361 miles on ODO broken lug stud WTH??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Halloween, Dec 7, 2022.
  1. Dec 7, 2022 at 1:21 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    We are to assume that you didn't run them down with an impact wrench followed by your check of the torque wrench? Technically you shouldn't be using the torque wrench to tighten, only to check, but that is the way most people do it.
  2. Dec 7, 2022 at 1:21 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    My guess is discount ruined them. I see them use the torque wrench but not without the impact first. My guess is they zipped it too tight and then they go around the circle with the torque wrench for that satisfying click (even though they’re already tighter than the torque spec).
    that’s just a guess, but definitely what I’ve seen at some Discounts. So I would be questioning them, and not necessarily the parts just falling apart for no reason.
  3. Dec 7, 2022 at 1:22 PM
    Halloween
    Halloween [OP] Well-Known Member
    Toyotas a plenty
    Here’s what I do and always do. I hand thread them to start. Then run them in with an impact just to save time but do not torque… just “cinch”. Than torque to spec.
    SR-71A and boston23 like this.
  4. Dec 7, 2022 at 1:24 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Well thankfully you have another 5 lugs for safety. :thumbsup:
    83 ft/lb…damn. My trailer torque spec is more than double that. :rofl:
    G8R_Taco, hiPSI, wilcam47 and 3 others like this.
  5. Dec 7, 2022 at 1:24 PM
    Halloween
    Toyotas a plenty
    That’s a possibility …. I use the same place every time and the manager is top notch and is on top of it…. . What’s done is done. I’m
    Just aggravated. Easy fix but just aggravating
  6. Dec 7, 2022 at 1:28 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Yeah, isn’t the 6th one the spare lug?
    ColoradoTJ[QUOTED] likes this.
  7. Dec 7, 2022 at 1:31 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Probably just been extremely unlucky. Sucks tho.
    Halloween[OP] likes this.
  8. Dec 7, 2022 at 1:32 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I have always been a 90 ftlb guy when it comes to torquing lug nuts. That equates to one solid "ugga" with my trusty 4 sided lug wrench. :)
    But OP, I gotta believe yours must have seen excessive force sometime in its life. Those things rarely fail in my experience.
    JFriday1 and Rusty66 like this.
  9. Dec 7, 2022 at 1:38 PM
    Halloween
    Toyotas a plenty
    They’ve never failed in my lifetime. This is a first. Brand new truck. 361 miles. My typical luck
  10. Dec 7, 2022 at 1:43 PM
    duckytw
    duckytw Well-Known Member
    They could have also over torqued them at the port. Especially with all the strike talk recently, wouldn't surprise me if the higher ups said swap the wheels and get it out of here asap. My last Tacoma had the pink and blue chalk on the lugnuts, this time nothing.
  11. Dec 7, 2022 at 1:45 PM
    Halloween
    Toyotas a plenty
    Maybe. Just sucks. I’ll get it fixed soon
  12. Dec 7, 2022 at 1:52 PM
    eurowner
    eurowner Duke Sky
    Scoty
    The nuts didn't fail.
    Sharpish, wilcam47 and MR E30 like this.
  13. Dec 7, 2022 at 1:53 PM
    eurowner
    eurowner Duke Sky
    Scoty
    My wife's TJ is 100Ft/lbs!
  14. Dec 7, 2022 at 2:00 PM
    Dirt McGirk
    Dirt McGirk Well-Known Member
    Phoenix, AZ
    19 TRD OR 4X4
    I will say that discount paid for me to get all of my studs replaced and ordered me new lug nuts due to them over tightening.
    I rarely have discount actually put my wheels on because I’m normally there with a new set of wheels and I just put them on myself. This time I was lazy and they ruined a $250 set of lug nuts and cross thread or broke at least one stud on each wheel. They also put a huge scratch in the barrel of one of my Volks that they also paid to have re finished.
    nothing against discount, normally have great experiences but that tech really messed up.
    MR E30 and Halloween[OP] like this.
  15. Dec 7, 2022 at 2:02 PM
    #35
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Somebody cranked on them at some point.
    I lost a lug nut between the dealer and home after the very first free service. All of the lug nuts on that wheel were loose to the point of easily moving them two fingers. Lucky I didn’t lose it and kill me or another unlucky person driving next to me.
    The other wheels were attached with an impact, no question. I had to use a 1/2 inch drive, 36” breaker with a cheater pipe to get them loose to retorque them. Lucky I didn’t end up in your situation myself.
    That was the last time my truck went to the dealer for anything but one warranty job and a recall and even that I checked their work in the service drive with odd looks coming from every direction. This is the kind of thing that happens, Just because you do things to right pretty much guarantees someone else won’t and ruin something. I’d be making a few phone calls in your shoes.
  16. Dec 7, 2022 at 2:07 PM
    #36
    ColoradoTJ
    Colorado
    Absolutely. Spare isn’t needed all the way to the parts store and back home. :D
    wilcam47 likes this.
  17. Dec 7, 2022 at 2:08 PM
    #37
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sometimes, but not always.
    I will do a test click on a lug before I take the wheel off.
    But usually, I set my wrench to 70 ft/lbs. You’ll know if the wrench doesn’t click before it gets “tight”.
    The lower ball joint mount bolts are 118 ft/lbs. So there’s a “test bolt” for 83 ft/lbs.
    If you really want make sure it’s going to click.
  18. Dec 7, 2022 at 2:13 PM
    #38
    soggyBottom
    soggyBottom Well-Known Member
    Tire shops are the worst. I got new tires recently. They broke one of the tire sensors and did replace it but without tech stream, I couldn't get tire pressure working.
    On top of that, they couldn't be bothered to clock the tires using the orange/yellow dots.
    Junkhead and HondaGM like this.
  19. Dec 7, 2022 at 2:17 PM
    #39
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    yep...i see that ever now and then...find out they had tires put on,test the sensors and there good...just not learned
  20. Dec 7, 2022 at 2:19 PM
    #40
    TnShooter
    Deogee
    STOCK
    Yeah, I watched a guy at the local shop use a torque wrench.
    He torqued the wheel off the ground. He was a big guy, he basically spun the tire with one hand and used the other to “slam” the wrench forward. The wrench definitely moved past the point of “click”.
    And yes, it was on my truck.
    I was not too concerned, because I never used a torque wrench on anything until I joined this site. :rofl:
    Let’s just say, I am/was guilty of cranking them down. At least they were tight, so I didn’t complain.
    ColoradoTJ and Halloween[OP] like this.
