3rd Brake Light Safety Recall?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jose_Dirte, Aug 12, 2021.
  1. Dec 7, 2021 at 2:22 PM
    #361
    GumShoe
    GumShoe Well-Known Member
    New Mexico
    MGM 2016 Tacoma SR V6 4x4 DCSB
    I guess it depends on the dealer. They quoted me $600 but I said no. I fixed it myself for $150 but didn’t tell them about it and it’s not noticeable at all. That was back in 2018.
    Just this year, I went back to the Dealership and they went ahead and did the recall work anyways by applying silicone around the light and placing a bracket on it. They probably didn’t even check if it was leaking. It’s not much but it’s an extra layer of protection.
    Cipher94[QUOTED] likes this.
  2. Dec 7, 2021 at 2:23 PM
    #362
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    I had mine in for the fuel pump recall and they apparently ordered the parts to do the brake light. They called me a few days later and said the parts were in and they needed to schedule me to come in and get them installed. I'm like, wtf are you talking about? Oh, the service writer didn't tell you about the third brake light recall? Well, no. I took it in a couple of days later and got it done so I'm caught up on recalls for now.
    eurowner likes this.
  3. Dec 7, 2021 at 6:44 PM
    #363
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    I'll probably run a bead of silicone around it again at some point then.
  4. Dec 9, 2021 at 3:51 AM
    #364
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    this came up on mine but have a questoin?, if you are out of warranty do they still cover it?
    Service Campaigns:
    Title
    LIMITED SERVICE CAMPAIGN 21TD03 (Remedy Notice) - Certain 2016-2019 Model Year Double Cab Tacoma - Center High-Mounted Stop Lamp - Water Leak
    Status
    Remedy Available
    Description
    The Center High-Mounted Stop Lamp on the involved vehicles has a seal between the lamp and the vehicle body which can deteriorate over time. If the seal deteriorates sufficiently, water from outside the vehicle could leak into the vehicle cabin through the seal.
    Remedy
    Any authorized Toyota dealer will inspect the vehicles headliner to determine if a water leak resulting from this condition has occurred. If no such water leak is identified, the dealer will install the Center High Mounted Stop Lamp Repair Kit FREE OF CHARGE. If the aforementioned water leak is identified, the dealer will (1) either install the Center High Mounted Stop Lamp Repair Kit or a new Center High Mount Stop Lamp Assembly, as appropriate; and (2) clean and/or replace interior components damaged by the aforementioned water leak, as appropriate, FREE OF CHARGE.
  5. Dec 9, 2021 at 4:01 AM
    #365
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    I actually received a recall notice in the mail directly from Toyota about this, so I logged onto my dealer website in the service area, and it was right there saying my 2019 Tacoma TRD Sport had a recall notice, specifically, this one for the 3rd brake light. I made the appt and it was all done within an hour.
  6. Dec 9, 2021 at 4:04 AM
    #366
    oogielaflick
    Keith
    Regarding the fuel pump recall, I don't know where you live, but here in CA, the DMV actually will not renew your license plate if you do hot have this recall. This is well documented on another thread about this here on TW. Just get it done, along with the 3rd brake light recall too. Although both may be alright, I would not want to wait until either one craps out on you. Yes it is annoying to have to take the truck back to the dealer, but in my case at least, I thought better safe than sorry...
  7. Dec 9, 2021 at 5:07 AM
    #367
    Jose_Dirte
    Jose_Dirte [OP] Life's a garden, dig it
    Joey
    Green Acres, CO
    A Tacoma, just like everybody else...
    Yes, it's kind of like a recall.
    I have 90k miles on mine and just got the repair done 100% free
    kgilly[QUOTED] and davidstacoma like this.
  8. Dec 9, 2021 at 8:23 AM
    #368
    eurowner
    eurowner Duke Sky
    Scoty
    Correct, it is a Campaign. I got an email stating that I have a 5 year window to have it done.
    kgilly[QUOTED] likes this.
