3Pooches version 3.5
Discussion in '2nd Gen. Builds (2005-2015)' started by 3pooches, Apr 27, 2018.
  1. Jan 14, 2023 at 10:45 AM
    #8401
    SACTOWN
    SACTOWN Mr. bougie, apparently
    Greg
    Still raining here
  2. Jan 14, 2023 at 10:47 AM
    #8402
    3pooches
    3pooches [OP] Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    I saw mammoth has already received around 200” of snow. You guys have a boat ready?
  3. Jan 14, 2023 at 10:49 AM
    #8403
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    For someone that was up or still up at 4am, I don't know how you're upright.
  4. Jan 14, 2023 at 10:53 AM
    #8404
    SACTOWN
    Greg
    Thank god we are on high ground. Doesn’t really flood around me. Yea I saw that about mammoth.. we aren’t far behind. Their base is -160. Ours is -130
    3pooches[QUOTED][OP] likes this.
  5. Jan 14, 2023 at 10:57 AM
    #8405
    SACTOWN
    Greg
    Mammoths bases is around 8100. Which is the Top of our highest peak. Palisades base is 6800
    3pooches[OP] likes this.
  6. Jan 15, 2023 at 8:31 AM
    #8406
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
  7. Jan 15, 2023 at 10:11 AM
    #8407
    3pooches
    VA & WV
    That would make changing wheels easier
  8. Jan 15, 2023 at 10:23 AM
    #8408
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Scissor lifts are a tease.
    Greg.Brakes.Tacos likes this.
  9. Jan 15, 2023 at 10:58 AM
    #8409
    3pooches
    VA & WV
    They definitely limit the amount of under carriage work you can do.
  10. Jan 15, 2023 at 11:39 AM
    #8410
    Tiny's Taco
    Shenandoah Valley
    I just solved that problem. New tires go on the Baja's Wednesday. Old tires on the stock wheels are gone. No more spacers either.
  11. Jan 16, 2023 at 7:25 AM
    #8411
    SACTOWN
    Greg
    Sup party people
  12. Jan 16, 2023 at 7:28 AM
    #8412
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    I want snow.
  13. Jan 16, 2023 at 7:28 AM
    #8413
    SACTOWN
    Greg
    Haahaa
  14. Jan 16, 2023 at 8:59 AM
    #8414
    Tiny's Taco
    Shenandoah Valley
    Go to CA. I hear they have a little.
  15. Jan 16, 2023 at 9:13 AM
    #8415
    SACTOWN
    Greg
    We don’t got that much. We could use more get us out of the drought
  16. Jan 16, 2023 at 9:20 AM
    #8416
    Tiny's Taco
    Shenandoah Valley
    I thought it was stacking up pretty deep in the mountains. I saw last night that the average snowfall was 225% above average. And reports that some of the reservoirs are coming up with the repetitive storms. I know it's primarily the central and northern parts, but that's still a lot of snow. More than Ic are to deal with.
    SACTOWN[QUOTED] likes this.
  17. Jan 16, 2023 at 10:41 AM
    #8417
    SACTOWN
    Greg
    it is.. i was joking. we got 300inches of snow this year so far. Truckee CA avg about 425 i think of snow a year
  18. Jan 16, 2023 at 7:25 PM
    #8418
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    It's almost like the yacht doesn't want to leave. I replaced the knock sensors, and wiring for them. This fixed the check engine light. While I had it apart, I replaced the oil pressure sensor and cam position sensor. Good to go.
    Today, I finished up a project on it I had started a year ago. While I'm doing it I notice the carpet in the footwell is soaked. I pull it up and the padding underneath is full of water. Not sure how it happened. I don't see any signs of a leak. Only thing I can figure is I didn't get the rear door shut good; which would cause the front door not to shut good. Last thing I want to do is track down a leak.
    And the kicker is that it's suddenly been starting weird. It won't catch to run on the first key turn. Maybe a mild pop from the exhaust. But it'll fire on the second turn. I believe it's the fuel pressure regulator. I hope it is. Or I futzed something on reassembly.
    I just want to sell this thing so I can move forward! :angrygirl:
    3pooches[OP] and nguyenpatrickt like this.
  19. Jan 17, 2023 at 7:40 AM
    #8419
    SACTOWN
    Greg
  20. Jan 17, 2023 at 11:00 AM
    #8420
    3pooches
    VA & WV
    Maybe timing from the cam position sensor?
