3inch lift help
Discussion in 'Suspension' started by sctrd09, May 27, 2011.
  1. May 27, 2011 at 1:13 PM
    sctrd09
    sctrd09 [OP] Well-Known Member
    SC
    2013 TRD OFF ROAD
    I have a 09 trd sport. I want to run 33in tires with either 17s or 18s. Ok now for the questions. First Im only doing this for looks dont really do any offroading other than going down sum dirt roads and pretty smooth ones at that. Next will I be able to fit 33s with a 3in lift. If this is possible what lifts do yall suggest knowing that I want this setup mainliy for looks. Thanks in advance.
  2. May 27, 2011 at 1:35 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Yes, 33's will fit on a 3inch lift. You have a ton of lift options check out the search button I'm sure you will find what you're looking for.
  3. May 27, 2011 at 1:38 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    you can fit 33s stock with the right backspacing on a wheel and trimming.
  4. May 27, 2011 at 1:41 PM
    Bz3r0
    Bz3r0 Smackalicious!
    Bryan
    Edwards AFB, CA
    White 2017 TRD Offroad
    Under Construction
    x2
    I've seen some people run into troubles with this and a lift... No thank you on making a 9 pt turn to get out of a grocery store parking lot lol.
    Do plenty of research man, and there are quite a few folks that posted info related to that on TW, you just have to find it.
  5. May 27, 2011 at 1:45 PM
    VanillaGorilla
    VanillaGorilla Itsnevertoearlytostartbee fingupyourobituary
    Erik
    East Bay Area, CA
    09 BSP Pre Runner SR5
    Tint. (DONE) Soon to come. 3in Llift (OME) Color matched grill (DONE) BHLM (DONE) Tail tint (DONE) Pro comp rims (8069) End goal: Murdered out truck
    billys set at 2.5, AAL?
  6. May 27, 2011 at 1:47 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    yeah that will work too.
    OP - just gotta search and see what will get you what you want for the price you are looking for. each has its pros and cons.
  7. May 27, 2011 at 1:47 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    For a street truck you will be fine you will probably need to remove your front mud flaps. But what size are you looking to get? there is a lot of 33's from 10" wide all the way to 15" your not going to have a problem with the height of the tire its the width.
  8. May 27, 2011 at 1:50 PM
    sctrd09
    SC
    2013 TRD OFF ROAD
    Im not sure probably around 12 to 13in
  9. May 27, 2011 at 1:50 PM
    VanillaGorilla
    Erik
    East Bay Area, CA
    aye JLee check the NCT site real quick bout the welder. BACK ON TOPIC.
    Like they said just do some research on here. You'll find answers.
  10. May 27, 2011 at 1:55 PM
    Hellabadazz
    Hellabadazz Member
    Durham NC
    2011 TRD Sport pkg 3" fabtech lift
  11. May 27, 2011 at 1:58 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    all he wants is a show lift.
  12. May 27, 2011 at 2:02 PM
    sctrd09
    SC
    2013 TRD OFF ROAD
    Yea thats pretty much what Im looking for but no price when I clicked on the fabtech link. Anybody have an idea on the price of this kit or another quality brand with the same components?
  13. May 27, 2011 at 2:04 PM
    JLee
    Jerry
    Grass valley CA
    If you go between 12" and 13" you will need to do some trimming even for road use.
  14. May 27, 2011 at 2:05 PM
    JLee
    Jerry
    Grass valley CA
    got it
  15. May 27, 2011 at 2:12 PM
    sctrd09
    SC
    2013 TRD OFF ROAD
    Ok thanks for the heads up about the trimming and I'll check out the rcd 4in.
  16. May 27, 2011 at 2:22 PM
    sctrd09
    SC
    2013 TRD OFF ROAD
    yea i just noticed that about the rcd kit
  17. May 27, 2011 at 2:23 PM
    sctrd09
    SC
    2013 TRD OFF ROAD
    Anyone know anything about any of the toytec kits?
  18. May 27, 2011 at 2:34 PM
    Bz3r0
    Bryan
    Edwards AFB, CA
    Under Construction
    I've got the Toytec ultimate lift installed on my truck set at factory height running 285/75/16 tires and only rub when almost locked turning left and right.
    Be sure to look into getting aftermarket upper control arms... I suggest getting those before you purchase your lift, and have them installed when you get it done. I'm still running the stock UCA's and I've got very little clearance when i go over speed bumps, and fairly certain they're rubbing my coilovers. :facepalm:
  19. May 27, 2011 at 2:43 PM
    Bz3r0
    Bryan
    Edwards AFB, CA
    Under Construction
    ^x2
    Yeah... I forgot to say "Yep, they're good" lol.
  20. May 27, 2011 at 2:45 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    OME ?
    good.
