3in lift rides like crap! Whats the deal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jaren1512, Jun 30, 2012.
  1. Jun 30, 2012 at 12:14 PM
    Jaren1512
    Jaren1512 [OP] Well-Known Member
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    Deck plate mod, all chrome plasti dipped, 32" BFGs, fogs, 3" bilstein coilover 5100s/5150s in the rear, manaflow exhaust, smoked tail lights, rooftop lightbar, upgraded alpine sound.
    So I keep hearing this talk about "vibes". Im not really sure what exactly that means. With the lift I have right now i feel damn near every bump in the road. sometimes it feels like my truck jumps 6 inches left or right every time i hit a tiny bump. is this something the diff drop would fix? how can i improve the ride quality?
    Now I know i have a spacer lift. (I have realized now why everyone hates on them) I know I need to get a new setup but its not an option at the moment. I just need to make this setup work as good as it can until I can afford to upgrade.
  2. Jun 30, 2012 at 12:16 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Spacers are going to ride that crap, just like you described. That's about all there is to it.
    The vibes people talk about are usually a shudder right after take off, or a buzzing feel at a certain speed.
  3. Jun 30, 2012 at 12:18 PM
    Jaren1512
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    so im pretty much stuck with this thing hopping around on me until i go full suspension?
  4. Jun 30, 2012 at 12:20 PM
    Jaren1512
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    The spacers sit on top of the coil if thats what your asking...
  5. Jun 30, 2012 at 12:22 PM
    KPT
    09 Prerunner
    So they are not compressed in the coilover assembly, correct? As in, you did or did not need a spring compressor to put them on.
  6. Jun 30, 2012 at 12:24 PM
    Jaren1512
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    No they are compressed in. We didnt need a spring compressor tho, my buddy figured out a backdoor method of getting them on without compressing the spring.
  7. Jun 30, 2012 at 12:48 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    THIS is why we don't recommend spacer lifts...this and the fact that if you hit a bump just right they'll snap your struts.
  8. Jun 30, 2012 at 12:56 PM
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    Spacers--when no other suspension parts are used in conjunction--will necessarily stiffen your ride because they limit the overall and designed travel of the shock... this is the sudden rebounding you are feeling if you hit a bump, and yes, it can often feel like your front end is hopping around fairly abruptly.
    Hope you can upgrade soon because your stuck unless you go back to your stock config.
  9. Jun 30, 2012 at 12:59 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Keep saving $$$
  10. Jun 30, 2012 at 1:21 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    should have gotten above coil spacers.
    there's no fixing the set up you have.
  11. Jun 30, 2012 at 2:09 PM
    Jaren1512
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    would the 32" tires I have work if I were to remove the spacers and everything?
  12. Jun 30, 2012 at 3:28 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    wut tire pressure you running ?
  13. Jun 30, 2012 at 3:31 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    Casper the friendly Taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Adjust this
  14. Jun 30, 2012 at 3:34 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Front spacers that go under the coil plate (compressing the coil further) will always make the ride a lot worse. You are compressing the coil making it stiffer without doing anything to gain up travel or down travel.
    If you are strapped for cash, get rid of those spacers and look for some top spacers for cheap used (I have some I can sell for cheap), and use those. Top spacers go above the whole shock assembly and dont affect the preload of the coil, so the ride wont be affected.
  15. Jun 30, 2012 at 3:38 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    If you do have 32s you can take the lift off and just run 32s with no lift
  16. Jun 30, 2012 at 3:40 PM
    BulletToothTony
    BulletToothTony TTC #0001 Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    lose the spacer and get some 5100's
  17. Jun 30, 2012 at 4:06 PM
    Jaren1512
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    how much you thinking?
