36K miles for a serpentine belt?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kenneth Noisewater, Mar 3, 2025.
  1. Mar 3, 2025 at 5:09 PM
    Kenneth Noisewater
    Kenneth Noisewater [OP] New Member
    2019 Tacoma TRD Offroad
    My 2019 TRD has about 35,800 miles. Started getting an intermittent squeal from the serpentine belt (or pulleys?). That seems low to have to replace the belt and it's intermittent, so tricky to diagnose. I see there has been a TSB, is it worth calling the dealership (I'm out of 3/36K warranty), or should I just start with a new belt since it's relatively cheap?
  2. Mar 3, 2025 at 5:15 PM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I wouldn't take it anywhere, but that's me. Even though I doubt it's the belt it's not a bad idea to replace it even if it's just to rule it out.
    I've never had a Toyota truck squeal because of a belt but I guess it can happen. On my trucks it's always been the idler pulleys. While you have the belt off spin the pulleys to see if the bearings sound and feel ok. Replacing those is a cheap and easy job.
  3. Mar 3, 2025 at 5:21 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Agreed, it's relatively inexpensive a and simple to replace.
  4. Mar 3, 2025 at 5:22 PM
    MGMDesertTaco
    The oem dayco belt is nice quality. I just replaced mine after 9 years, 64k miles. Pulley's were still fine.
  5. Mar 3, 2025 at 5:22 PM
    MGMDesertTaco
  6. Mar 3, 2025 at 5:23 PM
    MGMDesertTaco
  7. Mar 3, 2025 at 5:26 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I've always replaced my serpentine belt as soon as it starts squealing...
    shakerhood likes this.
  8. Mar 3, 2025 at 5:31 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Mine makes no noise at all but will probably swap it out soon as it's 8 years old, gonna swap out the original battery at the same time too.
  9. Mar 3, 2025 at 6:01 PM
    PennSilverTaco
    Charlie
    How many miles do you have?
    shakerhood[QUOTED] likes this.
  10. Mar 3, 2025 at 7:15 PM
    shakerhood
    Southern Ohio
    Closing in on 60K, will be needing spark plugs at that point too.
  11. Mar 3, 2025 at 8:35 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Replaced my first one around that mileage. And just again at like 80k along with an idler pulley.
  12. Mar 3, 2025 at 8:37 PM
    Bishop84
    Bishop84 Well-Known Member
    When I was daily gravel road driving, I was changing my belt every 2 years.
  13. Mar 4, 2025 at 12:08 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I'm getting to 85k and it still looks fine
  14. Mar 4, 2025 at 4:18 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    This exactly, Dirt roads etc really cut down on the life of belts.
  15. Mar 4, 2025 at 7:12 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Belts harden with age. My Crown Vic needed one after 30k miles- but that was over 10 years lol.
    It's too cheap to not at least try before bothering to diag anything.
  16. Mar 4, 2025 at 8:22 AM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    If it has iridium plugs they are good to 120k
  17. Mar 4, 2025 at 8:35 AM
    shakerhood
    Southern Ohio
    The Owners Manual calls for 60k changes, but you are probably right that they last awhile longer.
  18. Mar 4, 2025 at 10:58 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    58k on mine, belt just started chirping, so im replacing it today.
  19. Mar 18, 2025 at 8:47 PM
    Kenneth Noisewater
    Changed it out today. Youtube videos are super helpful (as usual). Definitely would recommend taking off skid plate to facilitate working from both top/bottom as well as extra light. Helpful to have an extra hand if available when locking out the tensioner.
    I have a feeling this belt just got dry/hard due to age vs. mileage. Same happened to first set of tires...they dry rotted before wearing out.
    Squeal/chirp all gone! Good DIY project to save a couple hundred bucks.
