3rd Annual Red River Gorge Meet Success w/Pics & Shennanigans
Discussion in 'Kentucky' started by MedlinAround, Mar 19, 2018.
Should stock trucks try to climb this mysterious rock in the woods?
  1. Yes
    20 vote(s)
    40.0%
  2. No
    9 vote(s)
    18.0%
  3. Enough Skinny Pedal will get you up it!
    12 vote(s)
    24.0%
  4. Enough Beer you can do anything!
    21 vote(s)
    42.0%
Multiple votes are allowed.
  1. Jun 6, 2018 at 7:35 AM
    #1261
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    Wore it all weekend too. Like a champ.
  2. Jun 6, 2018 at 8:35 AM
    #1262
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    Just got back from a bachelor party so haven't been on here in a bit.
    I put on a Wilson Gum Drop mount on because the hole was too big for the regular firestik mount I bought. There was no directions so I put it on the way it was assembled with the rubber disc between the Wilson Gum Drop and the top of the mounting plate on the bumper with the metal washer on the bottom between the bottom of the mounting plate on the bumper and the nut holding the mount on where the coax screws on.
    It's a firestik antenna, 4' I believe
    I don't have a great pic but you can kind of see the antenna/spring in this picture:
    Also, I got approved for the time off from work so I can come!!! :cheers:
  3. Jun 6, 2018 at 9:49 AM
    #1263
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    Looks nice. I'm using a 3' firestik but considering getting a 4' before my Amazon return period runs out. I'm at 1.7 SWR at 1 and 40... So I'm not sure if it's really worth troubleshooting or if I should be happy with my results .
  4. Jun 6, 2018 at 9:50 AM
    #1264
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Wanna shoot for earlier? I'll take a half day off and I can be there by 3 or 4?
    tacofort[QUOTED] likes this.
  5. Jun 6, 2018 at 9:53 AM
    #1265
    dirty deeds
    Nick
    Eastern KY
  6. Jun 6, 2018 at 9:57 AM
    #1266
    dirty deeds
    Nick
    Eastern KY
    The bracket your antenna mounts to, ground that. May help your numbers, I don't really think you're too far out. True test will be when you're around other CB users.
  7. Jun 6, 2018 at 9:58 AM
    #1267
    dirty deeds
    Nick
    Eastern KY
    :yes: Fender redemption! Those wheels are straight secs!
    Honestly, I can't see the mount at all.
  8. Jun 6, 2018 at 10:04 AM
    #1268
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    I'm still 2 hrs away no matter what. I could probably be there 4-5 at best.
    dirty deeds[QUOTED] likes this.
  9. Jun 6, 2018 at 10:17 AM
    #1269
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    I think that mounting location is decently grounded...but maybe not. I may try to run another wire/strap down to the frame though.
    My SWR was running closer to 1.9 (from what I remember) before I added the spring, then once the spring was on I was able to get it closer to 1.7. That's why I'm thinking I need a little more height to get above the roof of the cab....but then again, I'm testing in my driveway and I may need to go to an open field.
  10. Jun 6, 2018 at 10:22 AM
    #1270
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Remember, Tacoma bed is "plastic"...Not a good ground point. Will work MUCH better with a chassis ground. Use a flat ground strap as opposed to round wire. You should have at least 66% of the antenna (winding) above the cab. Firestix are top loaded. (More wire in top 1/2 than bottom 1/2) I have 3', 4', and 5' Firestix. 3' stays behind seat as a spare. 4' USUALLY stays mounted. 5' is for long distance road trips or wheeling in open country. Reception/transmission (RX/TX) is noticeably stronger as the antenna length grows.
  11. Jun 6, 2018 at 10:57 AM
    #1271
    dirty deeds
    Nick
    Eastern KY
    Well piss. I was getting the vibe you wanted to be there earlier than what I initially said I would be.
  12. Jun 6, 2018 at 10:59 AM
    #1272
    dirty deeds
    Nick
    Eastern KY
    I ran an independent ground for my antenna bracket alone. Using regular 8ga stranded green jacketed wire and regular ol single hole lugs. Smeared a bit of goo on the wire, crimped on. Shrinked the ends. Smeared a bit of goo on the lugs, bolted down. I did shave a bit of paint off the bracket and the place I found on the frame, too.
    Grounded af!
  13. Jun 6, 2018 at 11:26 AM
    #1273
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    Good call. I found a spot on the frame that already has a hole in it, It's directly below the rear bed bolt. I'll clean up the paint on the frame and run a wire up to the mount. Should need 4' or less.
    The place the bracket is bolted to is metal, and connects to the bumper/frame, but it's thinner and also painted. So, we'll see if this ground improves things.
  14. Jun 6, 2018 at 12:07 PM
    #1274
    dirty deeds
    Nick
    Eastern KY
    Thought this same thing myself. Wrong.
    When I ran the independent ground, changed the game.
    JohnnyRed[QUOTED] likes this.
  15. Jun 6, 2018 at 1:08 PM
    #1275
    tacofort
    Joe
    Cincinnati, OH
    I'll do my best dude. Tell me what time and where to be and I'll try to make it happen.
    Edit: Normally, very difficult to leave work before 2 PM
  16. Jun 6, 2018 at 1:35 PM
    #1276
    dirty deeds
    Nick
    Eastern KY
    We can nail down our meet time a bit closer to the meat
  17. Jun 6, 2018 at 1:44 PM
    #1277
    tacofort
    Joe
    Cincinnati, OH
    Is our campsite reachable by a stock F-150 without causing damage to the truck? A buddy of mine was thinking about coming out and riding along with me.
  18. Jun 6, 2018 at 1:52 PM
    #1278
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Anyone have a magnetic mount cb antenna i can borrow for the meet?
    I can pwr my cb through 12v plug in dash but i likely won't have a good mount for the firestik installed yet.
  19. Jun 6, 2018 at 1:58 PM
    #1279
    dirty deeds
    Nick
    Eastern KY
    Yea. The most direct route is somewhere off the parkway around Campton.
    Is it at least 4x4? It's a pretty steep descent on "gravel" down onto the trial, may have trouble leaving and need pulled out by a Tacoma :devil:
  20. Jun 6, 2018 at 1:59 PM
    #1280
    dirty deeds
    Nick
    Eastern KY
    I had the Scosche from wally world, until LBL. Feel like someone else has this same thing.
