3mm rubber for vibration/reverb dampening?
Discussion in 'Audio & Video' started by crackedmirror, Jun 21, 2021.
  1. Jun 21, 2021 at 6:30 AM
    crackedmirror
    crackedmirror [OP] Well-Known Member
    Dynamat is expensive. 3mm rubber flooring is not. 24" x 1' is under 2$ at hardware stores. Any reason I shouldn't just stick this to sheet metal panels with some gorilla glue?
    pinktaco808 likes this.
  2. Jun 21, 2021 at 7:55 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Go with the Noice brand on Amazon. $1.80/sqft and it’s actually designed to be in the door. Rubber flooring isn’t designed to hold up in the harsh environment a truck door panel is over the years. And its not near dense enough to absorb the vibrations it needs to absorb.
    I like the creativity though. Love brainstorming alternate uses for cheap products!
    TacoManOne, GRNT4R and pinktaco808 like this.
  3. Jun 21, 2021 at 7:59 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Well, you could. But it would only work to a small extent and for a short time.
    Use product designed for the task.
    Remember, you do not need to cover 100% of the panel area to achieve effective vibration damping, roughly 50-60% is enough.
    soundman98 likes this.
  4. Jun 21, 2021 at 2:14 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    The biggest reason would be heat and smell. Use a product designed for the environment to minimize adverse conditions.
    GRNT4R likes this.
  5. Jun 22, 2021 at 11:38 PM
    pinktaco808
    pinktaco808 Hot Steppa
    Link I can't find shyt
  6. Jun 23, 2021 at 4:24 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    I don’t have a link, just go on Amazon and type in ‘noico’
    pinktaco808[QUOTED] likes this.
  7. Jun 23, 2021 at 11:17 AM
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    I 2nd or 3rd the Noico. Thats what i added to my doors and it made a night and day difference. I'll be doing rears and back wall eventually. Very easy to apply, i used a heat gun to heat of the back of the sheets just before placing them where i wanted them
  8. Jun 23, 2021 at 3:21 PM
    pinktaco808
    Ohh u spelt it wrong
  9. Jun 23, 2021 at 3:26 PM
    pinktaco808
    Which one of the 3 should I get or which ones?
  10. Jun 25, 2021 at 4:26 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
  11. Jun 25, 2021 at 4:33 AM
    Clearwater Bill
    Billy
    Largo Florida
  12. Jun 25, 2021 at 3:00 PM
    rob feature
    rob feature Tacos!
    Colorado
    Rubber mat is not a CLD (constrained layer damper). It's a rubber mat. They don't do the same thing. The rubber mat might block some noise at certain frequencies, but in this context it might be seen as more of a barrier layer than a damper. Barrier layers are most effective when they line as much of the interior, uninterrupted, as possible. They're generally used in conjunction with a CLD as well as other features. Also remember that this is going in a vehicle, so offgassing, smell, heat tolerance/viscosity and longevity matter.
    Generally the components of a full sound deadening treatment are dampers (CLD) for resonant surfaces, barrier layers to block incoming noise, and decoupling/insulating layers - among other techniques for dash rattles, etc. Many also incorporate absorbent features. Dampers probably make the biggest difference if only choosing one layer, but you want to use a quality damper in all the right places.
    DON'T BUY THE CHEAP CRAP. I can't say whether Noico passes heat tolerance tests. I've never used it, but I'm wary of cheap butyl. That said, I can't recall any posts where users have complained of melting, and it has been on the market for a few years. I won't use it personally. The constraining layer seems too thin. This is not an easy job, and you'll only want to do it once. And you certainly will not want to clean up cheap a runny elastomer.
    I mention that because it appears you're trying to find the cheap way out of this like most folks considering deadening. There isn't one. Fortunately many pioneers have come before you and figured out what NOT to do. I can think of no better example of - buy once, cry once. At the very least, avoid asphalt based products like Peel & Seal. Make sure you use a good quality butyl/aluminum damper from a reputable company. Realize that this is some challenging and tedious work. It involves removing and reinstalling your interior, so planning is big.
    If I had to do this today, I'd be choosing between Resonix (1st choice), Dynamat Extreme, or Knu Kolossus for CLDs...with Resonix taking the preferred spot by a good stretch.
    There are countless threads on DIYMA about this and even one awesome test thread. There is another in the works, but it could be a while before results are compiled. Noico is being tested in the new batch. There are also quite a few deadening threads here in the AV section of TW.
    Cheers!
    TrdSurgie likes this.
  13. Jun 26, 2021 at 7:29 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Noico. It’s is 100 here and zero smell. works great.
