3d printed Under seat amp rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacorgeron, May 14, 2024.
  1. May 14, 2024 at 2:32 AM
    tacorgeron
    tacorgeron [OP] Member
    Jessie
    2017 White tacoma sr5
    projector headlights and fog lights, 6" rough country lift, exhaust, 35x12.5x20 toyo mt's.
    I have the Pioneer 6600 nex in the dash, dual l7t kicker 10's, Kicker ks components front and rear, kicker key 50W x4 and dual Kicker key 500W x1
    SUMOTNK, Gmarch49 and Rednecktacoma22 like this.
  2. May 14, 2024 at 7:44 AM
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    This is kickass! I just velcroed the my sub amp (kicker 400) under the driver seat. Does this all fit without seat jackers? I also want to add a kicker key under the passenger in the future to have an amp for all the door speakers. I'd love to see more pictures of the rest of the install that you have.
  3. May 14, 2024 at 5:16 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    hopefully you've added some 12v fans under the cover on the one side? amplifiers use the aluminum chassis as the heatsink for creating the power. if there's not enough airflow around the amp, it can easily overheat. generally, one needs at least 2" around an amp to allow the heat to properly dissipate. if that's not possible, forced air is definitely required.
  4. May 14, 2024 at 5:54 PM
    tacorgeron
    Jessie
    It will be fine. Alot of amp racks that are built into boxes also cover the sides. some even cover them up with plexiglass. This design has about a half inch in between the amps. Also shield them from the under seat vent. In the summer time, when it's really hot, AC will be blowing under the seat.
