3in lift questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03 Tacoma TRD, Sep 21, 2011.
  1. Sep 21, 2011 at 9:01 AM
    03 Tacoma TRD
    03 Tacoma TRD [OP] Well-Known Member
    Travis
    Charlotte
    03 TRD Sr5 4x4
    MY BUILD http://www.tacomaworld.com/forum/1st-gen-builds/165602-03-toyota-tacoma-build.html
    Im looking to get this lift kit liftkit_0143146e24d5743651b7fc7016f07e4561c5de71.jpg
    from wheelers. would i need to buy extended brake lines? and possibly extend the 4wd? Please let me know
    Thanks
  2. Sep 21, 2011 at 9:07 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You will not need extended brake lines. And what exactly do you mean by "extend the 4wd"? :notsure:
    also there a alot better kits out there, for not much more $
  3. Sep 21, 2011 at 10:18 AM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    You'll hate the AALs unless you want a "stiffer" ride. If you're on a budget i'd suggest blocks for the back, IMO better than Leafs.
  4. Sep 21, 2011 at 11:04 AM
    KPT
    09 Prerunner
    Blocks promote axle wrap.
    I would recommend a lift that does not have any spacers or blocks of any kind, front of back.
  5. Sep 21, 2011 at 11:09 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    no. In my experience, blocks ride like crap, even compared to AALs. They also wear out the leaf pack (while AAL's at least extend their life) and, like KPT said, promote axle wrap.
    OP, have you considered spending a bit more cash for a coil lift instead of spacers?
    Generally the answer you'll get on here is to avoid spacer lifts, they can cause too many problems if you drive offroad and stiffen the ride considerably.
    Also, what do you mean by extend the 4wd? Theres no way to do that...
  6. Sep 21, 2011 at 11:17 AM
    KPT
    09 Prerunner
  7. Sep 21, 2011 at 11:38 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Worst advice ever.
    Block are shit, spacers are shit
    OP, do some more research and check your options more. Look up billy 5100s, OME, and Eibach. More money yes, but MUCH better option.
  8. Sep 21, 2011 at 11:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  9. Sep 21, 2011 at 11:41 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Shhhhh....He's 15. :)
  10. Sep 21, 2011 at 12:03 PM
    KPT
    09 Prerunner
    :gossip:
  11. Sep 21, 2011 at 12:38 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    Yep. Is is there anyway to lift it a little more if you get billys?
  12. Sep 21, 2011 at 12:45 PM
    KPT
    09 Prerunner
    A little more than.....?
  13. Sep 21, 2011 at 12:49 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    Than the 5100s give you at the top height
  14. Sep 21, 2011 at 12:59 PM
    KPT
    09 Prerunner
    Just making sure we are on the same page....you are asking whether you can more total lift with a billy setup than 2.5" (the top setting on the billy's)? If so, yes, you can add a thin top plate spacer to up to 3".
  15. Sep 21, 2011 at 1:00 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    Thanks
  16. Sep 21, 2011 at 1:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    But your ride will be shitty as the stock coils will be like super pre compressed. Eibach coils are like 170 bucks shipped man. Just get those. Way better option.
  17. Sep 21, 2011 at 4:29 PM
    03 Tacoma TRD
    Travis
    Charlotte
    03 TRD Sr5 4x4
    If i set my billies a 2.5 in the front will this stiffin the ride? and thanks for all the replys guy, thats very helpfull.
  18. Sep 21, 2011 at 4:37 PM
    03 Tacoma TRD
    Travis
    Charlotte
    03 TRD Sr5 4x4
    Also what setting would yall prefer on the billies? im looking to level it up with the back and also what about the AAL what size in those?
  19. Sep 21, 2011 at 6:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If you use the billy setting and an AAL i think 2.5 up front with a 1'' AAL levels it out pretty good. There is a photo thread on here with truck that have them at 2.5''.
    Personally id go with Eibach coils at 0'' setting and new packs and such. Way more pricey but definitely worth it.
  20. Sep 21, 2011 at 9:32 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    The ride will stiffen, because you're adding pre-load to the coils to get lift
    Setting them to the middle setting will level the truck out without an AAL, and will level it at the top 2.5 setting WITH the aal
    Do you plan on wheeling?
