3Pooches version 3.5
Discussion in '2nd Gen. Builds (2005-2015)' started by 3pooches, Apr 27, 2018.
  1. Nov 23, 2022 at 11:32 AM
    #7501
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Yes. It's a pile. The bar adjustment pin disappeared, the nut that secures the bar loosens constantly. And if you tighten it, it welds itself to the threaded stud. Today, I look down and the bolts that hold the cowl on have disappeared. These are semi-captive mind you. The constant chain-sharpening is me. Even though I'm careful about running it into the dirt and all. And I'm too much of a moron to use a moron-proof file. I look at Chris' Echo and unless he's hiding his struggles, that thing fires up and cuts every time.
  2. Nov 23, 2022 at 11:34 AM
    #7502
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Learned of a 2 stroke hack for seasonal/long term storage --- Drain out fuel, run machine until it burns off the fuel. Pour in 2 stroke oil ONLY into the fuel tank, then with the saw off, pull the cord a few short strokes, basically pumping the oil into the fuel filter, fuel line and most importantly, the carburetor!! When it comes out of storage, dump fuel tank...refill with your mixed fuel m
  3. Nov 23, 2022 at 11:37 AM
    #7503
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Running/starting isn't the problem.
  4. Nov 23, 2022 at 11:37 AM
    #7504
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    I've also got that echo CS-590 and it's been reliable, even when I didn't use/know of the just mentioned 2 stroke oil storage hack...
    That said, the M18 chainsaw is stupid easy to operate, but then again it does have a chain adjustment screw, 2 bolts to hold the bar...but no carb, no mixing fuel and has worked great for both my dad and my purposes (we each have one).
    Let me know the model, as I inherited a buddy's and it's literally sat w/o bar and chain for nearly 4 years now!!!! Haven't pulled it out once.
    3pooches[OP] likes this.
  5. Nov 23, 2022 at 11:47 AM
    #7505
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    MS251. Would not recommend...
  6. Nov 23, 2022 at 12:28 PM
    #7506
    3pooches
    3pooches [OP] Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    I think it would fun in his truck. He has a locker just in case there an issue.
  7. Nov 23, 2022 at 12:30 PM
    #7507
    3pooches
    VA & WV
    I’ve had that echo for about 8 years and haven’t had much of an issue. It runs a little rough here and there but I’ve never cleaned it or changed the spark plug. I’m going to try Greg’s trick and see if it helps.
    Hafaday likes this.
  8. Nov 23, 2022 at 12:41 PM
    #7508
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Just use the manufactured fuel. Expensive, but I will say that the chainsaw has never failed to start reliably. (except where the idiot owner doesn't know what he's doing)
    Hafaday and 3pooches[QUOTED][OP] like this.
  9. Nov 23, 2022 at 4:41 PM
    #7509
    Hafaday
    Hafaday Well-Known Member
    Bill
    Richmond, VA.
    19, DCSB, Off Road. 23 KLX300, 14JKU
    Echo, is a damn good saw. I like’em.
    Sometimes I wish the M18 had a clutch in it. I’ve thrown the chain a time or two.
  10. Nov 23, 2022 at 6:39 PM
    #7510
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Motorcycles in the wild.
    Hafaday and 03dumdum like this.
  11. Nov 23, 2022 at 7:55 PM
    #7511
    03dumdum
    03dumdum Well-Known Member
    JT
    White 2018 TRD OR
    Fox 2.5 rr, RCI front/mid skid JBA uca RCI rack iKamper Xcover AAL Ray 10 17x9 -38 Maxzis Razr AT 285-75r17 20% front windows & 5% strip on windshield Tactilian magnetic flags Weird engine squeal Custom pin strips.
    Just gonna drop this here :rofl:
    Hafaday likes this.
  12. Nov 23, 2022 at 8:00 PM
    #7512
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Well then....
    I'm willing to admit my issues are user-error, but I really don't know what I'm doing wrong.
  13. Nov 23, 2022 at 8:16 PM
    #7513
    03dumdum
    JT
    White 2018 TRD OR
    I got one of their electric pressure washers and it’s been great, hopefully the chainsaw will perform at the same level, only time will tell.
  14. Nov 23, 2022 at 8:29 PM
    #7514
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I looked that one up. There's two studs for the bar. Leaps and bounds better than mine.
    03dumdum[QUOTED] likes this.
  15. Nov 24, 2022 at 6:19 AM
    #7515
    Hafaday
    Bill
    Richmond, VA.
  16. Nov 24, 2022 at 6:46 AM
    #7516
    Hafaday
    Bill
    Richmond, VA.
    All this saw talk.. I need to do a serious external cleaning on my 271.
    Will admit though.. having both gasser and a battery powered have their advantages.
    Greg.Brakes.Tacos and 03dumdum like this.
  17. Nov 24, 2022 at 6:47 AM
    #7517
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    Happy Thanksgiving all!
  18. Nov 24, 2022 at 6:48 AM
    #7518
    Hafaday
    Bill
    Richmond, VA.
    You too.
  19. Nov 24, 2022 at 8:33 PM
    #7519
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    Haha, same. I drank milk instead of water as a kid when I came in from playing outside. Fortunately I'm not lactose intolerant now.
    He has a locker so he should be fine.
    Do it!
  20. Nov 26, 2022 at 7:21 AM
    #7520
    Hafaday
    Bill
    Richmond, VA.
    Too quiet in here.
