3inch leveling kit help in NoVA... anyone want booze and pizza?
Discussion in 'Virginia' started by jstyle, Jul 15, 2017.
  1. Aug 7, 2017 at 3:33 AM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    Man i love this forum. everyone is willing to help (and troll) lol. good luck man, it is really not hard, you can prob do it. but i hope one of the bros can help you. Id offer to do it for you but i'm in Hawaii. lol... all you need is like a 21mm 19mm 17mm and 14mm socket and the same in open ends. also, might need a 22mm i can't remember. have a marking pen and some blue or red locitite. while you're at it, you might want to also anti seize the camber bolts since you're going to need an alingment anyway. use the marking pen to mark your alignment bolts so when you put it back together you can kind of get it close to right. to anti seize the bolts alignment bolts, just take them out, throw anti seize on both the bolt and the sleeve (sounds weird but when you look at it you will know what i mean) and put it back the way you found it. you want to anti seize it for later, I have had to chop off too many fucking bolts to list when doing lower control arm work. it is a good preventative measure.
  2. Sep 26, 2017 at 4:45 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @EatSleepTacos this guy turned out to be my coworker!
    @jstyle sorry we forgot about this. I think you did already, but did you get it installed?
  3. Sep 26, 2017 at 5:42 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No way! That's awesome.
  4. Sep 27, 2017 at 10:03 AM
    jstyle
    jstyle [OP] Well-Known Member
    Josh
    2012 Taco Off Road
    Anything that was shiny is now black
    Yeah I ended up getting it done but it’s all good. I’m sure I’ll ask you for help going forward :)
    fatfurious2 likes this.
