3d scanner
Discussion in 'General Automotive' started by soggyBottom, Sep 7, 2022.
  1. Mar 14, 2023 at 1:56 PM
    BamBeds
    BamBeds Founder/Designer Vendor
    Ben
    Central Coast, CA
    '09 Access Cab TRD OR
    Bilstien 8100, 8112, Snugtop w/ windoors
    I just bought and am promptly returning the $10,000 peel 3.
    I found the tracking to be far worse than the $1000 einstar. I played with all sorts of exposure and resolution settings on the Peel 3 and it just couldn't hold its tracking for whole vehicle size parts without the use of tracking dots (which I refuse to spend my time applying and removing)
    To add to my bad experience with the peel 3, I had to contact 2 different customer support numbers and have a rep remote into my computer just to get the software installed because their website was broken and wouldn't let me download it as intended. Then while using the software I found it to be fairly buggy especially when undoing part of a scan or resetting the scan.
    To anyone reading this, try the Einstar before going for a 10k+ scanner. I think you'll be impressed. This is not a paid promotion in any way. I just really think the einstar has some insane value and sadly I haven't found any domestic supplier that comes close in terms of value.
    Why is a Chinese company doing so much better than a domestic company?
    Perhaps because they taken it upon themselves to track and scan the faces of a billion people from every street corner :*(
  2. Mar 15, 2023 at 10:07 AM
    Firn
    Firn Well-Known Member
    White OR
    Creality just announced their "Ferret" scanner. https://www.creality.com/products/cr-scan-ferret-3d-scanner
    $350 !!
    Time will tell if its any good, looks like a lot of folks found their other cheap scanner, the Lizard, to be pretty bad. I believe the issues there were on the software side.
    Still, for $300 (preorder), I may get one. That is cheap enough for a hobbyist like me to struggle through some difficulties.
    BamBeds and soggyBottom[OP] like this.
  3. Mar 15, 2023 at 4:12 PM
    Talon2006
    Talon2006 Well-Known Member Vendor
    I am curious how this, and the scanner posted above would compare to my go scan spark…
  4. Mar 16, 2023 at 3:58 AM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    After owning a creality scanner and lots of printers, I have the impression that their focus is to print things you scan. This could change in the future but I doubt the new one will do large items like the spark can.
  5. Jan 20, 2024 at 11:24 AM
    Pinatacoma
    Pinatacoma Well-Known Member
    Vancouver Island, BC
    2020 ACOR
    Reviving a bit of an older thread...
    There are a few parts of the 3rd gen that I'd love to have 3D scanned models to work from to design various things. I've been using Solidworks professionally for a number of years, and am pretty good at taking rough models/scans and creating high quality dimensionally accurate 3D models from them.
    Good 3D scanners are still out of my budget for how often I'd use them, but I can offer to trade some CAD work for high quality scans... Anyone interested?
  6. Jan 20, 2024 at 1:11 PM
    soggyBottom
    I really like the idea of making a community effort in scanning Tacoma parts. What parts do you want scanned?
    Pinatacoma[QUOTED] likes this.
  7. Jan 20, 2024 at 2:10 PM
    Pinatacoma
    2020 ACOR
    Three things immediately come to mind:
    1. The left hand dash panel that houses switches - specifically the back of it with all of the clips and complex outside shape
    2. Under the hood, right hand side (driver's perspective) where the on board air compressor usually gets mounted in models that have this space empty. I'm interested in the mounting locations of this plate and the clearance around it
    3. The trim around the head unit, similar to what was at the beginning of this post, but more detail and both sides
    EDIT:
    4. The side mirror housing, all around to where it mounts on the truck. I'll assume these can be mirrored for left and right. ;)
  8. Jan 20, 2024 at 7:20 PM
    soggyBottom
    I have a cheap 3d scanner. For some things it works great but for others it can be a real pain to get just right. Can you post a picture and circle the area under the hood you're referring to?
  9. Jan 20, 2024 at 9:04 PM
    Pinatacoma
    2020 ACOR
    Passenger side between the air filter box and the firewall. I'd like to figure out the 3D dimensions of the three mounting studs here, and some of the threaded holes on the inner fender wall.
  10. Jan 22, 2024 at 5:41 PM
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
