361 miles on ODO broken lug stud WTH??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Halloween, Dec 7, 2022.
  1. Dec 7, 2022 at 2:49 PM
    #41
    Halloween
    Halloween [OP] Well-Known Member
    Toyotas a plenty
    How were you able to prove they did it…. Happenwhile you were there? It’s been a few weeks since I’ve been there.
  2. Dec 7, 2022 at 2:52 PM
    #42
    Halloween
    Toyotas a plenty
    Wow!!!! Yeah I’ll be calling
  3. Dec 7, 2022 at 2:56 PM
    #43
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Ask if dealer would warranty it. Probably not, but never know
    Halloween[OP] likes this.
  4. Dec 7, 2022 at 2:57 PM
    #44
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Any PBlaster or Fluid Film overspray on the threads?
    What brand of torque wrench? Some will not click if you reef on it too slowly. I broke a stud that way with a Neiko.
  5. Dec 7, 2022 at 3:01 PM
    #45
    Halloween
    Toyotas a plenty
    It’s actually a snap on. Had it for a long time. It’s been serviced too
    no pb blaster overspray that I know of. Why? Curious.
  6. Dec 7, 2022 at 3:03 PM
    #46
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Lubricants on the threads increase the preload at any given torque value. Same 83 ft-lb with lube stretches the bolt more than dry threads.
    Kodiak420 and ColoradoTJ like this.
  7. Dec 7, 2022 at 3:04 PM
    #47
    Halloween
    Toyotas a plenty
    Makes sense
  8. Dec 7, 2022 at 3:22 PM
    #48
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    You never know with things of this nature. Could have been a bad lot of wheel studs, improperly heat treated even.
  9. Dec 7, 2022 at 3:28 PM
    #49
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    too much lubrication
    OP lubed the stud too much
    you never lube a stub that much
    noob mistake, soft studs bust too easily with too much lube
    TexasWhiteIce likes this.
  10. Dec 7, 2022 at 3:34 PM
    #50
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    were the threads wet at all... rain/anti siege, loctite, etc?
  11. Dec 7, 2022 at 3:39 PM
    #51
    Halloween
    Toyotas a plenty
    I didn’t lube them at all. Never do. I do use anti seize around the hubcentric area but that’s it.
    eurowner likes this.
  12. Dec 7, 2022 at 3:39 PM
    #52
    Halloween
    Toyotas a plenty
    No they were dry.
  13. Dec 7, 2022 at 3:59 PM
    #53
    Arcticdc5
    Arcticdc5 Well-Known Member
    Had a respected repair shop repair a slow leak tire. The next time I pulled the wheels off to do a tire rotation, (2) of the lugs were cross threaded and snapped. Last time I took my vehicle to that shop.
  14. Dec 7, 2022 at 4:02 PM
    #54
    Halloween
    Toyotas a plenty
    Ordered new studs. Will throw them on next week. It’s not my daily so it can sit
    rtzx9r likes this.
  15. Dec 7, 2022 at 4:02 PM
    #55
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Have to “like” for the Eagle Talon reference. Mine wasn’t turbo, but I had a red with black roof 93 Eagle Talon, and the studs on it were broken as well. 2 of the 4 wheels had broken studs when I bought it in 1996. Ah the memories…. The automatic seat belts worked for a bit but then broke, the RPMs would randomly drop below 500rpm when idle where it almost dies. But but but, being in high school at the time it was a chick magnet!!! The backseat was small but it served its purpose……
  16. Dec 7, 2022 at 4:15 PM
    #56
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I had the same thing happen to be the other day and I didn't even have an impact to run it down with. Hand brake was on and I was torquing the wheel in the air to 83ft-lbs. i have a digital torque wrench and watched the torque peak at 72ft-lbs then start rapidly decreasing. Repositioned and barely tugged it and heard a snap of the stud. I have a 21 Tacoma. I suspect a bad batch of studs. I replaced it myself because i'm a mechanic and didn't feel the dealership would cover it since they didn't take off the wheels even but it's worth a shot. They may have a bulletin on it and cover it for you. A new nut and stud cost me 17.73 at the local Toyota dealer.
  17. Dec 7, 2022 at 4:28 PM
    #57
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2017 Tacoma TRD PRO
    Only takes one over torque to weaken a stud. Could have been a Friday build at the factory or maybe a tire needed to be changed upon delivery to the dealer.
  18. Dec 7, 2022 at 5:16 PM
    #58
    Halloween
    Toyotas a plenty
    Yeah it’s easy job just sucks. I ordered the studs. Will get it done soon. I hope there’s not a bad batch. I have horrible luck lol
  19. Dec 7, 2022 at 5:16 PM
    #59
    Halloween
    Toyotas a plenty
    That’s my luck.
  20. Dec 7, 2022 at 5:24 PM
    #60
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    This can happen if your truck has too much torque. See exhibit A.
    G8R_Taco and ColoradoTJ like this.
