3'lift help with tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by white09tacoma, Oct 1, 2009.
  1. Oct 1, 2009 at 4:25 PM
    white09tacoma
    white09tacoma [OP] Active Member
    David
    texas
    09 prerunner sr5
    so i found a 3'lift that i like and now i what to know what is a good tire size i should get i have 2009 prerunner 4l2.4l
  2. Oct 1, 2009 at 4:35 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    when i ahd my 3in spacer lift at first i ran and still run 285s (33") i have spindles now and can fit 35s... The biggest u could go in 3 in is 285 there might be a little rubbing at full crank depending on what rim size u get.... But there is people on this forum that was able to fit 35s lol.... r u gonna have fun with it or is just looks..??
  3. Oct 2, 2009 at 11:31 PM
    white09tacoma
    David
    texas
    09 prerunner sr5
    its a little bit of both
  4. Oct 3, 2009 at 1:48 PM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    Look at the camburg spindles that's what I run on my truck and it will give u 4" lift in the front... Are u gonna get coilovers too..??
  5. Oct 3, 2009 at 1:59 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2 That'd be nasty! 4" spindles and adj. c/o's!!! If ya got the loot, do that :thumbsup: otherwise like sandman said 285's. Don't forget that you might have alignment issues w/ your stock UCA's so ya might have to upgrade. ;)
  6. Oct 4, 2009 at 12:14 AM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    Yes zziirr.. thats what im running and i love it... your right about the alignment issues... U can max out the UCA at about 3" of lift but thats it... I had it like that and it rode like shit... Thats y i got the spindles and i could still use my stock UCA and Lower controls arms as well and they can take a beating ... But remember that if u do run 35" tires your gonna have to rear gear the truck or your gonna get shitty gas millage...
  7. Oct 5, 2009 at 10:52 AM
    white09tacoma
    David
    texas
    09 prerunner sr5
    ok thanks yal help a lot looks like i need to get some more money befor i do anything
  8. Oct 5, 2009 at 10:56 AM
    jterango
    jterango Dr. Bronzbak
    eastern wv
    d-cab off road
    bed mat,access cover
    will 31x1050" fit under a stock truck?
  9. Oct 5, 2009 at 11:08 AM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    Im pretty sure u could but there might be a slight rub only when at full crank coming up a driveway if anything but I'm pretty sure u should be striaght but I would still ask around to double check...
  10. Oct 5, 2009 at 11:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not a 5 lug.
  11. Oct 5, 2009 at 12:51 PM
    sandman427
    sandman427 KR FAB
    Amir
    BAMF TACO!!
    Yea... But isn't his 6 lug..?? Or am I trippin... Lol
  12. Oct 5, 2009 at 4:55 PM
    white09tacoma
    David
    texas
    09 prerunner sr5
    yea it 6 lug
