce rock lights, reverse light & Lightbar, Baja Design Squadron Pro fogs, CaliRaised Sliders, RLD Canopy, Odyssey group 31, Dometic CFX3-55IM
    Mine took a decent amount of weight, but no vibrations at all and are actually really smooth and quiet. As I think I mentioned before, they are definitely a soft tire, the softer sidewall than my previous cooper is a noticeable difference. IIRC someone from Kenda at Overland Expo did mention re-balancing after putting some miles on them, is not a bad idea.
  6. Oct 22, 2021 at 9:56 AM
    #306
    socalexpeditions
    Both my sets took a lot of weight but balanced out just fine
  7. Oct 23, 2021 at 10:02 AM
    #307
    Navigator1
    Spokane WA
    18 TRDORDCLBCEMENT
    Thanks guys. I took a quick freeway trip yesterday and they seemed fine so hopefully they stay that way. These do ride nice. I’m running a few psi lower than my SL rated Goodyear’s and they are nice and plush. They do have a little more wander going down the road, to be expected with this aggressive of a tread pattern, but no where near as bad as my Duratracs.
    Falldownhard likes this.
  8. Oct 23, 2021 at 11:55 AM
    #308
    Maxx
    They get better after a couple thousand miles once they wear down some and become more uniform in the tread.
  9. Oct 28, 2021 at 7:18 PM
    #309
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    About 20k miles into mine so far, and they are still doing phenomenal. Have been through almost every hard trail in moab, and the toughest trails here in the pnw. Starting to get a little chunking from burnouts on the rocks and some street drifting, but way less chunking than all of the other tires I've had in the past. Super soft rubber which helps. Still balanced out perfect, besides the broken tpms sensors floating around in the tire lol. Ready for winter to plow some snow
    95tojo, jubei, TimberTiger and 5 others like this.
  10. Oct 28, 2021 at 8:52 PM
    #310
    Navigator1
    Spokane WA
    18 TRDORDCLBCEMENT
    I hope so. I’ve had them in a couple highway trips now and there’s some steering wheel wobble. It’s minimal but it’s there for sure. Maybe if it keeps up I’ll see if Kenda wants to pay for another run at balancing them. I’m still looking forward to the performance in the snow and dirt though.
  11. Nov 28, 2021 at 1:20 PM
    #311
    awwbugman
    ditto?
  12. Dec 13, 2021 at 9:10 PM
    #312
    awwbugman
    Tires have been awesome so far and I'm still a big fan. Love this size. Few pics for those in the market.
  13. Dec 27, 2021 at 8:47 PM
    #313
    captrussia253
    captrussia253 IG: ruslan.khinotskiy
    PNW
    2017 Tundra CrewMax 2016 Toyota 4Runner
    Specs of your wheels?
    Im running 35x12.50r17 now but wouldn’t mind running these in the winter.
  14. Dec 30, 2021 at 8:31 AM
    #314
    dantheman1540
    dantheman1540 Well-Known Member
    Dan
    Sugar Loaf Mountain
    2011 Access cab 6 speed 4x4
    Camburg UCAs, Bilstien 5100s/886, AAL, Falken AT3W, Allpro Bumper.
    Does anyone know where to find these in stock under $250 each? Seems like they have dried up
  15. Jan 7, 2022 at 10:32 AM
    #315
    LongDistanceTaco
    LongDistanceTaco Well-Known Member
    Geoff
    California
    I know this is a kenda thread, but anyone tried out the Toyo oc at3 in the 35x11.5/17? They measure out to a 34.4 and weigh 63lbs in a c load. Tempting since the kendas are 68 freaking lbs
    Dirk Diggler and captrussia253 like this.
  16. Jan 7, 2022 at 10:49 AM
    #316
    captrussia253
    PNW
    They also make a Maxxis all terrain in 35x11.50r17
    Wulf and LongDistanceTaco like this.
  17. Jan 8, 2022 at 7:43 PM
    #317
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Wider width (same as the 285/xx-17 tires in the Toyo AT3 range), so there would likely be more rubbing.
    There's looks to be quite a bit of mfg variation in tire weights at that size. My Kendas measured 65 lbs on my bathroom scale. Saving 2 lbs wouldn't be a motivation to switch, especially given the AT3's less aggressive tread pattern. The AT3 has shallower tread depth as well (17/32" vs 19/32").
  18. Jan 8, 2022 at 9:14 PM
    #318
    LongDistanceTaco
    Geoff
    California
    I happened to nab a set locally. I didn’t realize how awful tire buying is right now, everything is on backorder or ridiculously priced.
    @Glenn_R measured the kendas at a section width of 11.25 and the toyos are a 11.4in based on the spec sheet. I'll weigh and measure them once I get them mounted.
  19. Jan 8, 2022 at 9:52 PM
    #319
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Yeah the Kendas are on 4-6 week national backorder according to some sites.
    It's odd @Glenn_R thought his measurements were true to the specs on Kenda's site, but Kenda's site lists section width as 10.47" when mounted on a 17x8.5" wheel (same as his) for P/N 601015 :confused:
  20. Jan 10, 2022 at 4:06 PM
    #320
    c_walters
    c_walters Well-Known Member
    Mooresville, Nc
    2019 TRD Sport 6MT MGM
    man that thing sits perfect! What’s your lift height end up being? I really need to stay out of tire threads, I wanna ditch my brand new 265/70’s for these
    captrussia253 likes this.
