3in lift problems,any one less notice this
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kdawwwg, Apr 3, 2010.
  1. Apr 3, 2010 at 12:58 PM
    Kdawwwg
    Kdawwwg [OP] Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    ok guys digin the info i get,wishin i would have found this site prior to all my work ,but truck is close to finished with only two more possible problems.
    #1 new light racing upper arms will sag much lower then the stock ones .when front wheels are off ground, the rubber boot on the ball joint hits the spring,the c.v. boot hits the lower arm , so as the tire spins its now wearing the boot out.granted this only happens when you go over whoops. seems like limiting straps might be in order,but have never seen em for a taco.
    #2if suspention takes a very little bump in a corner,i here a very faint alarm coming from under dash. it well last for about 3 sec ,with no trac warning lights,but some thing ive never heard before .............
    if ya cant understand ,how about. cv boot wearing on lower arm,going over whoops..........
    an truck makes a buzzer noise going over bumps while in a corner .
    cant break it down any more then that ...........
    here are those pics with the cv boot hiten an ball joint hiten
    1st pic is normal ride height,the outhers is front wheel lifted
    also it does have a diff drop,its a fat bob spacer, on sport springs
    taia
  2. Apr 3, 2010 at 1:03 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    for some reason that was incredibly hard to read.... in fact, I dont even remember one period. My head hurts :(
  3. Apr 3, 2010 at 1:08 PM
    rick
    rick `
    x2 and welcome to TacomaWorld Kdaw
  4. Apr 3, 2010 at 1:57 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    FOR #2
    Some trucks at 3"+ lifts are having problems with the traction control getting confused and going 'on' during sharp turns, speed bumps, etc. You'll need Toyota to recalibrate your ride height to get rid of this. There is a thread on here somewhere, anyone?
    So now that you have your lift, when you take a sharp turn and the body rolls like 1", your traction control perceives a 4" body roll (3" lift + 1" body roll) so it freaks out and tries to save your ass. It loves you but it's blind so you have to tell it you're a few inches taller now.
  5. Apr 3, 2010 at 2:12 PM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    So now that you have your lift, when you take a sharp turn and the body rolls like 1", your traction control perceives a 4" body roll (3" lift + 1" body roll) so it freaks out and tries to save your ass. It loves you but it's blind so you have to tell it you're a few inches taller now.[/quote]
    I agree. If you search the threads you'll find what you need on the alarm problem. But as for your CV hitting the lower control arm when the wheel is off the deck, somethings not right. What kind of lift do you have? Do you have a diff drop? There is no way your LR UCA ball join should touch your spring when the wheel is off the deck. The spindle won't allow that much travel unless your using some kind of crazy coil. Take a couple pics and let us see what your talking about. Somethings not right...
  6. Apr 3, 2010 at 3:03 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Idk you've got something going on there, my front shocks at full extension wouldn't allow for that, i have a 3 inch procomp lift and when i lift the truck in the air my cv's don't come close to the lower control arm. I have LR UCA's on the way, i'll see what happens when i put those on.
  7. Apr 3, 2010 at 3:07 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Agreed. My head hurts as well :( :confused:
  8. Apr 3, 2010 at 3:09 PM
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    I would say check out your LCR that looks like when your lifting the truck off the ground the LRC is sagging so much that it is causing everything connected to it (UCA, STEERING) to sag like crazy and just rub everywhere. When i lifted my truck it seemed like my stock UCA sagged like crazy but it wasnt that bad....thatt would be the first thing i would check
  9. Apr 3, 2010 at 3:13 PM
    Brunes
    Brunes abides.
    Rotorhead
    I'm not going to lie- 3inch lift does not = jumping and hard driving over whooops. You need a real long travel set up fro that kinda stuff. You built up parts of the suspension- the UCAs, the shocks, the springs- but others- the LCAs, the hardware, the spindles, and the CVs- are not any beefier and will not take that abuse for too long at all.
    Good luck with figuring it out!!
  10. Apr 3, 2010 at 3:14 PM
    KalamaKid
    I think you might have installed your UCA's on the wrong side. Seen it before. Take a pic of the top of the UCA
  11. Apr 3, 2010 at 3:18 PM
    KalamaKid
    well comparing your pics to my truck your UCA's are on right... i don't know what to tell you man, mine don't rub at all with the front off the ground.
  12. Apr 3, 2010 at 3:45 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    NVD , where you hear this ? I am wondering if this might help me in my sensitive VSC issue ,
    OZ
  13. Apr 3, 2010 at 3:58 PM
    nvdeserted
    Reno, NV
  14. Apr 3, 2010 at 4:01 PM
    OZ-T
    Peter North
    British Columbia
  15. Apr 3, 2010 at 4:11 PM
    Kdawwwg
    Ken
    Draper,Utah
  16. Apr 3, 2010 at 4:16 PM
    Kdawwwg
    Ken
    Draper,Utah
    only thing i can think of is the fat bob spacer mounts the shock a little lower then the outher spacers out there,they did this to not limit travel.
    so now the arm is bottoming out before the shock is
    stock arm would bind out way sooner the these light racing arms
