3rd Brake Light Safety Recall?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jose_Dirte, Aug 12, 2021.
  1. Nov 8, 2021 at 11:24 AM
    #341
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    I just did mine , my self . I should of taken pictures . But to all who is asking if it can be done with a cap ? part of the process , Is laying a beed of marine grade silicone around the brake light. You have to be able to access the bottom to properly seal it and smooth it out with a provided edge tools for them you attach the edge trim which has double sided tape .
  2. Nov 8, 2021 at 11:25 AM
    #342
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    If the dealer does the repair and later down the road it leaks, the fix and water damage is on their nickel. If you do the repair, not so much.
    helix66 likes this.
  3. Nov 8, 2021 at 11:26 AM
    #343
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    They told me I couldn’t order the part because it’s a recall. So I came home and googled it. Part #00948-CHMSL
  4. Nov 8, 2021 at 11:28 AM
    #344
    HelloFelix
    Felix
    Las Vegas
    I order mine offline from a Toyota dealership . Took multiple tries . First few companies returned my money. I finally was able to purchase one .
    MGMDesertTaco likes this.
  5. Nov 8, 2021 at 11:49 AM
    #345
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Dealership called me last week about it and got me in next day. Easy peasy done and done!
    helix66 and MGMDesertTaco like this.
  6. Nov 12, 2021 at 9:51 AM
    #346
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Which is exactly why I got it done.
    Also if you don't get it done and later on it leaks it's your headache.
  7. Nov 12, 2021 at 10:47 AM
    #347
    zod
    zod Member
    Noticed I had water running down the inside of my back window yesterday...was like crap! I thought the window was leaking but upon better inspection I noticed the headliner was wet so I knew it had to be coming from the antenna or the 3rd brake light. I was about to order parts and fix it myself but thought to myself, "I should check out the forum." Glad I did...Toyota is fixing it Monday.
    HisDad likes this.
  8. Nov 13, 2021 at 7:58 AM
    #348
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    I am going to do this myself since I have a shell and have no plans to take it off this winter. Can the trim bezel be ordered through Toyota? Any tips?
  9. Nov 13, 2021 at 8:05 AM
    #349
    USMC - Retired
    USMC - Retired No Better Friend, No Worse Enemy
    Gunns
    Ty Ty, Georgia
    2018 DCSB Quicksand
    Was in for an oil change recently and the service guy mentioned the recall and they did it while I was there. Easy day, took maybe an extra ten minutes longer than the normal wait time for the oil change.
    *edit to add that the service writer is a Marine as well and hooked me up with a discount on my oil change, "Brother to Brother".
    TartanEagle and Rottencotton like this.
  10. Dec 1, 2021 at 7:58 AM
    #350
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    I have an appt to get this done in a couple weeks. I had already siliconed around it a couple years ago when the only alternatives were to pay $600 out of pocket to have them replace it or deal with it.
    It’s never had a problem since I did it but the clear silicone is noticeable and I want a factory fix.
    Should I waste effort removing the silicone I have or just take it to dealer as is?
  11. Dec 1, 2021 at 12:30 PM
    #351
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    My guess is the dealer will try to charge you to remove the silicone you applied.
    daveeasa likes this.
  12. Dec 6, 2021 at 11:36 AM
    #352
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Classic, just juggled everything for service today, asked neighbor to help remove the shell, get to the dealer a bit early to pick up and they are OOS on trim rings.
    So I’m going to have to do the shell swap again sometime. Super fun times.
  13. Dec 7, 2021 at 1:10 PM
    #353
    rmac010
    rmac010 Well-Known Member
    2017 DCSB TRD Sport
    anyone with a camper shell gone to the dealer for the recall & charged to remove / move the camper shell to get to the 3rd brake light?
  14. Dec 7, 2021 at 1:20 PM
    #354
    BBanning
    BBanning Instagram: GCS_Tacoma
    Green Cove Springs, FL
    2019 Quicksand Tacoma TRD Offroad 4x4
    I just got mine replaced/resealed under recall, you should be able to too.
  15. Dec 7, 2021 at 1:22 PM
    #355
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    I just received my notice in the mail yesterday so I better get a hold of the dealership to schedule. :rolleyes:
  16. Dec 7, 2021 at 1:38 PM
    #356
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Yes. They quoted me an hour, and we negotiated down to half of that. Was worth it for me to not have to leave, talk off the shell, and go back another day (they didn't warn me in advance they would charge for it).
    rmac010[QUOTED] likes this.
  17. Dec 7, 2021 at 1:48 PM
    #357
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    did you ask about yours? I bought my truck used and when inspected the people said well someone already messed with it so it voids the fix... to me it sounds like if you tried to stop the water leaking they kill the warranty even though they tried to charge you before it became a known issue.
  18. Dec 7, 2021 at 2:03 PM
    #358
    Jose_Dirte
    Jose_Dirte [OP] Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    I'm actually riding Lyft as we speak from dropping mine off at Toyota.
    Looks like they're replacing my headliner and we'll see on the carpet.
    Of course they'll have to order it in first even though they said they would order it ahead of time....
  19. Dec 7, 2021 at 2:06 PM
    #359
    MGMDesertTaco
    Funny my dealer never contacted me about this. Must've forgot about me. :tumbleweed:
  20. Dec 7, 2021 at 2:08 PM
    #360
    Jose_Dirte
    Joey
    Green Acres, CO
    You have to contact them.
    They're not actively reaching out.
    If you use the Toyota app it will have an alert.
    MGMDesertTaco[QUOTED] likes this.
