3rd Brake Light Safety Recall?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jose_Dirte, Aug 12, 2021.
  1. Apr 21, 2022 at 7:21 AM
    #441
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I found the lense on the passenger side had a crack in it - no leakage. Dealer wanted to charge me for a new light which was obviously caused by over tightening from factory. I decided to buy the light on line and do the work myself - only to later find the dealer mod for a "no-leak" situation was to add the plastic bezel rim ring with sealer. I can't find the plastic bezel trim ring anywhere and the dealer is of no help since I would not let them replace the light at my cost. Anyone here know the PN for the no-leak plastic trim ring ? (not the foam gasket) TIA
    MGMDesertTaco likes this.
  2. Apr 21, 2022 at 7:36 AM
    #442
    MGMDesertTaco
    See below...
    Virginian[QUOTED] likes this.
  3. Apr 21, 2022 at 7:38 AM
    #443
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Says right in the recall that the dealer might have to REPLACE the light. You shouldn't have to pay for it. Print out the recall and highlight the area where it states this and bring it to the misinformed dealer
  4. Apr 21, 2022 at 8:02 AM
    #444
    MGMDesertTaco
    The dealer will only replace the light if interior water damage is found. According to the tsb, the trim gasket isn't supposed to be needed if the light is replaced with the updated light that has the thicker gasket, but do what works for you.
    https://www.toyoheadquarters.com/th...eak-limited-service-campaign-lsc-21td03.2280/
    "**Note: Parts needed will be dependent on inspection results. If a vehicle requires a new Center High-Mounted Stop Lamp Assembly, the vehicle does NOT require the repair kit nor the hardware kit. Refer to the technical instructions for more detail. Any work needed to replace interior components damaged by the water leak resulting from this condition will require prior approval by FTS through website submission requiring photos."
    GoldenBrew likes this.
  5. Apr 21, 2022 at 8:59 AM
    #445
    GoldenBrew
    Golden, Colorado
    This. Exactly my case. No leak no leak repair. I even had the LSC in hand hoping they would cut me some slack. Not.
    MGMDesertTaco[QUOTED] likes this.
  6. Apr 21, 2022 at 9:02 AM
    #446
    GoldenBrew
    Golden, Colorado
    investigation on my part says the listed parts are foam gasket with sealer and adhesive kit/tool - no plastic trim piece. although the Dealer data/picture are vague. ??
  7. Apr 21, 2022 at 9:07 AM
    #447
    TacoSupremo19
    NJ
    I think you mistaking the trim piece for a gasket. There is no gasket that is replaced.
    This picture shows both "kits" The sealant and tool are the "HW" part # and the bezel and the stencil are in the plastic bag
  8. Apr 21, 2022 at 9:11 AM
    #448
    GoldenBrew
    Golden, Colorado
    True, I replaced the complete light with the new version - I don't need a gasket only the trim piece - but neither of the two items listed indicate they are the plastic trim according to the dealer description. I will look again - I certainly could be wrong.
  9. Apr 21, 2022 at 9:16 AM
    #449
    TacoSupremo19
    NJ
  10. Apr 21, 2022 at 9:16 AM
    #450
    MGMDesertTaco
    I'll let you know what the trim piece is made of exactly when it arrives on the 27th via snail mail. ;):turtleride:
  11. Apr 21, 2022 at 12:53 PM
    #451
    GoldenBrew
    Golden, Colorado
    Thanks for the clarification - I will go back to my dealer on-line parts department and see if I can order the bezel only - I have sealer and caulking tool.
    Please do - I would like to be sure.
  12. Apr 21, 2022 at 1:06 PM
    #452
    TacoSupremo19
    NJ
    00948-CHMSL
  13. Apr 21, 2022 at 1:09 PM
    #453
    GoldenBrew
    Golden, Colorado
    thanks! got it and found it at the on-line parts department of the dealer nearest to me. gonna order and install as soon as I pick it up.
    Thanks again for your assistance and patience! @MGMDesertTaco too!
  14. Apr 21, 2022 at 2:45 PM
    #454
    GoldenBrew
    Golden, Colorado
    well Rat F'k - dealer just called and said they won't sell me the trim - even though I replaced the light (which did not leak but had a crack in it). Total Cluster dance. Parts manager said he would see if there is a way to sell. He said the trim piece is associated with the LSC - so if you don't qualify you can't purchase it. Looks like one of you lucky people has a dealer that is less by-the-book. @TacoSupremo19
  15. Apr 21, 2022 at 3:13 PM
    #455
    MGMDesertTaco
    Yep, been there. Dealers won't sell the parts, because they can make more from Toyota doing the TSB. I've been told no by 3 local dealers and had a couple dealers cancel my online orders. Here's my suggestion:
    Enter the part numbers on Walmart's website and look for a seller by the name of Fred Haas Toyota out of Texas. See below...
    GoldenBrew[QUOTED] likes this.
  16. Apr 21, 2022 at 5:40 PM
    #456
    GoldenBrew
    Golden, Colorado
    will do if they dick me around. Thanks.
  17. Apr 22, 2022 at 2:40 PM
    #457
    GoldenBrew
    Golden, Colorado
    yep dealer shot me down - their solution was for me to reinstall the old broken brake light, bring it in and pay for a new light and then they would allow the trim to be purchased/installed. Not happening. Moving on to your solution or to simply wait until the LRC is expired and then buy trim. Truly a $$ grab for the dealers.
  18. Apr 22, 2022 at 2:44 PM
    #458
    MGMDesertTaco
    Only a few left on Walmart....:boink:
  19. Apr 29, 2022 at 1:22 PM
    #459
    MGMDesertTaco
    Just emailed my documents for reimbursement request. We shall see...
  20. Apr 29, 2022 at 1:46 PM
    #460
    08sprsnke
    08sprsnke Shelby Girl
    Pleasanton, Ca
    2016 TRD Sport
    3" Lift, 17x9 Pro Comp Wheels, Toyo A/T 285/70/17
    Well, that's not true. My Vin is part of the recall and I did receive a notice. I did not have any evidence of the light leaking and told the dealer that. They said better safe than sorry, made an appointment and got it done.
