3M double sided tape eyelid removal help
Discussion in 'Hawaii' started by Low Kun, Mar 25, 2013.
  1. Mar 25, 2013 at 8:55 PM
    Low Kun
    Low Kun [OP] Member
    Section 808
    08 Taco
    Hey tw hawaii,
    I put t rex2 eyelids on my stocks with 3m double sided tape and i just recently switched out my headlights to different ones and i wanna transfer the eyelids off the stocks and onto the new pair. Any suggestions to get em off without ruining or breaking anything? All responses are appreciated.
    Thanks!
  2. Mar 25, 2013 at 9:00 PM
    rtrudel35
    rtrudel35 Well-Known Member
    Becky
    Methuen, MA
    2014 4Runner
    Strong fishing line. Just like it's used to debadge the Tacoma.
  3. Mar 25, 2013 at 9:02 PM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    Hair dryer. heat it up little by little
    or use the heating steps used in the bhlm process. should work
    Both go with the fishing line idea
  4. Mar 25, 2013 at 10:32 PM
    Low Kun
    Low Kun [OP] Member
    Section 808
    08 Taco
    Thanks for the info guys! Ill pick up some fishing line asap.
  5. Mar 26, 2013 at 1:56 AM
    bullaculla
    bullaculla IKA fabrications
    Honolulu HI
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings.
    Dental floss works well too.
  6. Mar 26, 2013 at 3:02 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Heat heat heat. Helps
    Then get goo-off if there is some sticky left
  7. Mar 26, 2013 at 12:04 PM
    Low Kun
    Low Kun [OP] Member
    Section 808
    08 Taco
    Dental floss and hair dryer for heat first attempt it is then. Lol thanks!
