3rd gear grinding
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Seimandi14, Jun 9, 2018.
  1. Jun 9, 2018 at 12:46 AM
    Seimandi14
    Seimandi14 [OP] Member
    Sergio
    2017 tacoma trd or
    Hi anyone still having problems with the 6sp manual getting 3rd gear into place, mine still grinding after 3500 miles and its getting worst, any advise or experience on this will help because I'm going to the dealership to claim the powertrain warranty!!
    2017 trd off road 6 spd manual
    2.5 lift with bilsteins 6112 and 285's
    MOC221_ likes this.
  2. Jun 9, 2018 at 1:15 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No problem with mine. Try shifting at different (higher) rpm. Welcome to TW!
    bobrown14, su.b.rat and shakerhood like this.
  3. Jun 9, 2018 at 3:22 AM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    No problems here. It’s synchronized so it shouldn’t be grinding unless your not using the clutch or something like that.
    tonered and bobrown14 like this.
  4. Jun 9, 2018 at 5:16 AM
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
    No problems here
    bobrown14 likes this.
  5. Jun 9, 2018 at 6:21 AM
    Mountainhog
    Mountainhog Active Member
    Joe
    2018 cement off road mt
    Cooper discoverer stt pro, SCS 16" wheels, fox stage 2 lift with HS add a leaf, factory pro grill, clazzio seat covers.
    Girlfriend and I both have 2018 dcsb offroad. My truck never had the grinding in 3rd, but with her truck has happened several times with either of us driving and only in 3rd gear. Maybe once every 500 miles as it usually shifts fine. At first I thought it was user error but now I believe something is wrong with synchro. Dealer is 2 hours away so not wanting to take it there so they can tell us they could not replicate the problem.
  6. Jun 9, 2018 at 6:41 AM
    GR8APE
    GR8APE Well-Known Member
    Sounds like 3rd gear synchronizer may be chipped, you haven't been speed shifting have you?
  7. Jun 9, 2018 at 7:45 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No grinding at all on mine either.
    tonered likes this.
  8. Jun 9, 2018 at 7:52 AM
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Smooth as butter
  9. Jun 9, 2018 at 7:54 AM
    Bishop84
    Bishop84 Well-Known Member
    Just don't be a douche about it and if one dealer doesn't claim it move on to another. Pissing on the tree doesn't help and you'll get better service with a good attitude.
    It's likely they will blame your driving/shifting.
  10. Jun 9, 2018 at 8:06 AM
    Seimandi14
    Sergio
    2017 tacoma trd or
    No I haven't, neither abuse of the truck. And it's every single time I shift to 3rd that grinds.
    tonered likes this.
  11. Jun 9, 2018 at 8:06 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    FWIW, my '16 did this for a while and eventually went away (more of a chunk when engaging 3rd). I don't know exactly how many miles it took, but I can tell you it's butter now and I haven't noticed any ill effects (~33,000 km on the odo today).
    All I can say is don't force the shift, just let it "fall in" with light pressure.
    specter208 likes this.
  12. Jun 9, 2018 at 8:21 AM
    GR8APE
    Yep, it sounds like a broken sychronizer ring. You might also check your transmission fluid level but I doubt that's the problem. You can double clutch sometimes to keep it from scraping until you find out what the problem is. I asked about the speed shifting because I have missed a lot of gears in my life and most of the time I ruined a syncro.
  13. Jun 9, 2018 at 11:06 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Yep, it sounds like a bad synchro ring. warranty service time.
  14. Jun 9, 2018 at 2:06 PM
    su.b.rat
    su.b.rat broken truck
    no problems here either but i do need a good aim to get it right or the stick will bounce back with 3rd. but no grinding or any of that.
  15. Jun 10, 2018 at 4:19 AM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Sorry you’re having 3rd gear shifting problems..but are you
    “Granny shifting not double clutching like you should?”
    Sorry...I saw the opportunity
    On the real, have your dealer verify, and check your trans fluid level.
  16. Jun 10, 2018 at 11:26 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    That.^^^. honey get the fly... or sumptin like that. Vinegar not so much.
    If it did it from the get-go should have taken it in to document moving forward so track record.
    IF they blame you, ask them was there ZERO miles on my truck when I drove it off the lot? Food for thought.
    Don't let em blame the suspension either. Dealers lift these trucks all the time b-4 sale with shit lifts too.
    That all said, have you tried a carrier bearing spacer add-on. I had a slight grinding sound (likely from the u-joint) and a carrier bearing spacer tco'd my only problem after lifting.
    Tranny smooth as silk. SPECIALLY 3rd gear. Sounds like a synchro problem. How's the clutch feel - is it soft easy no squeaks?
  17. Jun 11, 2018 at 7:40 AM
    Seimandi14
    Sergio
    2017 tacoma trd or
    Clutch feels just right, and I've been trying holding the clutch for a wile and shift to 3rd slowly, that will work but it takes for ever and that's not how it should be! Truck came with like 50 miles on it!
  18. Jun 11, 2018 at 8:35 AM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    Mine needed to be kind of eased into 3rd for the first couple hundred miles to prevent a slight grind, at 1400 miles it shifts very nicely. Like butter as they say. No issues. If you're getting grinding at 3500 miles I think something is wrong. I wonder if in the 50 miles put on it before you got it if somebody tried to speed shift it and damaged a synchro. Good luck getting it resolved.
    Seimandi14[OP] and bobrown14 like this.
  19. Jun 11, 2018 at 9:27 AM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Dealer time... be kind and humble.. and firm if you need to be. G/L
  20. Jun 21, 2018 at 7:12 AM
    Seimandi14
    Sergio
    2017 tacoma trd or
    Thanks you all for the comments and advices, I just picked up my taco from the dealer they replaced the transmission for a new one at no cost and looks like problem is solved!
    Paul631, tonered, Arries289 and 3 others like this.
