35x10.50x17 Kenda Klever R/T Kr601 Thread *SKINNY 35s*
Discussion in 'Wheels & Tires' started by socalexpeditions, Mar 13, 2020.
  1. Aug 4, 2020 at 10:43 PM
    #81
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    I got 5 for $1,100.. Should be here sometime next week.
    I have a schedule for a CMC at a local shop and then I'll toss em on. I might not even need the CMC but figured it wouldn't hurt.
    rlx02 and Rockefelluh like this.
  2. Aug 4, 2020 at 11:32 PM
    #82
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    yeah i didnt get a 5th. my goodyear MTR 35x12.5 has never been used. so didnt feel like getting another one. as a spare it will do what i need it too.
    gravyboat[QUOTED] likes this.
  3. Aug 5, 2020 at 8:07 AM
    #83
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    It needs a CMC :D
  4. Aug 5, 2020 at 9:08 AM
    #84
    Wackyhacky
    Wackyhacky A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    So is the consensus w/ those running these that snow performance is good to excellent? Appreciate any feedback.
    Also @socalexpeditions , what weight are your wheels?
  5. Aug 5, 2020 at 9:16 AM
    #85
    socalexpeditions
    socalexpeditions [OP] IG: @socalexpeditions
    So far so good but I live in Socal, so can’t offer too much snow experience.
    My FN’s are 21lbs
    Wackyhacky[QUOTED] likes this.
  6. Aug 11, 2020 at 7:26 PM
    #86
    amadougrand
    amadougrand Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    The 35x10.5 is being mounted as we speak. Little worried about the 8 ply, but for the price worth a shot.
    question in airing down. Running true bead locks with a little weight up front, but only spare in back. What pressure front vs rear. Wife wants smooth. I think the previous pressures listed seem a little high so I am planning to experiment, but was hoping for a starting point.
  7. Aug 11, 2020 at 9:45 PM
    #87
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    if you’re running headlock why worried? Wouldn’t be concerned about the 8 ply.
  8. Aug 11, 2020 at 11:40 PM
    #88
    socalexpeditions
    I’m at 40 hot for long trips and 36 normal. Thats just what I chalked at. You might be in the 34-35 psi range.
  9. Aug 12, 2020 at 5:16 AM
    #89
    Chadr7858
    Chad
    Colorado
    I noticed that they start hooking up well below 15 psi. I normally run mine 12 front 10 rear and my truck is a heavy pig
  10. Aug 12, 2020 at 6:12 AM
    #90
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Ok. 12 and 10 seems closer to a starting point. I do most of my wheeling within 30-40 miles of my house with minimal pavement between house and gravel so the pressures I am looking for are a combo of ease and comfort desires. Comfort on these boney roads and ease to drop and air back up to get home. Should have it home Friday (with luck) from the shop and will give comments after a weekend of breaking in new gears and testing rubber.
  11. Aug 12, 2020 at 6:23 AM
    #91
    Chadr7858
    Chad
    Colorado
    They’ve gotten me up a severe rated trail or two so far.
  12. Aug 12, 2020 at 8:47 AM
    #92
    socalexpeditions
    Oh offroad I run 10 psi no beadlocks.
    Rockefelluh likes this.
  13. Aug 15, 2020 at 6:51 AM
    #93
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    So far so good! Put about 1k on them and they still ride nice and pretty quiet. These things balance out great also!
    next to the 285s
  14. Aug 15, 2020 at 10:03 AM
    #94
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    It looks like Your flares are still uncut, how easy were these to fit? A lot of the guys with these tires are 3rd gens, so its nice to see a set on a 2nd. What are your wheels specs as well? These are supposed to be a little easier to fit, but they're still 35s, just wondering how much work it was getting these on a 2nd gen.
  15. Aug 15, 2020 at 10:37 AM
    #95
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    @TommyG has a Maxtrac spindle lift, which moves the wheel 4" lower in the wheelwell. His clearance will be a lot more than yours.
    TommyG likes this.
  16. Aug 15, 2020 at 10:44 AM
    #96
    Jojee117
    Joe
    MT
    Dang, that's too bad. I thought that lift looked a little high, good looking truck though.
    TommyG likes this.
  17. Aug 16, 2020 at 7:35 AM
    #97
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    I did the usual CMC, pinch weld beating, and a little trimming. Didn’t have to do any major cutting. As mentioned I have the 4” Maxtrac spindles so I get a little more clearance. I run my coil overs with no preload set at 0 lift so the truck rides amazing. I can go up another 3” if I need more clearance but I don’t want it that high and only slightly rub when I fully bottom the front out hard against the bump stops. Wheel specs are 17x8.5 0 offset 4.75 backspace.
    Jojee117[QUOTED] and CCWTaco like this.
  18. Aug 16, 2020 at 10:53 PM
    #98
    socalexpeditions
    You will still want to cut flares on a 2nd gen
    Jojee117[QUOTED] likes this.
  19. Aug 17, 2020 at 6:27 AM
    #99
    Chadr7858
    Chad
    Colorado
    Mine have taken me places
  20. Aug 17, 2020 at 6:49 PM
    #100
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    How much lift are you running? Cmc? And do you still rub anywhere?
    socalexpeditions[OP] likes this.
