3rd gear syncro is shot, what to do??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ipunchwalls, Sep 9, 2011.
  1. Sep 9, 2011 at 10:28 AM
    Ipunchwalls
    Ipunchwalls [OP] Well-Known Member
    Brian
    Colorado
    So I took my 05 6sp in to the dealer today because every time I would go into third I'd get a small grind and they informed me that my 3rd gear syncro was toast. They suggested the be course of action is to replace the entire transmission....estimate for that was $4700. I was floored as I cannot really afford dropping that kind of cash right now. What do you guys think I should do? I'm going to be looking for other transmission shops in the area, if anyone knows of a good shop in South Denver let me know.
  2. Sep 9, 2011 at 10:37 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    if you do drive it, make sure you rev it high in second and skip 3rd and go straight to 4th.
    i would have a tranny shop go in there and fix it
  3. Sep 9, 2011 at 10:57 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I skip third all the time go from 2nd to 4th and then 4th to 6th. You could do that for awhile as you save up, but you will have to get it fixed as it will deteriorate further.
  4. Sep 9, 2011 at 11:02 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I guess you're past even your drivetrain warranty period?
    Don't pay dealer retail for a new transmission, see a tranny shop for a repair.
    Meantime, learn to double- clutch. It's not that hard and once you get the hang of it, you may decide a repair isn't worth the cost.
  5. Sep 9, 2011 at 11:13 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I went both to a tranny and the dealer....MUCH BETTER deal from the local dealer than I got from AMCO. Labor itself was close to 75% less at my dealer.
  6. Sep 9, 2011 at 11:22 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    AAMCo does NOT count as a "local transmission shop!" :mad:
  7. Sep 9, 2011 at 11:27 AM
    Ipunchwalls
    Brian
    Colorado
    yeah I found a few shops I'm going to give a call to, other things I should look for is clutch replacement and possibly throwout bearing wear, anything else?
  8. Sep 9, 2011 at 11:29 AM
    08pretaco
    Oliver
    az
    OK I am sharing my experience which is why I did not put it simply as a local transmission shop rather put the companys name...moving on
  9. Sep 9, 2011 at 11:32 AM
    Ipunchwalls
    Brian
    Colorado
    see I bought the truck from a friend and was under the impression that it had the extended warranty, but we I take it in I tell them I don't know if it still has a warranty and they either don't check or it is in fact expired. I have around 80000 mi
  10. Sep 9, 2011 at 2:22 PM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