  9. Dec 9, 2021 at 8:39 AM
    #369
    Rottencotton
    Stinkin Rincon
    5 years is insane. That's plenty of time for it to leak to develope and destroy your interior with mold and other nasties. :bananadead:
  10. Dec 9, 2021 at 9:55 AM
    #370
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Quote for 4h to install trim ring after already having the truck the better part of a day for oil change and recall (without telling me they were out of trim rings until I picked it up).
    Ah, good times...
    shakerhood likes this.
  11. Dec 9, 2021 at 5:40 PM
    #371
    Jose_Dirte
    Joey
    Green Acres, CO
    I'm just glad Toyota stepped up to do this for all of us out of warranty and didn't just act like there wasn't a problem. Mine was leaking pretty bad.
  12. Dec 10, 2021 at 11:49 PM
    #372
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    Yeah, normally I would assume my 2017 work truck would be out of warranties since it's well past the 36K/3years at 4years/80K by now, so I jumped on it when I saw there wasn't a stipulation like that I could find mention of.
  13. Dec 12, 2021 at 9:18 PM
    #373
    ARNIE R
    ARNIE R Well-Known Member
    Arnold
    Leesburg, VA
    2019 Tacoma White SR5 4D ShortBed
    Fender gravel guards; Side step bars; Bug shield; Vent shades; Body side door moldings; Door edge trim; Tonneau cover
    Has anyone had this done who had a Lomax tri-fold hard tonneau cover on the bed and had to remove it first, or were they able to work around it?
  14. Dec 13, 2021 at 4:00 AM
    #374
    Rottencotton
    Stinkin Rincon
    I have a Rough Country hard tonneau on mine and they didn't say anything. Figured it gave them something to sit on while doing the work. Beats standing up and stooping down.
    ARNIE R[QUOTED] likes this.
  15. Dec 13, 2021 at 4:44 AM
    #375
    oogielaflick
    Keith
    I took my truck in and I have a hardtop trifold bed cover. I just unlocked the tailgate [power lock with a dash switch] and folded the cover up, leaving it on. That was plenty of room for them to be able to replace the 3rd brake light. No problems.
  16. Dec 13, 2021 at 5:52 AM
    #376
    Jose_Dirte
    Joey
    Green Acres, CO
    I have a Leitner ACS rack.
    I took my tent off for the winter and had removed the front cross bar and they had zero issue with it.
    ARNIE R likes this.
  17. Dec 23, 2021 at 7:17 AM
    #377
    TheNatural07
    TheNatural07 New Member
    I just had my "recall" done on my 2017 DCLB OR on 12/22. Everything was fine before I went in and my truck wasn't having any issues. The dealership had the truck for about 4 hours before calling me to tell me it was done. They said they didn't have to replace the whole light and that there was only a little bit of moisture they found. When I went back to pick it up the vehicle it had a weird smell, kind of like vomit that definitely was not there before I dropped the truck off. I asked the dealership what the smell was, but nobody seemed to care or have any answers. Have any of you guys noticed a strange smell when you went to pick up your truck after the recall was completed?
  18. Dec 23, 2021 at 9:57 AM
    #378
    Rottencotton
    Stinkin Rincon
    Maybe one of the techs was sick that day.
  19. Dec 23, 2021 at 10:01 AM
    #379
    Cloaked
    Cloaked Well-Known Member
    Got mine doen jus
    Got mine done today. No smell but I suspect it was the sealant they used that caused the smell in your cab.
    They did all of the work from the outside.
    No leaks here so they put a new seal in as the recall stated. 1.25 hours of shop time. Done deal.
  20. Dec 23, 2021 at 10:13 AM
    #380
    TheNatural07
    Thanks cloaked. When I asked the service manager he checked with the team that did the work and they said the sealant and glass cleaner they use doesn’t normally have a smell. They also said the same thing to me about doing the work from the outside. Hopefully you’re right and it’s just the sealant.
