3gen issues with crawl control after lift and ecgs
Discussion in 'Technical Chat' started by 17tacotrdor, Oct 17, 2017.
  1. Oct 17, 2017 at 9:22 PM
    17tacotrdor
    17tacotrdor [OP] Well-Known Member
    SOCAL
    2019 TACO
    I just did the ecgs bushing on my 17 trd off-road. After doing so I tested the 4wd. 4wd hi works fine, goes into gear no problem. 4lo seems to have a weird idle and when I put it into crawl control the truck starts to have issues. When releasing my foot from the brake the truck moves just as it should but it makes hesitation and sounds like something is slipping and the brake pedal flutters even though I’m not touching it.
    Took it to the dealer for insight, they are worthless. Basically told me I’m not allowed to talk to the techs, I need to drop it off and they will create a word order and hope they fix it.
    The truck has bilstien 6112s in the front and 5160s in the rear. Suspension was installed by 4wheel parts. Since the lift was installed, the truck has only been in 2wd, and 4 hi. Prior to the lift I used crawl control with no issues.
    Would anyone have insight on what the problem could be?
    Thanks
  2. Oct 17, 2017 at 9:28 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Only thing I could think would cause an issue since the bushing doesn't mess with any systems, is that you somehow knocked one of the speed sensors loose, see if 4lo and atrac does the same thing
  3. Oct 17, 2017 at 9:28 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    That's how the crawl control works. Makes a lot of noise and sounds like stuff is binding. Just adjust your crawl control settings
  4. Oct 17, 2017 at 9:29 PM
    mosquitoTaco
    Anthony
    SouthTennessee
    Crawl control wouldn't be pulsating unless it was using the brakes if a wheel was slipping
  5. Oct 17, 2017 at 9:32 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    Or using a really low setting if going too fast for that setting. Truck flutters if going to fast that setting. Not sure if that makes any sense
  6. Oct 17, 2017 at 9:35 PM
    17tacotrdor
    SOCAL
    2019 TACO
    I get what you mean, I was only using crawl control in a low setting. If I’m not applying gas how could it be too low of a setting?
    90yota[QUOTED] likes this.
  7. Oct 17, 2017 at 9:36 PM
    17tacotrdor
    SOCAL
    2019 TACO
    I will try that in the morning and report back. Thanks for the suggestion
    mosquitoTaco[QUOTED] likes this.
  8. Oct 17, 2017 at 9:40 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    When on the lowest setting, or crawl control in general I'm never on the gas and if not on a hill my crawl control typically makes the symptoms you said
  9. Oct 17, 2017 at 9:42 PM
    17tacotrdor
    SOCAL
    2019 TACO
    So when you use it on a higher setting on flat ground, you experience no issues? I’ll try that and see if it works
  10. Oct 17, 2017 at 9:44 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    Right, the pulsating is part of the crawl control. I adjust to how fast the vehicle is going.
  11. Oct 17, 2017 at 9:46 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    If turned all the way to the right it will pulsate a lot, just play with the knob and find that happy setting.
  12. Oct 17, 2017 at 9:46 PM
    17tacotrdor
    SOCAL
    2019 TACO
    When I put it on the lowest setting it’s from a dead stop. I don’t put my foot on the gas or the brake. Any idea what that setting would be for?
  13. Oct 17, 2017 at 9:48 PM
    HardShellTacoma
    HardShellTacoma Well-Known Member
    Eric
    Colorado
    2017 DCSB OR
    The 5 CC settings are just speed control: 1-5 mph.
    90yota likes this.
  14. Oct 17, 2017 at 9:48 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    Honestly it all depends on your terrain
  15. Oct 17, 2017 at 10:11 PM
    17tacotrdor
    SOCAL
    2019 TACO
    Ok I’ll try the different settings and report back. Thanks
  16. Oct 17, 2017 at 10:14 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    If you put your truck in crawl control, on lowest speed, on flat ground, it sounds like Godzilla is trying to rip out of the engine compartment and the truck will surge and shake like crazy. Crawl Control, in my experience, is only smooth and behaved when you actually need it (all four wheels stuck on a steep hill etc).
  17. Sep 17, 2018 at 12:36 PM
    moto nordlichhaus
    moto nordlichhaus Flying Mammal
    2017 DCLB OR
    This is good to know. Lifted my truck last week and tried out the CC & MTS modes for the first time this morning. Heard the Godzilla sounds when attempting to use CC on level, gravel-covered dirt (when I didn't actually need it).
    Stocklocker[QUOTED] likes this.
  18. Sep 20, 2018 at 8:41 AM
    eddyizm
    eddyizm Well-Known Member
    2018 TRD OR DCSB 4x4 Cement
    This started to freak me out! I tried this on a moderately steep decline and had massive clank sounds as it crawled down for a few yards.
  19. Nov 6, 2018 at 7:23 PM
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    So then bumping this thread... technically a lift won’t mess with the computer (MTS or CC) or 4wd modes correct? OP did you ever figure it out?
