3rd gear grinding
Discussion in '2nd Gen. Tacomas (2005-2015)' started by will84, Feb 19, 2020.
  1. Feb 19, 2020 at 9:03 AM
    will84
    will84 [OP] Active Member
    Will
    2005 Green Tacoma
    2005 Tacoma with a 6 speed manual transmission.
    About every other time I shift into 3rd gear, it grinds. It doesn’t do it in any other gears. It doesn’t take a bunch of extra force to get it in gear, but it does grind.
    The pivot seat bushing is out, so I was thinking that could be causing it so I have the bushing kit for the shift lever on order.
    Do you guys think that will fix it?
    Truc577 likes this.
  2. Feb 19, 2020 at 11:41 AM
    binge_stinker
    binge_stinker Well-Known Member
    2005 4X4 MT6 DCSB
    Power sliding rear cab window retrofit
    Mine does the same. I’ve done a good amount of reading and I’m positive my 3rd gear synchro is worn.
    Jimmyh and jetfishn like this.
  3. Feb 19, 2020 at 4:33 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    What fluid are you running?
  4. Feb 19, 2020 at 7:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Syncro more than likely.
    Do you rest your hand on the shifter when driving? That will wear a syncro out rapidly.
    Mully likes this.
  5. Feb 19, 2020 at 7:59 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    It can be fixed or replace the transmission. Good luck.
  6. Feb 19, 2020 at 8:04 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I figure the direction in which you apply pressure while resting your hand probably makes a difference, do you know which direction is the worst?
  7. Feb 20, 2020 at 1:42 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I would assume you are correct about the direction aspect. As to which direction I have no idea.
  8. Feb 20, 2020 at 5:20 AM
    tacoNS
    tacoNS Well-Known Member
    2006 TRD Off-Road 6-Speed Manual
    3rd gear grinds in mine too sometimes. I think it's just the syncro being worn out. Changing the gear oil may help a bit though
  9. Feb 20, 2020 at 5:28 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Try running some heavier gear oil like lucas 85w140
  10. Feb 20, 2020 at 9:36 AM
    andrew61987
    Funny, in mine only 2nd gear ever grinds. And only when downshifting form 3rd in 4LO. Never otherwise. But I have the 5spd.
  11. Feb 20, 2020 at 9:39 AM
    Truc577
    Truc577 Well-Known Member
    Curt
    NOMO
    2005 TRD OR 4x MT, 2020 TRD OR 4x AT
    High output valve stem caps 2020: Bilstien 6112/5100 Mobtown sliders RRW RR-5 Bronze wheels 2005: 2018 frame and full suspension 2017 Dark Anthracite wheels ARB front bumper
    Mine will grind only when its cold. Started after changing fluid and replacing with Redline.
  12. Feb 20, 2020 at 9:40 AM
    Truc577
    Curt
    NOMO
    Different trans but yes if I easily slide it in, it doesn't grind even if cold.
    whatstcp[QUOTED] likes this.
  13. Feb 20, 2020 at 9:42 AM
    andrew61987
    Sounds like a keeper :cool:
    Jimmyh and Truc577[QUOTED] like this.
  14. Feb 20, 2020 at 9:43 AM
    Truc577
    Curt
    NOMO
    That moment when I am typing something in and I know someone just like me will go another direction.
    :rofl:
