3rd Brake Light Antenna Mount
Discussion in '1st Gen. Tacomas (1995-2004)' started by Willbeck, Jan 22, 2018.
  1. Jan 23, 2018 at 12:48 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Im in. For 2 potentially.
  2. Jan 23, 2018 at 1:06 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Count me as a maybe. I've been thinking about how I'm going to mount an antenna and this looks like it has potential... in the mean time :popcorn:
  3. Jan 23, 2018 at 9:15 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Also in, interested in what the price would be.
    Do you think you could add another place to mount an antenna on the other side? Then I could mount a long range gps antenna and calm my OCD down too...
    BURRTIO and ClevSix like this.
  4. Jan 23, 2018 at 9:21 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Link to 2nd gen version thread ?.. interdasted fosho
  5. Jan 23, 2018 at 9:25 PM
    Willbeck
    Willbeck [OP] Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Thread has the same title. I’ll see if I can dig it up
    IronPeak[QUOTED] likes this.
  6. Jan 23, 2018 at 9:29 PM
    IronPeak
    AuggieX
    Back to Back
    Found it thanks, i like the clean look and thoughtful design. Was planning on adding a mount to my Thule rack crossbars but I like this permanence of this, plus if I pull my shell it could stay on. Since they just stopped making my truck 2 years ago reselling it (planning on owning this or some 2nd gen for the rest if my life, but you never know) would be easy. Ive been thinking about that when considering any mods these days.
    Willbeck[QUOTED][OP] likes this.
  7. Jan 24, 2018 at 8:41 AM
    Skeletoy
    Skeletoy Well-Known Member
    RDM, OR
    Stock 3rd gen, Samurai
    I'd be in for one
    Willbeck[OP] likes this.
  8. Jan 24, 2018 at 10:07 AM
    ClevSix
    IL/IA
    I really like the idea of a mount for two antennas.
  9. Jan 24, 2018 at 10:33 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Can't do that...well..you could do a VHF and a gps. But not two separate VHF ones, you'll get interference.
  10. Jan 24, 2018 at 12:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    All types of antennas operate best with a full ground plane, not just ones for CBs.
    It seems like it would only be support for half a ground plane. The antenna broadcasts a 360° signal. Mounting the antenna in this location would tend to make the signal directional so to speak.
  11. Jan 24, 2018 at 1:43 PM
    ClevSix
    IL/IA
    Well kinda... the two antennas would have to be for different uses. You might be able to get two VHF antennas to work but would need to run band filters and run each on very specific freq ranges or something. That would be more headache then it is worth... Transmitting from two antennas that close together would be problematic at best. Instead of running HAM off the brake light mount I was thinking of running WiMAX or a Mobile Phone repeater.
    Then if you add a second mount maybe XM, GPS, something that is receive only. I still plan to have two whips, one for CB and one for HAM.
  12. Jan 24, 2018 at 1:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have 2 ham antennas and a cb. From my research they need to be a minimum of 19" apart.
    ClevSix[QUOTED] likes this.
  13. Jan 24, 2018 at 1:48 PM
    ClevSix
    IL/IA
    Maybe I should have been more clear... the CB and HAM antennas would not be on the 3rd brake light.
  14. Jan 24, 2018 at 1:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No i got your drift. Was just stating that they should be around 19" apart in general minimum
  15. Jan 24, 2018 at 1:53 PM
    #35
    ClevSix
    IL/IA
    19" is a good minimum, any closer and you will have issues to deal with. Further apart is better.
  16. Jan 24, 2018 at 2:01 PM
    #36
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Right, but with my regular cab, I'm not getting much of a ground plane regardless. This is just an alternate to drilling the roof, and it's better than a hood or bumper mount.
    I've also had my antenna mounted to a headache rack, only a couple inches away from where this mount would be, and it worked fantastic. If anything this will work a little better.
  17. Jan 24, 2018 at 2:30 PM
    #37
    Blackdawg
    Monte
    Wyoming/St. Louis
    I had all mine mounted to a bar that was close to the roof. They worked.
  18. Jan 24, 2018 at 3:01 PM
    #38
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    thread = jacked
  19. Jan 24, 2018 at 3:24 PM
    #39
    Skeletoy
    RDM, OR
    Any idea for price?
  20. Jan 24, 2018 at 4:46 PM
    #40
    ClevSix
    IL/IA
