$375 to install Billstein 5100's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coloradotacoma, Nov 15, 2011.
  1. Nov 15, 2011 at 5:49 PM
    Randy Y
    Randy Y Active Member
    2010 4x4,4 cyl. 5 speed
    Just had mine done for 125 with allighment
  2. Nov 15, 2011 at 6:13 PM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    Look in the Colorado bs thread, or Colorado trading post. Itll help you out alot
  3. Nov 15, 2011 at 6:17 PM
    D13
    D13 Well-Known Member
    D
    Moving all the time
    08 TRD-OR
    Tinted windows, Plasti-dipped emblems (black), white 2011 grill w plasti derped white toyota emblem, Weathertech dontfits; Clarion HU, Hertz-165 Coax, Alpine 500w mono to 8" JL 3w3, Wet Okeles, CBI sliders, Eibach/5100's @0.85 in front, Dakar leaves and OME shocks in rear, Leer topper.
    wow.. i got quoted 375 for my entire lift.
    since i posted... anyone anywhere between SD and St. Paul got the tools and willing to help with the install?
  4. Nov 15, 2011 at 6:20 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    That right there should be a signal to not do any more business with them unless you have nowhere else to go.
  5. Nov 15, 2011 at 7:47 PM
    coloradotacoma
    coloradotacoma [OP] Well-Known Member
    The writing is on the wall. Tomorrow I wil be contacting another Dealership. Part of the whole process is the convience of not needing to go to two shops and spend time twice to have the work done. I wil pay more for that convience. However not $200 more.
  6. Nov 15, 2011 at 8:00 PM
    KenLyns
    Belly of the Beast
    One thing I've learned over the years: a dealer or large repair shop cannot be trusted to do multiple jobs in one session. They will always forget something. Unless there's a big labor saving (the proverbial timing belt and water pump), go to separate shops or at least make separate appointments.
  7. Nov 15, 2011 at 8:16 PM
    Slapps74
    Slapps74 Well-Known Member
    Thornton
    2014 FJC
    Bone stock for now!
    Op. I will do it for 100.00. I have lifted several of the members trucks some of which are posting on this thread. Contact any of them and they will tell you about the work I do. Sean266, Hoyle, blacktacoma23, Geotaco, TRDBandit, are a few of them. Let me know.
  8. Nov 15, 2011 at 8:18 PM
    coloradotacoma
    Excellent advice. I will probaby end up going that route. I always try to be as greedy with my time as I can. I will most likely let them do the TSB and have my usual shop do the shocks
  9. Nov 15, 2011 at 8:19 PM
    coloradotacoma
    That sounds great. I appreciate the help. I will send you my phone #
  10. Nov 16, 2011 at 12:00 AM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    If you want to come down to Pueblo on a Sunday around noon I'll help ya put em on for free. It's super easy to do and we should be done in a couple hours.
  11. Nov 16, 2011 at 12:05 AM
    Fistgar
    Fistgar Off-Road Limo
    Chance
    Denver, Colorado
    2010 TRD Sport LB 4x4 MGM
    Satoshi grille, painted engine cover, 20% tint on windows, OME 3" Lift, TSB in the rear with ToyTec AAL, , tinted tails, Hella 500's. 1" body lift
    I did mine in front of my apartment ;) Never done it before but there were some great write-ups on this site that helped walk me through it. I did piss off my neighbors a lil bit using my impact gun on the spring compressor that I rented from Autozone... noisy :) You will still need to have your front end aligned which is the only bummer. I thought that when Toyota did the TSB on the rears they had to perform an alignment the front end anyways? (they did on mine). Might save you a few bucks if you install the billy's first and then have the TSB on the rear done.
  12. Nov 16, 2011 at 12:10 AM
    Manwithoutaplan
    ID
    just get some tools and jacks. DO yourself not very hard.
  13. Nov 16, 2011 at 6:14 AM
    Slapps74
    Thornton
    2014 FJC
    Bone stock for now!
    I would like to see you do this in 30 min.
  14. Nov 16, 2011 at 8:55 AM
    Manwithoutaplan
    ID
    x2
  15. Nov 16, 2011 at 9:04 AM
    #35
    neoflex
    neoflex Well-Known Member
    If they're doing the TSB the alignment should be on them as that is part of the TSB anyway. At any rate they are still way over priced. I had a local mechanic do mine both front and rear and he charged me $110. I than drove my truck from his shop to the dealer for them to do the alignment, which was $60 for a four wheel alignment. So in total I was in $170.
    I did the four wheel alignment only because it cost the same to do all four corners as just the front. I did stop at a Firestone by the house and they quoted me $395 without the alignment. After choking I said no thanks.
  16. Nov 16, 2011 at 9:12 AM
    #36
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    I've hired 4 lawyers in my lifetime...none of which charged anything near $109/hour!
  17. Nov 16, 2011 at 9:21 AM
    #37
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Lawyers aren't dealer service departments. $109/hr is actually a little lower than the average rate around here. Alot depends on geography.
  18. Nov 16, 2011 at 9:26 AM
    #38
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Oh, I know that is about right (unfortunately). Regardless, it always startles the hell out of me when I think of it.
  19. Nov 16, 2011 at 9:26 AM
    #39
    Slapps74
    Thornton
    2014 FJC
    Bone stock for now!
    A lot of people bash the dealer for what they charge, and you all seem to be able to do it your self. But, how many of you have a 100k alignment rack, a building or the proper tools to do the work? I'm sure I have more tools than most of you (about 15k) and I buy more all the time. The truth is just because you can figure it it doesn't make you a mechanic and your post count is not a reflection of your automotive intelligence.
  20. Nov 16, 2011 at 12:00 PM
    #40
    coloradotacoma
    Dealership won't budge on their price. I am letting them do the TSB and that will be the last time I am there. (I am only letting them do that much because they already ordered the parts.) My usual shop is doing the work for $120, 4 wheel alignment included. Thanks to those of you who offered to do the work for/with me. If I wasn't a chef and working like nuts right now I would take advantage of your more than generous offers. Hopefully I will have a chance to get together with you guys in the near future.
