3Pooches version 3.5
Discussion in '2nd Gen. Builds (2005-2015)' started by 3pooches, Apr 27, 2018.
  1. Jul 11, 2022 at 4:45 PM
    #5121
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Jeeeeeep update!
    I got a whole side done yesterday. All by myself.f
    I worked on it a little more today. Instead of starting on the other ball joints, I decided to put the new drag link, tie rod and track bar on. Ball joint can wait till the weekend.
    Have any of the parts pulled off been bad? Fo' sho'. On the side I did, the lower ball joint was done. The drag link and tie rod weren't horrible, but getting to the point of bad. Surprisingly, the track bar bushings were shot. Like falling apart, shot. Glad I got it. I hadn't planned on it until the vendor had a sale and pulled the trigger because.
    Lesson for the day: Be sure and tighten that steering stabilizer up when the steering is full lock in the opposite direction of the frame tab. That was 20 minutes of head-scratchin'.
  2. Jul 11, 2022 at 4:53 PM
    #5122
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Nice job! :thumbsup: I know you are cussing the hell outta the heep, but diggin your patience with it. Gotta push through.
    3pooches[OP] likes this.
  3. Jul 11, 2022 at 4:57 PM
    #5123
    Hafaday
    Bill
    Richmond, VA.
    All I did today was make a damn mess of an oil change. Pix are in the NOVA thread.
    The short and sweet…. Oil change and tire rotation on both the jeep and truck.
  4. Jul 11, 2022 at 5:01 PM
    #5124
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I have no choice. The ball joints have turned into an expensive fiasco. Ridiculously priced ball joints aside, I'm at $600 currently. $200 in tools and $400 in parts. Makes me wonder what labor would've been....... :angrygirl:
  5. Jul 11, 2022 at 5:03 PM
    #5125
    Hafaday
    Bill
    Richmond, VA.
    Damn! I might have to pull out my ball joint set and just see if it’ll work, Cups that is.
  6. Jul 11, 2022 at 5:10 PM
    #5126
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I made mine work, but I ordered the correct cups. I'll see if they're better than what I had. My ball joint press is pretty pathetic at any rate.
    Edit: the tools were the cup set and and hub press to separate the axle from the unit bearing. I could've used a hammer or something, but I've been wanting to get something for a while.
  7. Jul 11, 2022 at 5:35 PM
    #5127
    Hafaday
    Bill
    Richmond, VA.
    Rite.
    Hell, as far as I’m concerned… any work job around the house or vehicle requires a new tool purchase.
    03dumdum and crashdb[QUOTED] like this.
  8. Jul 11, 2022 at 7:07 PM
    #5128
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    Quick update: had a procedure today to remove the blood clot in my arm and also confirm the diagnosis as to what caused it. They confirmed it's thoracic outlet syndrome, which means the vein gets pinched between my upper rib and clavicle when I raise my arm over my head, which ultimately caused the clot. So next step is surgery to remove the rib. But the outlook is full recovery and back to normal activities once I recover. That is all.
  9. Jul 11, 2022 at 7:09 PM
    #5129
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Glad they found out why!! Prayers going out
  10. Jul 11, 2022 at 7:10 PM
    #5130
    y=mx+b
    y=mx+b Station Wagon
    Lafayette, IN
    '05 T4R SR5 v6 4wd
    Glad you're doing better now mark! That's just weight reduction for high speed truck huckin
  11. Jul 11, 2022 at 8:05 PM
    #5131
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Good news!
    Would they allow you to keep the removed rib? You could turn it into a keychain.
  12. Jul 11, 2022 at 9:53 PM
    #5132
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    2nd this.
  13. Jul 12, 2022 at 3:12 AM
    #5133
    Mojo Jojo
    Mark
    Harpers Ferry, WV
    Haha, or hang it from the rear view mirror.
  14. Jul 12, 2022 at 4:28 AM
    #5134
    Hafaday
    Bill
    Richmond, VA.
    Glad they found the reason why.
    I was gonna say, nip the tips and hollow it out. That way, Mark could literally toot his own horn. :rimshot:
    Even better.. make a kazoo out of it.
  15. Jul 12, 2022 at 5:15 AM
    #5135
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Yay Dave!!! All I did was put in my order request for the correct misalignment spacers through the Elka service dealer in Ohio...never got the link to make the purchase, so I'm following up this morning
    Hafaday and 3pooches[OP] like this.
  16. Jul 12, 2022 at 5:16 AM
    #5136
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    So glad they are addressing the root cause and removed the current clot!! :cheers:
  17. Jul 12, 2022 at 5:49 AM
    #5137
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Guess they don't like money.
  18. Jul 12, 2022 at 5:57 AM
    #5138
    3pooches
    3pooches [OP] Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    I can’t wait for you to get all this done and behind you buddy!
  19. Jul 12, 2022 at 6:39 AM
    #5139
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    They were pulling the spacers and 2 additional bearings before invoicing me, so they value making sure they don't have to refund any of those monies!!
    Hafaday likes this.
  20. Jul 12, 2022 at 6:55 AM
    #5140
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I'll bite. Did you break something?
