3rd Annual SAN G. TRAIL RUNS & POTLUCK/BBQ ON 9/22-24
Discussion in 'Southern California' started by BLKTRUCK, Jul 17, 2017.
  1. Jul 20, 2017 at 5:26 PM
    #561
    Kloy
    Kloy Well-Known Member
    Orange County, CA
    '16 Off Road white
    So question, a friend of mine is interested in off-roading, would a 2wd stock tundra that doesn't have AT's be able to do trails without much damage?
    TXpro4X4 and eccracer104 like this.
  2. Jul 20, 2017 at 5:33 PM
    #562
    BLKTRUCK
    BLKTRUCK [OP] Where’s @ODNAREM?
    The Privilege
    Find Ron
    ICON 2.5, ARB bumper, ICON 2.0 RR, Dakar leaf pack, Maxtrac spindles, Moto Metal wheels,
    The turn radius might be hard on a tundra.
    I would tell him to show up and ride shotgun.
    TXpro4X4 likes this.
  3. Jul 20, 2017 at 5:36 PM
    #563
    tcjacado
    tcjacado Well-Known Member
    Should be fine in most situations. Like bee canyon, lasardi trail and such. idyllwild had a Chevy volt up on one of trails Chan took us on. I lost all respect for that trail instantly!:rofl:
  4. Jul 20, 2017 at 6:02 PM
    #564
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    I've seen a Honda Element up on some nasty trails in Big Bear. I laughed and lost respect for the trail too... Unless they found some alternative route but every direction would have definitely caused some under carriage damage that's for sure.
  5. Jul 20, 2017 at 6:45 PM
    #565
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Turn radius could potentially be tough, and maybe some pinstripes from being wide (if it's the 07+ body style, non issue if 1st gen Tundra). Aside from that should be just fine for the most part :thumbsup:
    Kloy[QUOTED] and tcjacado like this.
  6. Jul 20, 2017 at 8:02 PM
    #566
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    Can someone educate me on the BFG K02s please? I remember reading that they should be rotated every xxx amount of miles? I could be wrong.
  7. Jul 20, 2017 at 9:27 PM
    #567
    WileECoyote
    WileECoyote Well-Known Member
    SoCal
    1st Gen 4WD 2.7L RegCab
    Yaesu FT-1900R w/ 2m/70cm Comet SBB-224 antenna, Cobra 19 DX IV w/ 4ft Francis CB24 Hot Rod antenna, Uniden Bearcat BC355N 800Mhz mobile scanner (analog), an external BNC mount routed to inside the cab for a handheld fire/police scanner or HAM HT's, Rancho RS5000 front struts and rear shocks, 6in KC Daylighter (pencil beam), 15x7 Black Rock Wheels Series 942, 31x10.50R15 Firestone Destination AT, fog lights, COBRA antenna hood mount (this is used to mount the GoPro on to)
    YESSSSS!!! This is very true!!! :thumbsup::fistbump:
    dtaco06[QUOTED] likes this.
  8. Jul 20, 2017 at 9:36 PM
    #568
    noSKills858
    Alex
    Poway, CA
    You guys rotate your tires that often? I rotate my tires on every vehicle when the tread becomes much more uneven (that is about every 30k).
  9. Jul 20, 2017 at 9:38 PM
    #569
    WileECoyote
    SoCal
    You're actually losing "mileage life" out of your tires by doing that!!! Just trust me on that one!!! :thumbsup::fistbump:
    dtaco06 and tcjacado like this.
  10. Jul 20, 2017 at 9:40 PM
    #570
    WileECoyote
    SoCal
    "Cupping" can be from many different things like: 1) bad shocks/struts 2) alignment 3) simply lacking of the rotation of the tires etc etc etc. Again, it can be caused by quite a few things, but those are the most "main issues" that cause tire cupping. :thumbsup::fistbump:
    Btw, IF (NOTE: SOME tires are "directional"... well, not most of your off-road type tires, but... anyways, just as long as they're not directional is the point) you can, "cross-rotate" your tires if there is any form of cupping involved!!! :thumbsup::fistbump:
  11. Jul 20, 2017 at 9:41 PM
    #571
    tcjacado
    I ruined a set of new tires with a bad alignment on my 07. I had two new fronts put on and didn't bother with a alignment. Tire size I changed to was a little smaller, but I took a trip to big bear, pavement only and by the time I got off the mountain and home. The inner tread was bald, I was pissed as af.
    Nicklovin likes this.
  12. Jul 20, 2017 at 9:44 PM
    #572
    noSKills858
    Alex
    Poway, CA
    Yeah but it's probably the equivalent to running the A/C. On my truck I don't care, I run 10-15 year old tires and they get swapped around because I run a bit of negative camber on my front end for the desert. My car, it gets 30-35 mpg with old bald tires so losing 1 mpg doesn't bother me that much.
    WileECoyote[QUOTED] likes this.
  13. Jul 20, 2017 at 9:45 PM
    #573
    WileECoyote
    SoCal
    LOL, well, since you put it that way!!! :laughing::laugh::rofl::rofl::rofl:
    The highlighted RED makes sense as well!!! Not much you can really do their either way? You could still try to cross-rotate to help a littttttttle bit though!!! :notsure:
    tcjacado likes this.
  14. Jul 20, 2017 at 9:47 PM
    #574
    noSKills858
    Alex
    Poway, CA
    As long as I have tread on the front tires so I can turn, I'm all good!
    tcjacado and WileECoyote like this.
  15. Jul 20, 2017 at 9:57 PM
    #575
    2000man
    2000man The Church Of @ODNAREM San Diego Chapter 1904
    G
    SDMF CA
    Shadow 4x4
  16. Jul 20, 2017 at 10:32 PM
    #576
    ItsRichieRich
    Richard
    Temecula, CA
    '13 Ford Raptor
    Ok, so I am not crazy. I thought I read somewhere here on the forums that you gotta change out the KO2s had to be rotated more often than 5k miles.
    WileECoyote and TXpro4X4 like this.
  17. Jul 20, 2017 at 10:34 PM
    #577
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    So, I'm thinking about changing my mind from going to Calico to this one. Who was planning on fishing saturday? Heard theres a few places nearby to catch some native browns. Not much of a trout fisher but would love to catch one
  18. Jul 20, 2017 at 10:42 PM
    #578
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    You would be surprised where front wheel drive cars can get you...:anonymous:
    ODNAREM, dtaco06 and tcjacado[QUOTED] like this.
  19. Jul 20, 2017 at 10:43 PM
    #579
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Every 5000! Or as close as I can
    ODNAREM and dtaco06 like this.
  20. Jul 20, 2017 at 10:45 PM
    #580
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Yes.
    But what condition are his tires and he's not trying to cruise up with like some 21 inch rims on rubber bands that are half bald?
    And some of the turns would require a little bit of forward and backing up as other have said
    Kloy[QUOTED] and ODNAREM like this.
