3in. lift
Discussion in 'Suspension' started by Pannell_Trd, Aug 30, 2010.
  1. Aug 30, 2010 at 9:04 PM
    Pannell_Trd
    Pannell_Trd [OP] Well-Known Member
    Tyler
    Georgia
    2009 Prerunner Double Cab Trd Sport
    Yellow foglights 20% tint
    What brand do yall recommend? i dont want to have to worry about cv angles or anything and it will fit 33's correct? this is my first toyota
  2. Aug 30, 2010 at 9:11 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I rather doubt you will have any worries about cv angles, due to the lack of cvs.:)
  3. Aug 30, 2010 at 9:14 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    ^ x2 on the CV's. How much are you wanting to spend? OME makes a lift kit for around 600 IIRC or Fox and companys of that nature are going to be considerable more!
  4. Aug 30, 2010 at 9:17 PM
    Pannell_Trd
    Tyler
    Georgia
    id like to stay away from the spacers in the front coilsprings, is there anything else id have to change or worry about?
  5. Aug 30, 2010 at 9:18 PM
    08pretaco
    az
    Well not if you are just going with a nice coilover in the front. Once you start messing around with the rear lift lots of people start to experience vibrations which have fixes but still an inconvience.
  6. Aug 30, 2010 at 9:19 PM
    ktmrider
    Junk
    well if you go above 2 inches it would be a good idea to get upper control arms to get a correct alignment.
    Another option is spindles for 1000 bucks pretty much you get 4 inches of lift no strings attached
  7. Aug 30, 2010 at 9:20 PM
    08pretaco
    az
    haha i totally forgot that i have spindles to tell him as an option lol with the mention of cv's i totally spaced..
  8. Aug 30, 2010 at 9:22 PM
    ktmrider
    Junk
    yeah theres just so many options my mind goes blank occasionally lol.
  9. Aug 30, 2010 at 9:24 PM
    Pannell_Trd
    Tyler
    Georgia
    yeah, im thinkin about just leveling the truck out and putting 265's on it, independent front suspension lift are expensive and have a few problems.
  10. Aug 30, 2010 at 9:26 PM
    08pretaco
    az
    what sort of problems are you talking about?
  11. Aug 30, 2010 at 9:28 PM
    Pannell_Trd
    Tyler
    Georgia
    like the control arms id have to buy, just alot of money. what would yall recommend me doing? i just want to give my truck a better look and not spend a ton of money and it be just as reliable as stock.
  12. Aug 30, 2010 at 9:30 PM
    08pretaco
    az
    the easiest way is just buy a set of billy 5100 and set then at 1.75" i think thats the right number, and sit level without messing with anything else. they are pretty cheap as well!
  13. Aug 30, 2010 at 9:34 PM
    ml1178
    ml1178 Member
    3in lift, 2in wheel spacers, 16in rims, 32in tires, fully tinted windows and lights, hid headlights, kenwood 994 radio, alpine 1000w amp, Orion HCCA 10.4 sub, with custom box.
    3 in readylift. If you need something cheap.
  14. Aug 30, 2010 at 9:35 PM
    Pannell_Trd
    Tyler
    Georgia
    My truck has billys on it from the factory but there not adjustable correct?
  15. Aug 30, 2010 at 9:37 PM
    08pretaco
    az
    yes they are not adjustable
  16. Aug 30, 2010 at 9:38 PM
    08pretaco
    az
    he is trying to stay away from spacers
  17. Aug 31, 2010 at 8:05 AM
    newbtacoma
    newbtacoma Well-Known Member
    Houston, TX
    2010 Super White Sport
    If you get spindles, do you still need UCA's? I am also looking for a good 3 inch lift (do not want spacers) and have been looking at the OME kit (i just drive to work and back, no offroad) Would spindles be more beneficial? If so, who sells spindles (Brands)?
  18. Aug 31, 2010 at 8:20 AM
    08pretaco
    az
    I run the camburg which are 4" but total chaos makes a set thats 3.5". No you do not need UCA but they spindles cost upwards of 1k but are worth every penny!
  19. Aug 31, 2010 at 8:22 AM
    08pretaco
    az
    If you only drive on the road i wouldnt waste the money on spindles on anything other than billy 5100. THey give you want you want without overkill for a dd that sees lttle dirt
  20. Aug 31, 2010 at 10:06 AM
    newbtacoma
    Houston, TX
    Would the billies work with my stock springs, or would it be a good idea to get a coilover? Do I need a AAL in the back with adjustable billies? I have the TSB springs - how much lift in the back would I need for 3"?
