3inch 2k budget
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlexOntTheFly27, Feb 4, 2018.
  1. Feb 4, 2018 at 6:25 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Cnatact Marie at headstrong off-road, if you want to do something you will be happy with with lots of wheeling, I would go better than OME, definitely get a new leaf pack for the rear since it will add payload and more travel with the right set up. at 3 inches you will most likely need to look into upper control arms as well. I personally have about 90percent used parts and still have about $1000 into my rear and the same for the front. I do wheel my truck at least every other month and still want better stuff, my front is OME on bilstiens with LR uca, rear is allpro leafs on bilstien b110 with Ubolt flip superbumps and extended brake lines. Much to consider. Pretty happy with the rear but I do want to upgrade the front to either ADS or King
    AlexOntTheFly27[OP] likes this.
  2. Feb 4, 2018 at 6:27 PM
    AlexOntTheFly27
    AlexOntTheFly27 [OP] Well-Known Member
    2013 dcsb Trd OR
    Good info to have. I am def doing uca and will go with the spcs due to budget. That is the only thing I know for sure haha
    mosquitoTaco[QUOTED] likes this.
  3. Feb 4, 2018 at 6:32 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    JBAs can get a lot of castor for around the same price.
